Question about Acer X193W LCD Monitor
How do I fix an acer X223W monitor with black screen and power blue light flashing
  • 8 Answers
SOURCE: Acer x223w - no option to goto 1680x1050
It would seem, somehow, your graphics driver was corrupted. The only thing to do is re-install graphics drivers. These can be found with a quick Google Search: CLICK ME
The first link, to DriversCollection.com, looks promising. This one is for Windows Vista or XP, but you need to specify on the tabs near the top of the page. Make sure you download the correct driver, as this page includes other drivers. You're looking for "Graphics Driver" [Vista] or "Video Driver" [XP].
Hope this works for you.
~Chris
Posted on Jun 11, 2009
  • 235 Answers
SOURCE: I just purchased a new cpu and plugged in my Acer
have youre cpu check if the monitor works on other computer, then the problem is in your cpu, if you hear any beeping sound a bad memory or vga could be posible, try removing it clean it and put it back, also if you have a vga card install clean it also then reboot, also check the power supply if it is working properly
Posted on Nov 20, 2009
budmrtn
  • 11361 Answers
SOURCE: Acer LCD monitor--> screen is black, light is
First thing to look will be bad caps with bulging/leaking caps in the power supply section, post back what you see insdie so we can guide you further, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Posted on Feb 23, 2010
budmrtn
  • 11361 Answers
SOURCE: acer v193w monitor screen is black, and an amber
The blinking Amber light can mean two things, one is that the monitor is not getting the video signal from your PC, or it can be problem in the monitor power supply due to bad caps. Please try it on another PC first before opening up the monitor. If is it the monitor then read below so you can make up your mind if you want to DIY or not.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Apr 15, 2010
budmrtn
  • 11361 Answers
SOURCE: Power button light flashes (blue flashing light)
You may have problem in the power supply section, that wil be the first place to check. Look for caps with bulging/leaking tops first.
Please see my photo albums so you will know what to look for.
Posted on May 19, 2010
I have a acer.x223w when,it powers up the.screem stays black, n i get a blue blinking light on.the bottom
I disagree with ikkenom only due to the symptom of the flashing blue light. This would indicate to me that the monitor is not getting any display signal and is in sleep mode at least the is what happens on my Samsung monitor. Used to be that they use a two color led in the monitor, green when ON and getting display signal and amber or orange when in sleep mode. I would check the computer by trying a different monitor. If you have a second monitor, great, if not, maybe a friend will let you bring your computer over and try the computer with their monitor. Could also be a display adapter setting. Do you get any change when you first turn on your computer? i.e. Do you get the BIOS or manufacturer screen when first turned on? Also if you disconnect the monitor cable from the computer and power cycle the monitor, do you get a No Signal display for a few seconds before the monitor goes black and the blue light starts flashing?
Let me know what happens with the testing above or if you need further instructions to carry out testing.
Thanks, Jim
Feb 21, 2013 | Computers & Internet
My Acer X223W auto-aligns my screen 2
I was having this exact same issue. I held down the 'e' button and let it re-auto config and it seemed to clear up the problem.
May 28, 2012 | Acer X223W Monitor
My acer x223w monitor goes black and the blue light stays on what could it be??
The backlight controller has failed. It can be repaired or replaced.
Feb 20, 2011 | Acer 22" X223w LCD Monitor
The screen went black while I was on the computer. Is there a fuse or a safety switch?
If you have no power on the monitor and the switch light does not come on, there is a fuse in the power supply section that is probably open.
Feb 14, 2011 | Acer X223W 22" Monitor
Suddenly my acer X223W lcd monitor goes blank and the light stays blue. I can barely see the images like in a 10% transparency filter. When I turn the lcd on everything is ok until the logon screen appears...
There is an "inverter" component inside the LCD monitor,
that creates all the "brightness" of the image.
That part is failing, and is becoming intermittent.
It's about a $20 part to replace, plus $50 for a qualified TV/computer technician to open the monitor, replace the part, and reassemble the monitor.
Jul 17, 2010 | Acer 22" X223w LCD Monitor
Blue light goes out yellow light stays on after computer is turn off
User manual: http://www.retrevo.com/support/Acer-X223W-Monitors-manual/id/23224ci553/t/2/
That is normal condition, yellow = no video signal from PC since PC is off or PC in standby mode.
Mar 24, 2010 | Acer 22" X223w LCD Monitor
My acer v223w lcd monitor screen when i pluged it to my computor the blue light on the monitor comes on then the acer name appears then it says no signal. what do i do then it goes to sleep
uninstall the driver from ur display in the device manager, u shud be able to do this thru safe mode. it seems the lcd driver is not compatible with thw m/bord
Oct 14, 2009 | Acer 22" X223w LCD Monitor
Acer X223W monito won;t wake up after sleep.
I have a dual monitor system, both are the x223w. Same problem but only on the second monitor. Backlight shuts off.On/off light stays blue. I have to turn off the monitor and turn it back on. I returned it and Acer could not find any problem so I got it back. No problem for awhile and now a few times over the past couple days. Not good...
Aug 10, 2009 | Acer 22" X223w LCD Monitor
1inch black line down right hand of screen
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Jan 15, 2008 | Computers & Internet
Acer X193W LCD Monitor Logo
47 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
