Question about Electrolux W4180N
Pls send service manual to ktthomas@technip.com
Washing machine W4180N had a "door lock" problem. Machine door did not open after the wash cycle was completed. Door controller was not sending operating voltage for enabling opening of the door. External voltage was provided for "door lock" operation. By doing so, door operation became normal but drum stopped going forward and reverse during "wash" cycle. Spin operation is normal. Service manual for this machine W4180N is not held on board.
FitzOriginal
  • 842 Answers
SOURCE: The door will not open on my Electrolux washing machine
How much trouble do you want to go to?
If you just want to preserve the washing, then simply put it on another cycle tonight and that will keep it fresh until the callout turns up to fix it.
The next clever step is to power the machine off at the mains for 10 minutes. Depriving it of power MAY release the interlock door switch even if the cycle didnt.
Final attempt to get to it... Turn off power, unplug at the mains. drag the machine out so you can see the back. Remove the 2 screws that hold the top on, pull back or tap the top forward (depending on the model) to unclip it. Peer inside. You will see the door switch inside the chassis exactly in line with the door handle on the outside. See if you manually make the mechanism release, or if you have a stubby philips screwdriver, you can probably unscrew the switch complely.
If you trust yourself NEVER to open the door in the middle of a cycle, the machine will of course function without a switch. Just so long as you recognise that you will flood the place if you do open it with water in. Also if you put your hand inside dirung a wash (Or worse still a spin) the power of the motor combined with the weight of the wet washing will rip the arm clean off a fully grown man, so if you doubt yourself or you have kids (or kids may visit) don't leave it like this.
Posted on Feb 09, 2009
  • 4 Answers
SOURCE: unusual display on panel (padlock) machine can't be programmed door is not locked however
i just went through the same thing.......you need to hold the option and extra rinse buttons simultaneously for 6 seconds, this will unlock it.....so turn the machine on and press the two icons, dont worry about the beeping and flashing after 6 seconds the padlock symbol will go and you can use the machine as usual.....i wish they put that 'minor detail' in the manual...cheers!!
Posted on Aug 19, 2009
SOURCE: cannot open the front door
I really did not fix the problem. I think the plastic linkage may have been broken and I was looking for a fixto open the door.
Thanks anyway,
Jim Charlesworth
Posted on Jan 11, 2010
SOURCE: I have an Electrolux EW 548 F Washing machine.
It sounds as if something has got stuck in the filter jamming the drain pump,try draining the water out either through the filter but beware of the amount of water.Or take the drain pipe at rear and try to drain iinto a container or through the nearest door to an outside drain.Once the water is out you should be able to open the door.Then you will have to find out if some object is stuck in the filter(located at bottom right hand side).
Posted on May 03, 2010
  • 174 Answers
SOURCE: Electrolux EWF1087. door locked shut. when i reset
sounds like door lock is faulty e42 is saying door is still open. could be wiring to door lock also.
Posted on Jul 20, 2010
My washer dryer was on baby cycle wash and although the green light has come on to indicate it has finished, red lock key is also on and I am unable to open the door.
Martha, Try running another cycle, for some reason I think machine is sensing it still has water in it. If after running another cycle dose'nt do it, check links below to see (2nd link) how to open door manually with out damaging machine. press the helpful button
How to fix washing machine door lock in Hotpoint washing machine
Opening locked washing machine door
Feb 10, 2016 | Hotpoint Aquarius WD640 Front Load...
My washing machine will not lock to wash i have replaced the locking mechanism assembly and the lock lid light just blinks and click near the computer board what els should i try please jelp
How to fix a washing machine door lock in a Hotpoint ...
? 4:21
https://www.youtube.com/watch?v=p14EEa4AYGM
Jun 4, 2010 - Uploaded by eSpares
For all your washing machine spare parts go to http://bit.ly/1828iPF In this video, ... How to fix a washing machine door lock in a Hotpoint washing machine ... How to open a washing machine door that won't open normally.
