Sony PlayStation Portable  Console
Problem for Sony PlayStation Portable (PSP) Console
Psp "R" Button problem
By erickthug22 on Nov 04, 2007
My "R" button on my psp wont work, it's like stuck or something, when im playing a game like ape escape, the r button is to crouch and im always crouching cause of the r button.
Same Problem
May 13, 2009
-   The problem with mines is that the R button is not physically stuck but it "electronically" is stuck. For example: I'm playing GTA Liberty City Stores and the R button is used for aiming while on foot, and hand brakes while in vehicle. Please help! -   Guest
Mar 29, 2009
-   My PSP's R button is always on. If im playing a fighting game and R is Block my guy will always be blocking. (to exit games with this problem go to home then put hold on then off then the buttons will flash and you can select yes or no) -   Metal_vampir
Mar 09, 2009
-   the r butten won't work
-   Guest
Mar 08, 2009
-   my R-button is not working and is all ways actavatied so i cant do any thing on my games and when i try to leave the game the bit where it say's yes or no to leave is not flashing so i cant get off the game im playing, please help me all i want is my problem solved.-   Jordan Bood
Mar 08, 2009
-   my bloody psp R-button is not working and when i try and get off the game im playing the bit where it says yes or no to go to home again the bit is'nt flashing and i cant get off the game so that's what i think is causeing the R-button to not work and the R-button is always actavatied. please help me!!!-   Guest
Best Solution
posted on Nov 04, 2007
Very Helpful)
Cerfer39
Rank: Guru  Sony Expert
Rating: 87%, 1188 votes
Hi Erikthug22,
You will have to open up your PSP to get to the contacts of the R button.
  1. REmove the battery
  2. Remove 4 screws from battery compartment
  3. Remove 1 screw from front edge under the PSP logo.
  4. Remove 2 screws from back on opposite side of battery.
  5. Lift the faceplate from the edge above the LCD slightly.
  6. Lift the front faceplate edge under the Home/Start button.
  7. You need to be very protective of the little screw hole that is under the PSP logo of the Faceplate..
  8. Do not touch the LCD screen if you can help it. If you do use a lint free cloth and windex glas cleaner to remove fingerprints and lint. Same thing for faceplate window.
  9. REmove the R button
  10. lift the rubber pad/frame behind the R button straight up.
  11. Clean the back of the rubber piece with a Q-tip and Rubbing alcohol.
  12. Clean the contact pad that is behind the rubber pad/frame.
  13. Press the rubber/fram piece back into place carefully.
  14. Put your R button back on.
  15. Be sure your LCD sreen and inside of faceplate window are clean.
  16. Refit the faceplate.
  17. Reinstall screws.
Was this helpful?
Yes
No
17 people thought this was helpful
Solution #2
posted on Jan 06, 2008
Somewhat Helpful)
jay007
Rank: Apprentice
Rating: 66%, 13 votes
you can tap it kinda hard and it pops in back in to place but if you to hard your psp will break.
Was this helpful?
Yes
No
4 people thought this was helpful
Solution #3
posted on May 07, 2009
Somewhat Helpful)
firuki
Rank: Master
Rating: 77%, 79 votes
Try this link . . . www.sony.com/playstation3
To find your best solution.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #4
posted on Oct 30, 2008
Somewhat Helpful)
Texaslonghor
Rank: Apprentice
Rating: 81%, 4 votes
where is the best place to fix the "r" button on the psp.would it be expensive tp fix it.
Was this helpful?
Yes
No
Solution #5
posted on Oct 22, 2008
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
my psp had fallen of the table, and i had turned the psp on to see if it was okay, i was playing MPO and i found that my R button was pushed in...so i got on here to see for help, and i saw the comment for instructions on how to open the case and clean it out, i was about to do that, but luckly i kept reading, and saw comment number 7...i had done what he said, push the buttom up and down kinda hard, in a pattern, my R buttom worked normally again =D
Solution #6
posted on Sep 10, 2008
Somewhat Helpful)
crazynuts
Rank: Apprentice
Rating: 75%, 1 votes
This solution worked a treat.
Make sure that you are out of warrenty though, as you have to peel a label off in the battery bay that voids your warrenty.
Also, if you are finding sony a pain, just be persistent, and insistent.
When i got my brand new PSP, it had three dead pixels in the middle of the screen. I rang sony who told me that my $300 purchase was not faulty and that they were not responsible. Needless to say i kept pushing the point with the guy on the phone, and demanded to speak to his manager.
I then got the response i wanted and they sent me an email with a bar code which i took to australia post and 1 week later i had a new PSP.
Keep up the good fight and thanks for the help
Was this helpful?
Yes
No
Solution #7
posted on Aug 27, 2008
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
alright i just fixed my i was hitting the R button on my knee like 3 times it fixed it idk if it will go back ill post here if it does
Solution #8
posted on Aug 25, 2008
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Mine Does it to
Im thinking about taking it apart myself
Solution #9
posted on May 01, 2008
Somewhat Helpful)
roundo
Rank: Apprentice
The rubber is on a small metal frame that is held in place by a black tab. You slide the frame out from the tab and then lift up.
Was this helpful?
Yes
No
Solution #10
posted on Aug 15, 2008
Not Rated)
jamo9568
Rank: Apprentice
Rating: 0%, 0 votes
you have to push it harder and harder up and down in rythm up and down do this for about ten minites and it shoud work but if it doesent the problem isn't the same as myne....
thanks and goodluck
fixia team
Was this helpful?
