Question about Skytex Skytab-s Series 9.7"" Tablet Pc With Windows 7
My sky tab turn on. the buttons on top blink red but the screen doesnt light up what could it be
How do I reset this tablet
Since model number you wrote is for kickstand I assume that you want to reset Galaxy tab 3
Please make sure you have backed up all of your important data and apps before performing a reset.
Turn your Galaxy Tab 3 off.
Press and hold the Volume Up, Power and Home buttons together until you see an Android lying on its back. This is the - stock recovery screen.
Use the volume keys to scroll down to Wipe Data/Factory Reset and use the Power button to confirm.
Scroll down to Yes, Delete All User Data and hit Power to confirm.
Back on the first screen, scroll down to Wipe Cache Partition and select with power button.
Hit Reboot System Now to restart your Galaxy Tab 3 with factory settings restored.
Oct 15, 2016 | Tablets & eReaders
How do I connect irulu usb keyboard to my Visual Land Prestige Elite 7q tablet?
Make sure the tablet and keyboard are charged.
On the tablet, go to setting - it looks like a gear icon. Open settings and about the 3rd item down from the top of the drop down menu, you will see "Bluetooth." Make sure it is set to "ON"
Then go to the keyboard. It also has an "ON" button and press the botton. A tiny red light will blink slowly close to the button. There is a second "Connect" that must also be pushed - it is the "Connect" button and it will search for the Bluetooth signal from the tablet.
When it finds te tablet signal, you will see a message on the tablet screen [it must e turned on} instructing you to enter a 5 or 6 digit code on the keyboard. When you enter the code, a "Connected" signal will show on the screen.
Open a document and start typing!
I'm pretty sure this pertains to all tablets and keyboards.
Feb 12, 2016 | Tablets & eReaders
Last night my galaxy tab 3, 10.1 started making a consistent bell ring sound. I was not using it at the time. I picked it up and the screen was blinking and changing colour from normal to black...
Probably because you don't normally turn it off.
It got confused.
I turn my phone off about once a week - it gradually loses battery longevity because of whatever processes started running.
Feb 14, 2015 | Samsung Galaxy Tab 3 16GB 10.1-Inch White...
Blank screen with Apple logo
You could try to reset the iPad. Press the home button and the on / off button together and hold them till the light goes out.about 5 seconds. Then the apple logo comes back and in within one minute the starts screen should reappear.
I hope it works, because I would hate it if your grandson had to turn over his piggy bank. (Joking)
Jul 15, 2014 | Apple iPad 2
The video app is not turning off, not recordingor allowing me to pull up pic's I've taken. On top of that the On/Off button doesn't work either. That's right, the iPad can't be turned off so the video...
It doesn't need to be turned off. try double tapping the home button. The bottom of screen should show the apps that are running, now depending on your version of iOS, (I know of 2 methods)
1. touch the app until red minus sign appears and touch the red circled minus sign for the recording app you want to close. and....
2. slide the app window above the app icon up so it disappears off the screen.
Jun 01, 2014 | Tablets & eReaders
It won't turn on
Let's try to hard reset your device, not sure if this will work on both models (2012 and 2013). What you are going to read next is a C/P, best of luck.
Hard Reset or Wipe via Menu
If your device is completely unresponsive, you still have one additional option.
1. Press the power button and both volume keys for several seconds. The computer screen will eventually blink off. Continue to hold until you see the Android recovery logo and the large Start selection at the top of the screen.
If you are forced or desire to factory reset and wipe the device, select Recovery Mode. Your device will reboot. This reboot will be much slower than normal.
2. When you see the Android with red triangle, hold the power button down and press the volume up key until the wipe data/factory reset option appears. Press the power button to select it. Remember that this will erase all the data on your device.
3. With the volume keys select Yes - erase all user data and again press the power button to select this option.
Mar 12, 2014 | ASUS Google Nexus 7
My tablet wont turn on it continues to blink but wont turn on
Try using a paperclip to reset it on the back, hold it in for 5 seconds, if that doesnt work:
Turn the tablet all the way off, press and hold the VOL - and power at the same time for 8 to 9 seconds, it will show a green android guy with a system recovery menu. Use vol - to go down to Wipe Data/Factory Reset, press the power button to select it, go down to 'yes' to confirm, press the power button to select it, it will wipe the tablet, you then press the power button on 'reboot system'.
Apr 20, 2013 | Coby kyros Tablets & eReaders
Galaxy tab 10.1 frozen
Remove the battery and memory card, wait 60 seconds for the processor to reset, and power up.
Jul 11, 2012 | Samsung Galaxy Tab 2
Blackberry tablet wont power on
this happened to me, it needs charging, make sure the blackberry symbol on the lead is facing up, putting it in upside down moves the little tab inside the housing stopping you from charging properly, if it is a bit loose realign the tab with a thin nail file carefully just a touch then push the lead in symbol side up and switch on give it time it should charge..
May 04, 2012 | RIM Blackberry Playbook 7Inch Tablet...
My SGT is brand new, only a week old and it has aldready crashed. I can't access it at all, the screen lock won't react and it's been hung up like that for over an hour now. I was listening to...
First put the charger plug in the Tab, I just tried mine that was sitting on the desk, even though I held the power on button for a long time it would not start. I pluged the charger in so the red charging light is on Tried to start and it worked perfectly. i.e. the voltage level is very critical, if it is a fraction low it won't start.
Jun 09, 2011 | Samsung Galaxy Tab Tablet PC
Skytex Skytab-s Series 9.7"" Tablet Pc With Windows 7 Logo
24 people viewed this question
Top Skytex Tablets & eReaders Experts
Are you a Skytex Tablet and eReader Expert? Answer questions, earn points and help others
