Question about Grandstream GXP2100
How to Set up voicemail on Grandstream GXP 2100
Just moved into a office and need to know how to set up voice mail. Everything else is pretty self explanatory
3 Suggested Answers
ted1430
  • 339 Answers
SOURCE: GrandStream GXP-2000 not booting
If both phones are showing the same symptoms then it probably means that your DHCP server is down or not configured properly. If the phones are on a separate VLAN and you have recently upgraded or replaced your network switch then it could be misconfigured as well - specifically it may require you to configure a DHCP helper address.
Posted on Jan 09, 2010
  • 23 Answers
SOURCE: does grandstream gxp 280 support vonage
Yes it supports.
SIP Account Name: Vonage
Phone Number: xxxxxxxxxx (enter your Vonage phone number)
Authentication ID: xxxxxxxxxx (enter your Vonage phone number)
Authentication Password: xxxxxxxx (enter your Vonage Authentication Password, this can be Provided to you by Vonage. Please remember that the password is case sensitive.)
SIP Domain: leave blank
Proxy Address: sphone.vopr.vonage.net
Port: 5061
Outbound Proxy: sphone.vopr.vonage.net
Port: 5061
Local Port: 5061
Register Timer: 3600
Codec: Auto
Pkt. Time: Default
Out of Band DTMF: On
-Karthik.
Posted on Oct 20, 2012
How can I set up a new voice mail in a new office without that person code
Whoever is the voicemail administrator in your office can reset the password to default or the mailbox to new. Very often no one takes this responsibility, so you may need to call your service company to do this, sometimes remotely.
Sep 16, 2014 | NEC Lands Phones
LG KG290
Call "077" to listen to messages received. Follow the voice instructions to change your voice mail settings.
Sep 17, 2008 | LG KG290 Cellular Phone
Factory Reset Grandstream GXP 2000 w/o using the menu?
From the Granstream User Manual (Page 44):
Restore Factory Default Setting
WARNING: Restoring the Factory Default Setting will delete all configuration information of the phone.
Please backup or print all the settings before you restoring factory default settings. Grandstream is not
responsible for restoring lost parameters and cannot connect your device to your VoIP service provider.
INSTRUCTIONS FOR RESTORATION:
Step 1: Press "OK" button to bring up the keypad configuration menu, select "Config", press "OK" to
enter submenu, select "Factory Reset" (Please refer to Table 5-1 of keypad flow chart)
Step 2: Enter the MAC address printed on the bottom of the sticker. Please use the following mapping:
0-9: 0-9
A: 22 (press the "2" key twice, "A" will show on the LCD)
B: 222
C: 2222
D: 33 (press the "3" key twice, "D" will show on the LCD)
E: 333
F: 3333
Example: if the MAC address is 000b8200e395, it should be key in as "0002228200333
395".
NOTE: If there are digits like "22" in the MAC, you need to type "2" then press "->" right arrow key to
move the cursor or wait for 4 seconds to continue to key in another "2".
Step 3: Press the "OK" button to move the cursor to "OK". Press "OK" button again to confirm. If the
MAC address is correct, the phone will reboot. Otherwise, it will exit to previous keypad menu interface.
https://www.grandstream.com/products/gxp_series/general/documents/gxp_usermanual_english.pdf
Apr 03, 2014 | Grandstream GXP-2000 IP Phone
My voicemail has been set up, but it will not answer calls.. it rings and then rolls back into the main message for the office
Set your Call Forward Busy/No Answer to go to voice mail ext. as follows: Lift the handset, dial 4 then 3 followed by the voice mail ext. (the number you dial to retrieve voicemail messages). Hang up.
Jul 26, 2011 | NEC Electra Elite 32D-1 Corded Phone
How to set up voicemail on a Samsung KPDCS-12B office phone
If an Engineer has previously set up a Mail Box on your Voice Mail, then you need to assign a VMMSG button to that extension. this will allow access to your Voice Mail. I have posted a Voice Mail training video for you to watch- if you need the key setting up, go to youtube and search 'abbeytel' look for the 'how to program a softkey', I hope this helps, written help is available at
http://www.abbeytelecom.com
Jun 11, 2010 | Samsung DCS 12 Corded Phone
Does Toshiba Stratta DK 14 current setup offer voicemail?
A DK 14 is only capable us using the Stratagy Flash voice mail and is an external unit Grey in color. I have phones and systems that are compatible but it's not something you just "Turn On". idacomusa.com
Jan 26, 2010 | Toshiba DKT2010SD Phone
We have 2 lines in our office. When both lines are in use someone calling in gets a busy signal. How can I set up Norstar Talk Flash so incoming calls can go to voicemail?
Order a 3rd line or order Central Office voice mail. If you have 2 calling paths to your premise, that's all you get.
There are other ways around this, like Call Forward Busy to a voice mail only line you control, but it's pretty much the same priciple as CO Voice Mail. Depending on how well you shop, $10 or less gets you the service.
Carl
Dec 16, 2009 | NorStar Lands Phones
One of our office phones is set up for voice mail yet the phone rings continuously. It won't offer the caller voice mail. Any suggestions?
You need to go into system programming and set that extension to "Forward no answer" to the extension of the voicemail.
If you dont know what that means, I would call someone in, as you can ruin your system by doing the wrong things.
Aug 05, 2009 | Nortel Lands Phones
Trying to set the gxp2000 with 3cx pb x
Here is a step by step that is very good:
http://grandstream.com/support/gxp_series/general/documents/gxp_interop_3cx.pdf
If you have any more specific questions, please let me know in a follow up. I just set up a 3CX system with these phones last month and it's pretty fresh in my mind.
Jul 30, 2009 | Grandstream GXP-2000 IP Phone
How to Check Voicemail Remotely?
call your phone and once the voice mail picks up hit rhe pound symbol you will have to look up what your phones default voice mail code is but after that you can set a code and check you voicemail using any phone
Jan 09, 2009 | NorStar M7208 Corded Phone
Grandstream GXP2100 Logo
146 people viewed this question
Top Grandstream Computers & Internet Experts
David Payne
David Payne
Are you a Grandstream Computer and Internet Expert? Answer questions, earn points and help others
