Question about GPS
Steering Wheel Control motevo - GPS
MY LOW BEAM LIGHTS, BREAK LIGHTS AND RADIO SOUND CONTROL ON STEERING WHEEL, ALL STOPPED WOKING
Steering wheel radio controls and horn not working - Jeep Wrangler ...
www.wranglerforum.com/.../steering-wheel-radio-controls-and-horn-not...
Sep 22, 2014 - 12 posts - ‎6 authors
... 2Dr sport and my step/reset buttons, radio control and horn all stopped working. ... Also the lights behind the step/reset and cruise control went out, but the ... Soundslike a bad clock spring ribbon cable in the steering wheel. steering wheel buttons not working
Jun 14, 2012
Steering wheel audio controls
Mar 5, 2011
More results from www.wranglerforum.com
Nov 23, 2015 | Cars & Trucks
Whats the bluetooth pin code in motevo moltymedya car Motevo KF-NS1
the code will appear on your phone at the same time
Jun 11, 2015 | Cell Phones
Motevo gtv x3 touchscreen: I don't know how to set radio stations. Once I find a radio station I try to store it, but I don't have a clue how. Can someone explain it to me or tell me where I c
I just bought a used honda city that has this Motevo GTV-x3+ installed. I was successful in storing the channel using the remote. After I go into the radio section, I touch the "Scan" button on screen and once it pauses on a channel I like, I touch the "Scan" button again. This stops the tuner from moving on to the next channel. Next, using the remote I long press a number for example 1 and the channel is stored in the list on position 1.
Oct 22, 2012 | Motevo GTV-X3 - 6.2" Touchscreen...
My Motevo gps on my 2009gps honda accord won't
Either the software has been manhandled or the GPS does not have the maps for places you would be visiting lately.
Aug 26, 2012 | GPS
I have a 2002 Yukon Denali and I was wanted to know, how do u change the bulb in the steering wheel?
Steering Wheel Control Switch Assembly Replacement Removal Procedure
  1. Remove the steering wheel. Refer to Steering Wheel Replacement .
  2. Remove the horn switch from the steering wheel.
  3. Remove the steering wheel shroud retaining screws from the back of the steering wheel.
  4. Remove the steering wheel shroud from the steering wheel.
  5. Remove the steering wheel control switch mounting screws.
  6. Disconnect the steering wheel control switch (2) electrical connector (1).
  7. Remove the steering wheel control switch from the steering wheel.
Steering Wheel Replacement Tools Required J 1859-A Steering Wheel Puller
Removal Procedure
  1. Disable the supplemental inflatable restraint (SIR) system. Refer to Disabling the SIR System in SIR.
  2. Remove the inflator module. Refer to Inflatable Restraint Steering Wheel Module Replacement in SIR.
  3. Remove the horn switch. Refer to Horn Switch Replacement - On Vehicle .
  4. Make an alignment mark in order to note the relationship of the steering wheel to the steering shaft.
  5. Remove the steering wheel nut.
  6. Remove the steering wheel, using the J 1859-A .
Installation Procedure
Oct 04, 2010 | 1995 GMC Yukon
Buttons on steering wheel do not work
have your mechanic check you STEERING WHEEL control module its the unit the control the function on the steering that communicate with veh ecm
Aug 07, 2009 | 2000 Ford Windstar
93' mazda mpv , wiper control lever will not turn off wipers.
Study THe steering wheel look for Philips screw holes, that removes horn cover front, on back of steering wheel, once you take the front cover of the steering, do not loose any springs and screws, use the cars ashtray to collect parts, Looking at the front, You will see a NUT 22 mm or 19 mm grab a 1/2 pride bar with socket( with locked steering) anti clock wise loose nut and washer and remove them, after that tap steering wheel from back towards You with both hands at the same time, till wheel OFF, You will see the wiper control leveler and how to replace it
Jan 22, 2009 | 1990 Mazda MPV
Traction control light stays on
If you're not getting an OBD (on board diagnostic) code, and it is constantly flashing, then the system needs to be calibrated at the dealer. This occurs when you replace or disconnect/reconnect a component of the traction control system, i.e., the sensors (shared with the ABS system), to the steering wheel position sensor, or the yaw sensors, etc. If you have it calibrated and it comes back on, you've got a poor connection at one of the components. The prime suspect here is the clock spring in the steering wheel, aka "sliding contact" in the steering column behind the steering wheel. This provides power to everything in the steering wheel, inccluding the steering wheel position sensor. When this goes bad, it is tantamount to disconnecting and/or reconnecting the steering wheel position sensor. Fords are famous for sliding contact failure. Usually, you'll also have other issues with steering wheel components, such as the horn, cruise control, radio volume, air bag ("high resistence" OBD code), etc.
Sep 06, 2008 | 2005 Mercury Sable
GPS Logo
29 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