Door makes clicking noise and won't lock or start - Kenmore ...
https://www.ifixit.com/.../Door+makes+clicking+noise+and+won't+l...
iFixitOct 30, 2013 - Door or Lid Latch Assembly If the washer lid or door won't lock the lockand switch assembly might be defective. This is a very ... The Kenmore Elite HE3 is awashing machine by Kenmore. ... Preview my answer. Post my ...
washing machine wont work. the door will not lock to start ...
www.shopyourway.com > Manage My Life > Questions
Manage My Life. washing machine wont work. the door will not lock to start the cycle. all the lights still ... Kenmore HE3T front load washing machine will not start.
How to Fix Washer That Won't Start ' Washing Machine Repair
www.partselect.com/Repair/Washer/Will-Not-Start/
Read on to learn how easy it is to fix the washing machine yourself... ... found on front load washing machine is the door switch and the door lock and strike.
Jan 23, 2016 | Washing Machines
My front loader washing machine won't open-the lock symbol disappears but despite putting the machine through a variety of cycles I can't unlock it
How to open a washing machine door that won't ... - YouTube
? 3:57
https://www.youtube.com/watch?v=-65_eoT6zuk
Aug 22, 2013 - Uploaded by how-2-repair.com
Your washing machine door won't open this video will show you a technique ... to our channels social media as this really helpsmy site and keeps us going. ..... Front Load Washer Door Latch Troubleshooting Replacement ...
How to Open a Washing Machine Door that's Stuck Closed ...
? 1:30
https://www.youtube.com/watch?v=s-_x2tSmd0A
For all your washing machine spare parts go to http://bit.ly/1828iPF If your washing ... of thumps on the frontpanel next to the lock to see if this shocks it to release. ....impossible for ariston av51 washer, my arm cant go thru it...small space for ... How to open a washing machine door that won't open normally.
How to open a washing machine door that is stuck shut.
www.how-to-repair.com > ... > Door Locks & Switches
Jan 04, 2016 | Beko Washing Machines
My Electrolux washing machine W4180N has faul error 6 (e6), how to fix the problem
I'm not finding anything in my literature on that code. I would contact electrolux directly.
May 30, 2012 | Electrolux W4180N
Door won't open and is jammed.
We have an electronic Sears front load model with which that happened. . If this is a Sears machine contact the service number located in your manual and they should be able to talk you through it. For us it ended up being a door switch that had become misaligned. Make sure the machine spins the water out of the tub before you try to open the door if it is a front loader.
Apr 02, 2012 | Amana Washing Machines
May tag Neptune showing codes
Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
Do
Your Maytag Neptune washer displays the "do" help code when the washing machine is trying to start a cycle, but the door is open or not locked properly. If this message is displayed, close the door securely and restart the washing cycle.
FL
The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
Sd
The "Sd" code indicates that you have added too much detergent to the washing machine and your laundry has too many suds. The machine will stop displaying this code if it has successfully run the suds recovery cycle, which removes the excess suds from the wash load. If the code remains, reduce the amount of detergent in the load. Use less detergent for similar loads of laundry in the future.
PF
The "PF" code indicates that a power failure has occurred. Restart the wash cycle. If the code still appears, check that the washing machine is still plugged in to the electrical outlet.
Nd
The "nd" code indicates that your Maytag Neptune is not draining as it should. Check that the drain hose isn't kinked and that the stand pipe isn't clogged. If you find either of these problems, fix them before restarting the washing cycle.
LO
The "LO" code appears when the washing machine has finished the selected wash cycle, but cannot unlock the door. Verify that the door is closed properly, push the "Off" button, and wait two minutes. The door should unlock and the error code will disappear. If the error code remains, unplug the washing machine, wait two minutes and plug it back into the electrical outlet.
Lr
The "Lr" code indicates that the washing machine's motor is not running as it should. Have your Maytag Neptune washing machine serviced by a certified Maytag repair professional. Maytag Neptune Priority One Service: (888) 462-9824
NF
The "nF" code appears when the washing machine has tried to fill with water and has failed. Verify that the inlet hoses aren't kinked and that the faucets are fully open.
Od
The "od" code appears when you must open the washer door. The Maytag Neptune washer requires that you open the door between cycles.
Other Codes
* If your Maytag Neptune washing machine displays any codes that are not listed above, contact Maytag Neptune Priority One Service for assistance. Maytag Neptune Priority One Service: (888) 462-9824
Hope this helps (remember to rate and comment this answer).
