Sc 995 aficio 2045 - Office Equipment & Supplies
SOURCE: ricoh copier aficio 401 error sc 419
How do i clear SC 548 error on aficio 1022 copier machine
Posted on Jul 09, 2008
SOURCE: Ricoh Aficio 2045 error code sc 502
sc 502 is the problem related to tray lift motor .open the backside of the machine ,almost downside u ll find one spring broken .replace tat the tray will start working.
Posted on Jan 21, 2009
SOURCE: sc code 672 with aficio 2090
Direct from the service manual:
• Controller board defective
• Controller board installed incorrectly
• Operation panel harness connection loose or incorrect
Posted on May 05, 2009
M2Tech1
  • 313 Answers
SOURCE: mpc 1500s sc 202 and af 1075 sc 995
are you sure the codes SC202 is ink related and you need to check the covers on the cartridges as the ink has run out...or the head is not recognising the cartridge..
the sc995 is due to a NVRAMM missmatch or failure.. the serial numbers are not recognised.. if you have replaced the controller board it is not correct or faulty. you can get a sd card and do SP5825 to download new details to the new NVRAMM
Posted on Jul 14, 2010
  • 62 Answers
SOURCE: I have Ricoh Aficio 2045. I am getting error as
change 40gb HDD - thanks
Posted on Dec 23, 2010
I have an sc 326 error code in my ricoh aficio 2045 copier
If you wish to get some details; check the site linked here. Pull up older posts....
Jun 19, 2016 | Ricoh Aficio 2045e 2035e Copier...
Sc 690
GAVD block i2c buss error
Mar 20, 2013 | Ricoh Aficio 2045e 2035e Copier...
kindly change the developer unit and clear the error.
the machine will respond
thank you and all the best
May 20, 2012 | Ricoh Aficio 2045e 2035e Copier...
Error code sc 322 for aficio ricoh 2045
this is a laser unit problem.check laser connections clean the laser unit.
Aug 08, 2011 | Ricoh Aficio 1035 Copier
Sc 322 for RICOH AFICIO 2045
That is a LASER error code.
It can be just toner dust because that error is a bad communication between the laser synchronization detector board and the LD unit.
Sometimes the dust of toner goes to the laser and causes this error.
Try to clean the laser unit. Maybe that work
Feb 24, 2011 | Ricoh Aficio 450 Copier
Sc990
sc 990 relates to the nv ram chip on the main board also check the values of the lazer unit are correct and not changed
Jun 16, 2010 | Ricoh Aficio 450 Copier
PROBLEM SC 995
Information Type 995 machine • Wrong
After switching on the machine, was detected with the controller card
mismatch CPM correct information sent by the Engine Controller.
Solution: Replace the controller card with the correct tab.
Jun 08, 2010 | Ricoh Aficio 3025P Black and White Copier
Sc 670 aficio 2045
Did you shift the machine recently? If yes check the connectors in the controller and other boards.
Or the boards are not installed correctly.
Worst case BICU board or controller board defective.
Mar 10, 2010 | Ricoh Aficio 1035 Copier
14 people viewed this question
k24674