Yes
No
Popular Solutions for Sony PlayStation Portable
Questions and Unsolved Problems for Sony PlayStation Portable
Do you recommend Sony PlayStation Portable (PSP) Console?
Answer
Answer
I just purchased a used PSP Play Station Portable and it came with no instructions or operator... (More)
Answer
game not loading 2004 model psp not used for over 2 years,charged up but wont load games or give... (More)
Answer
i downloaded music from pc to psp, i can't play the music because i must enable wma play back, but... (More)
Answer
I have a psp with 3.80 M33-5. I recently downloaded Assassin's creed and psp update 6.10. However,... (More)
36 Other Users Have The Same Problem - Continued
Comment by Joe2695, posted on Feb 28, 2009
where can i take my psp to get the r button fixed?
Comment by togano, posted on Jan 12, 2009
Me too!!!!!!!!! My L1 and R1 are jammed or sticking and every time i press them it feels like they are going to break and if you dont press them, they will be as hard as a rock. I NEED HELP FROM SOMEONE PLEASE HELP ME!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Comment by Guest, posted on Jan 10, 2009
i have exactly the same problem
Comment by Guest, posted on Jan 09, 2009
my r button doesnt wrk at all.
Comment by jsander42042, posted on Jan 02, 2009
r button is always in use
Comment by moh7777amd, posted on Dec 27, 2008
my r button it is stuck or some thing like that its like that i am pressing it repeatly and when it gets stuck the home button dooesnt work too please help
Comment by qwinlyn, posted on Dec 19, 2008
when i play gta and get in a car its in permanent drive by
Comment by Guest, posted on Oct 25, 2008
same im trying to play grand theft auto and i cant lock on to someone i want to shoot and for some reason when i push the hold button down and pop it back up it locks on and i cant unlock.
Comment by Guest, posted on Oct 22, 2008
i have the same problem, it happend to me when my psp fell of the table....all i did was what solution 7 said, i had pushed down and pulled up firmly, and it worked normally
Comment by Guest, posted on Oct 16, 2008
yeah im having a problem with my L and triangle button on my orignal psp please someone help me with how to fix it
Comment by simi_p, posted on Sep 19, 2008
same problem here when im playing midnight club and all my other games the handbrake keeps on locking, and my car won't move. I think it might be the sensors
Comment by Guest, posted on Sep 08, 2008
SAME PROBLEME BUTTON R IS FOR FIRE IN CALL OF DUTY SO I AM ALWAYS FIRING IT S STUCK
Comment by rockstar1869, posted on Sep 07, 2008
when im playing a game or navigating, when i press the R button, nothing happens, its like it doesnt respond
Comment by madamx089, posted on Aug 21, 2008
Hey... I've got d same problem here but its wid my L button!!! n If I give it 2 d ppl at Sony Shop how long will dey take 2 reapir it...?
Comment by vishito, posted on Aug 16, 2008
i have the exact same problem as aswin12345.
Comment by Guest, posted on Aug 16, 2008
Hey i am having a strange problem with my R button, its like i have am constanly pressing it but im not. Anyways, another strange thing is when i press "home" i cant move the cursor only if i hold and unhold it. Then i realized that my R button has switched to the hold button.
Comment by Guest, posted on Jul 18, 2008
I have the exact same problem, except its with my L button.
Comment by tiadonjay, posted on Jul 12, 2008
My "R" button on my PSP wont work. If Im playing a Sports game like NFL street 3 I can not Turbo. It is Weird
Comment by ashwin123456, posted on Jun 11, 2008
Hey everybody
my r button won't work but if i put my psp on hold and then put it back it does the same job a the r button
Comment by Guest, posted on May 26, 2008
lol worse for me, i play medal of honor, and R is to shoot
Comment by Guest, posted on May 18, 2008
Yeah I use the R button a lot (handbraking in GTA: LCS and VCS, crouching in Killzone: Liberation, and aiming in SOCOM: FTB1, 2 and Infected.
It's like the button isn't pressed in (as in jammed), but somehow (i.e. in KZ:L, I can't move sometimes as it says it's pressed, but it's not. Help, anyone?
Comment by hasseljake, posted on May 03, 2008
i'm tryin to play gta liberty city stories and the r button wont work it's like stuck
Comment by Guest, posted on Apr 24, 2008
the l button is stuck
Comment by Sky Esword, posted on Apr 19, 2008
That happend to me just that i can press it but the psp thinks its pressed.. O.o its kinda weird
Comment by Guest, posted on Apr 18, 2008
my psp is the same way
Comment by hfiuqhlhf, posted on Mar 22, 2008
i am having the same problem with my PSP. It acts as though the R button is always being held down which is really annoying as the function in the game which is associated with the R button is generally quite important.
Comment by Scorpius, posted on Mar 11, 2008
My R Button gets stuck occasionally and when i am playing a game, it thinks I am just pressing and holding the R Button when I am not; it gets stuck and malfunctions
Comment by Guest, posted on Mar 09, 2008
my r button wont work because it is stuck and when im playing a game i cant climb the cell or open the cells door.i het when i can do that.
Comment by zezima, posted on Dec 27, 2007
i put my psp in the car than when i took it out and wanted to play GTA the r button does not work is the a way to fix it with out paying and no remving parts f the psp
Comment by Guest, posted on Dec 13, 2007
my "R" button doesnt work at all. its not stuck, it just doesnt work.
Comment by hifi987, posted on Nov 25, 2007
i have the problem with the r button and also when i hit home i cant chose anything so i cant exit the game
Describe your Video Game Consoles problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Video Game... Experts
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
