Question about Dehumidifiers
SOURCE: Frigidaire 70-pint dehumidifier won't work after winter
No reset button on the compressor... but this tip may give you some clues as to what is or is not happening..
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Posted on May 05, 2010
SOURCE: How do I empty my frigidaire 70-pint dehumidifier?
Here is a tip that I wrote to help people with just that dehumidifier problem..
Dehumidifier Problem It shows Bucket Full
http://www.fixya.com/support/r4688381-dehumidifier_problem_shows_bucket_full
heatman101
Posted on May 15, 2010
SOURCE: My whirlpool AD70USS 70 pint dehumidifier won't
There
are many reasons why a dehumidifier will not work or collect water.
Here
is a tip that I wrote to help people to figure out what is going
wrong with their dehumidifier
Dehumidifier
heatman101
Posted on Jan 27, 2011
SOURCE: We have a Frigidaire 70
This happens quite frequently. It''s due to a clog in the hose or the a clog in the hose connection tubing. If you unit has a float valve in the top of the bucket, be sure that it's not stuck in the UP position. To resolve clogging problem, do the following:
1. Turn the Master ON/OFF Switch to OFF and unplug the unit. Disconnect the hose from the unit
and check for clogs and remove them if necessary.
2. If no clogs were found in the hose, the clog is in the hose connection tubing. Use and 18"
long, plastic ZIP Tie, appropriately sized to fit in the hose connector tubing. Carefully insert the
Zip Tie or something similar (NO Wire coat hangers, though) into the hole and continue to push
it in until you reach a bend in the tubing. You will need to gingerly work it past this bend, until
the ZIP Tie either bottoms out or you run out of usable ZIP Tie. Then while rotating (Twisting) the
ZIP Tie slowly pull it out. As you reach the inserted end of the ZIP Tie, be prepared for some
water to follow.
That should solve the problem. Be sure the hose is no longer than 5 feet and that it slopes downward from the unit, with no kinks in it.
Hope this helped you solve the problem. Please let me know, Thanks.
Posted on Jun 27, 2011
SOURCE: My model is Frig. Dehumidifier,
Check the float valve in the top of the bucket. It may be stuck in the UP position. If that the case, jiggle the float valve arm to get it to return to the DOWN position. That should solve the problem.
Posted on Jul 10, 2011
Jul 17, 2014 | Frigidaire 50 Pint Capacity Dehumidifier
Jul 02, 2014 | Frigidaire FAD704DWD 70 Pint/Day Energy...
Jul 02, 2014 | Frigidaire a/c fad704dwd 70 pint...
Jun 25, 2014 | Frigidaire FAD704DUD 70 Pint Dehumidifier
Jul 16, 2013 | Frigidaire Fad704dud 50 Pt Pint Electronic...
Jul 10, 2011 | Frigidaire Dehumidifiers
There
Here
Dehumidifier
heatman101
Jan 17, 2011 | Whirlpool Gold AD70USS 70 Pint Per Day...
There
Here
Dehumidifier
heatman101
Oct 04, 2010 | Whirlpool Gold AD70USS 70 Pint Per Day...
May 04, 2010 | Frigidaire FDL60P1 Dehumidifier
Jul 16, 2009 | Whirlpool Gold AD70USS 70 Pint Per Day...