Apr 03, 2011 | Maytag Dryers
If you get the FL how do you get the door to open??
  1. Your Maytag Neptune washing machine displays error codes, also called "help codes," to identify specific problems with your washer. Once you close your Maytag Neptune's door, the machine locks the door, goes through the selected wash cycles and unlocks the door when the laundry is finished. Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
  2. Do
  3. Your Maytag Neptune washer displays the "do" help code when the washing machine is trying to start a cycle, but the door is open or not locked properly. If this message is displayed, close the door securely and restart the washing cycle.
  4. FL
  5. The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
  6. Sd
  7. The "Sd" code indicates that you have added too much detergent to the washing machine and your laundry has too many suds. The machine will stop displaying this code if it has successfully run the suds recovery cycle, which removes the excess suds from the wash load. If the code remains, reduce the amount of detergent in the load. Use less detergent for similar loads of laundry in the future.
  8. PF
  9. The "PF" code indicates that a power failure has occurred. Restart the wash cycle. If the code still appears, check that the washing machine is still plugged in to the electrical outlet.
  10. Nd
  11. The "nd" code indicates that your Maytag Neptune is not draining as it should. Check that the drain hose isn't kinked and that the stand pipe isn't clogged. If you find either of these problems, fix them before restarting the washing cycle.
  12. LO
  13. The "LO" code appears when the washing machine has finished the selected wash cycle, but cannot unlock the door. Verify that the door is closed properly, push the "Off" button, and wait two minutes. The door should unlock and the error code will disappear. If the error code remains, unplug the washing machine, wait two minutes and plug it back into the electrical outlet.
  14. Lr
  15. The "Lr" code indicates that the washing machine's motor is not running as it should. Have your Maytag Neptune washing machine serviced by a certified Maytag repair professional.
Dec 06, 2010 | Maytag Neptune MAH5500B Front Load Washer
How to operate the washing machines front load washer brandt bf850
  • Open the front door and load the clothing into the washing machine. Check the owner's manual for the maximum load size. Overloading the washing machine may interfere with its ability to spin the clothes and rinse them clean.
  • Fill the detergent receptacle on the front of the washing machine, making sure not to fill it past the indicated line. Always use a liquid detergent that is designed for front-loading washing machines.
  • Add bleach or fabric softener, if needed. Most front-loading washing machines have a section for fabric softener inside the detergent receptacle. Check the instructions on the bleach to find out when it should be added to the washing machine.
  • Close the front door of the washing machine and make sure it locks into place. The machine usually will not turn on unless the door is securely locked.
  • Check the owner's manual to find out how to select the different options and wash cycles. As a general rule, use warm or cold water for most types of colored clothing. Hot water should only be used when washing white cotton items.
  • Start the front-loading washing machine and let it run through the entire wash, rinse and spin cycles before opening the door to unload the clothing.
  • Please rate this solution. Regards.
    Nov 04, 2010 | Brandt WFH1176 Front Load Washer
    Im having trouble with my maytag neptune tl washer it wont finish the spin cycle
    Please see the following Whirlpool / Maytag service manual for Neptune washers.
    https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/dc59d905140253e18525729c005765f4/$FILE/Maytag_Neptune_Washer.pdf
    On page 3-1 the manual explains that if the washer shuts off during the spin cycle, the problem points to a weak spring in the door lock mechanism.
    "Shuts OFF In The Middle Of The Spin Cycle:
    During the spin cycle, the machine control
    monitors the door lock mechanism to ensure
    the door is locked. This is done through the
    door lock enable switch. During "lock mode,"
    the shaft of the door lock mechanism is
    pressed forward by the door lock wax motor,
    and the shaft presses in the button of the door
    lock enable switch. If the machine control
    board sees the switch OPEN during the spin
    cycle, the machine control board will automatically
    shut the washer OFF. This is caused
    by a weak spring in the door lock wax motor.
    Replace the complete door lock mechanism.
    Oct 25, 2009 | Washing Machines
    Electrolux W4180N Logo
    Top Electrolux Washing Machines Experts
    Tim Whalen
    Dan Webster
    Dan Webster
    Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
