Question about SMC TigerStack III SMC6824M 24 x 10/100Base-TX 2 x GBIC Ethernet Switch (SMC6824MFT)
Smc 6824m password reset
When I try to do the factory reset by typing ctrl u it asks for a password, how do i clear that so i can boot the factory config
Can't find the reset Password pin near the Battery
If you are prompted for the Windows password, this would mean that your Windows user name is password protected. This is separate from the BIOS password. Resetting the BIOS password on your computer will not reset your Windows password. If you are unable to recall your Windows password, or if you do not recall setting up one, try to leave it as blank and see if it works. If not, your other option is to restore your operating system through a previous restore point. **WARNING: Be sure to try to backup important files before you proceed as this can cause data to be lost.** Try to boot using your Windows Disc and perform a repair install or a full operating system reinstall. Another method is to use the factory restore option on your dell computer if it is still available. To do a factory restore, restart the computer and as soon as the Dell logo/screen shows up, hold down the CTRL key on the keyboard and press the F11 key a few times and release both keys. once you get to the screen where you can choose to restore to factory settings select Restore then press Enter. Let it go through the process and select FINISH once you get the message that it is completed .
Mar 16, 2015 | Dell Dimension 8250 PC Desktop
Password lost how do i reset pc to factory
Use the windows 7 reinstall disk that came with your computer...or return it to its owner and go buy yourself your own PC and stop stealing jk...
Dec 11, 2014 | Acer eMachines Black EL1352G-41w Desktop...
Macbook pro dark screen
Close the lid, attach an external monitor, reopen lid.
Your display should now show on that monitr. If it is, your display on the MacBook Pro may be bad. I would try resetting the PRAM and the SMC before going to an Apple store. The SMC controls the MacBook's power founcts (see below)
Resetting the PRAM may do the trick:
You reset the PRAM by rebooting a Mac and then immediately hold down the Command+Option+P+R keys, you will then hear the Mac reboot sound again, signifying your PRAM has been reset. You must hit the key combination before the grey screen appears otherwise it won't work.
you've tried rebooting, you've reset the PRAM, you've done it all, but your Mac is still behaving strangely. What next? In certain circumstances, resetting your Mac's System Management Controller (SMC) can be a solution. This is sometimes necessary to restore normal lower level system functionality to your Mac.
Here's how to reset the SMC on any type of Mac (and any version of OS X) and the type of problems that it may resolve.
When & Why Reset SMC on a Mac? Some Common Hardware Reasons
Typically it's power and hardware related issues that can be helped or resolved by resetting a Mac SMC, particularly if you're having these types of problems:
* Issues with your Mac's cooling fans and fan management: fans run constantly at high speed, fans run high despite low CPU usage and adequate ventilation, fans not working at all, etc
* Power management and battery problems: Mac isn't turning on, sleep isn't working, random shutdowns and reboots, battery isn't charging, Mac won't wake from sleep etc
* Light problems and improper lighting management: battery indicator lights aren't working, display backlighting isn't adjusting to ambient light changes, keyboard backlights not working, etc
* Video and external displays not working: display brightness functionality not working properly, target video mode isn't working properly, external display isn't working, etc
* General performance and functionality problems: abnormally sluggish behavior despite no CPU or disk usage, external ports not working, airport & bluetooth aren't showing up, external devices are not being found, etc
So now that you've concluded you need to reset your SMC (Note that the SMC is on Intel Mac's only), here's how to do it on MacBook's, MacBook Pro's, iMac's, Mac Mini's, and Mac Pro's. Notice that the reset instructions are different for MacBook and MacBook Pro's if you have an internal or detachable battery.
Reset SMC of a MacBook Air, MacBook Pro Retina, or MacBook Pro's with an internal non-removable battery
This is how to reset SMC on most modern Mac laptops:
Shutdown your MacBook Air / MacBook Pro
Connect the power adapter to your Mac
On the MacBook/Pro's keyboard, hold down the Shift+Control+Option keys and the Power button at the same time
Release all keys and the power button at the same time
Boot your Mac as usual
Here's the key sequence to hold down:
Reset the SMC of a MacBook Air or Retina MacBook Pro
Do keep in mind that by resetting the SMC you will lose power specific settings, like the time it takes to sleep a Mac and other customizations to power settings. No big deal, but if you have made many changes to your hardware behavior you will want to adjust stuff like sleep behavior again.
Reset SMC of an iMac, Mac Pro, Mac Mini
Resetting SMC is different for non-portable Macs:
Shut down your Mac
Disconnect the power cord
Press and hold the Mac's power button for 5 seconds
Release the button
Reattach the power cables and boot the Mac as usual
Reset the SMC of a MacBook or MacBook Pro's with detachable batteries
mac reset the smc Older MacBook laptops with a removable battery can reset SMC with the following approach:
Shutdown the MacBook/Pro and remove the battery
Disconnect the power adapter, hold the Power Key for 10 seconds
Release the power key and reconnect your battery and power adapter
Turn your Mac on
Let boot as usual
Hopefully that will clear up your problems, if not it might be worth a visit to the Apple Store or a certified repair center.
Happy New Year,
Kerry
Jan 12, 2014 | Apple Computers & Internet
Wespro n720 hanging at loading os image how to solve this problem
You don't state the OS but usually it is a damaged system file.
On XP you can try this: Boot computer and press Ctrl+Alt+Delete twice when you See Windows welcome screen / login screen. It`ll show classic login box. Now type "Administrator" (without quotes) in username field and leave password field blank, press Enter and you should be able to login Windows. Now you can reset your account password from "Control Panel -> User Accounts". On Win 7 or Vista: Ctrl+Alt+Delete won`t work, you have to use some windows password recovery software. I recommend Windows Password Reset Deluxe
Read more: How to reset wespro n720 mini laptop? - My wespro n720 is start but hang all feature is not working :: Ask Me Fast at
How to reset wespro n720 mini laptop My wespro n720 is start but hang all...
Mar 21, 2013 | Sylvania Computers & Internet
Forgotten password
If you can tell me what the Os do you use, it could be must better.
Boot computer and press Ctrl+Alt+Delete twice when you See Windows welcome screen / login screen. It'll show classic login box. Now type "Administrator" (without quotes) in username field and leave password field blank, press Enter and you should be able to login Windows.
On Win 7 or Vista:
Ctrl+Alt+Delete won't work, you have to use some windows password reset tool. I recommend Windows Password Reset.
Resource: http://www.windowspasswordreset.net
Jul 30, 2012 | Computers & Internet
How do i reset my laptop to factory settings
What OS are you having?
Reset windows password as following instruction :
On Win 7 or Vista:
Ctrl+Alt+Delete won't work, you have to use some windows password recovery software. I recommend Windows Password Reset .
Jun 23, 2012 | Computers & Internet
My apple macbook air shows a question mark when i turn it on
Shut down your Mac
Release the button
Turn your Mac on
Let boot as usual
Happy New Year,
Kerry
May 22, 2012 | Apple MacBook Air
My computer has been locked from the boot menu i put my password in or so i think it is and it will not accept password it tells me to enter password then press (ctrl and enter) to disable system lock not...
U can reset boot menu password through removing BIOS battery and than switch on the system it will clear or some boards are with jumpers u can check CMOS clear from 1 to 2 for clear 2 to 3.try it.
Sep 13, 2010 | Computers & Internet
How can I come back to the initial configuration of a Fas250?
Connect to the FAS250 console by using the provided serial cable.
Logon to the appliance using username 'root' and the root password.
Type the following exactly as shown:
priv set diag
halt -c factory
The filer will reboot and ask for a fresh setup the next time it boots.
This should only be done if you are sure you really want to reset the configuration! This should probably only be done if you know how to then proceed and re-configure the filer.
If you do not have the 'root' password try resetting it. You will have to reboot the filer and type "ctrl-c" when prompted to access the special maintenance boot menu. Then choose the option for resetting the root password.
Aug 25, 2010 | Network Appliance NetApp FAS250...
Computers & Internet Logo
88 people viewed this question
Top SMC Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
