Question about Pride Mobility Products Jazzy Select
I need a charger for a jazzy select 14 series
I need to get a charger for the Jazzy Select and Jazzy14Xl
  • MobilityRepairSpecialist
    Contact your local pride tech. This is usually a stock item in my inventory and I would think it is the same for your local tech. If you don't know of a local tech you can call pride and they can provide contact info 1-800-800-8586
  • Pride Mobili... Master
  • 10,291 Answers
Look in the phone book for a mobility service company near you. Stuccu com Best Deals on jazzy wheelchair charger Up To 70 off or go here for one.
Posted on Oct 01, 2016
2 Suggested Answers
  • 175 Answers
SOURCE: have jazzy select series need to know flashing Code #9
Consult your owners manual for the flash code guide. I believe that you probably have a PG Drives Joysitck/Controller, in which case a 9 code would indicate problem with the brake system. Check the free-wheel levers by placing them in the neutral position, and then firmly placing them back in drive. Try to restart. If still flashing, you need to remove the seat and the shroud and examine the connections inside the base of the chair. The brakes are at the end of the motor, and there are thin wires coming from them back to the controller box. Inspect these wires for any damage, and follow them back to make sure any connections on the way are tight, and that the connections for all clip connections are tight.
The brake is electrically operated by a solenoid. If the solenoid has gone bad, then this will also cause a fault code. Contact your dealer for servicing this part. Good Luck.
Posted on Jul 09, 2009
How do you lower the seat on a jazzy select power chair?
See the links
[PDF]Jazzy Select Series - Pride Mobility
https://www.pridemobility.com/pdf/owners_manuals/...jazzy/us_select_series_om.pdf
Jazzy Select 6 with Power Seat. JAZZY. SELECT SERIES. Including Models: ... setup of this power chair and must perform all of the procedures in this manual. .... Use only AGM or Gel-Cell batteries to reduce the risk of leakage or explosive.
https://www.pridemobility.com/pdf/owners_manuals/us_jazzy/us_select_om.pdf Reduce your power chair's speed when driving on uneven terrain and/or soft .... The Jazzy Select Series Power Chair has two main assemblies: the seat ...
Comfort Adjustments; Seat Height Adjustment - Pride Mobility Jazzy ...
https://www.manualslib.com > ... > Scooter > Jazzy Select gt > Owner's manual Pride Mobility Jazzy Select Gt Manual Online: Comfort Adjustments, Seat Height Adjustment. ... power chair and made any necessary adjustments to suit your specific requirements. ... Raise or lower the seat post to the desired position. 9.
Jun 04, 2018 | Select Health & Beauty
What batteries do I need for a jazzy select6 pride
information and batteries for sale.
info
Jazzy Select 6 - Specifications, Owner's Manual, Features & Benefits
www.pridemobility.com > Jazzy Power Chairs > Models
  1. Cached
  2. Similar
In-line motor technology for increased efficiency, torque and range. Built with ease of service in mind. Easy side access batteries. Tool-less front panel access to ...
www.pridemobility.com/pdf/owners_manuals/us_jazzy/us_select_series_om.pdf
  1. Cached
  2. Similar
6 www.pridemobility.com. Jazzy Select Series. II. SAFETY. Do not connect an extension cord to the AC/DC converter or the battery charger. Removal of ... Batteries for Sale
Pride Mobility Jazzy Select 6 Ultra Wheelchair and Mobility Batteries at ...
https://www.batteriesplus.com > Batteries > Wheelchair and Mobility > Pride Mobility
  1. Cached
  2. Similar
If you rely on a Pride Mobility Jazzy Select 6 Ultra powered wheelchair or personal mobility scooter to get around, Batteries Plus Bulbs can help you find the ...
Pride Jazzy Select 6 Power Chair from Pride Mobility ' 1800wheelchair ...
www.1800wheelchair.ca > Brand Showcase > Pride Mobility > Pride Powerchairs
  1. Cached
The Jazzy Select 6 Power Wheelchair from Pride Mobility is the ultimate ... Easy side access batteries; Full-length, flip-up armrests; Solid flat-free tires; Foot ...
24V 3Amp Jazzy Select 6 Ultra Scooter Battery Charger: Amazon.ca ...
https://www.amazon.ca/Jazzy-Select-Scooter-Battery-Charger/dp/B00CIZ1GW6
  1. Cached
24V 3Amp Jazzy Select 6 Ultra Scooter Battery Charger: Amazon.ca: Sports & Outdoors.
Pride Mobility Jazzy Select 6 12V 35Ah Wheelchair Battery
https://www.amazon.com/Mobility-Jazzy-Select-Wheelchair-Battery/dp/B009DKGCC8
  1. Cached
Rating: 5 - ‎1 review Buy Pride Mobility Jazzy Select 6 12V 35Ah Wheelchair Battery - This is an AJC Brand® Replacement on Amazon.com ? FREE SHIPPING on qualified orders.
ALL THE INFO HERE BELOW
Google
Nov 24, 2016 | Pride Health & Beauty
My chair is blinking 4 times and I do not have a manual
If it is a Pride Jazzy or similar, the Diagnostic Flash Codes are in this PDF file.
PDF]INFINFB2048_Jazzy_Select_14_Troubleshooting ... - Pride Mobility www.pridemobility.com/download.php?f=troubleshooting/INFINFB2048_Jazzy...
  1. Cached
  2. Similar
basic troubleshooting instructions for the Jazzy Select 14/14XL power chairs. ... on my Jazzy Select 14/14XL seem to be "dead" (controller does not light up when .... What if the left red battery condition meter LED on the VR2 or VSI is flashing? chair is blinking 4 times Google Search
Nov 15, 2016 | Health & Beauty
How to stop squeaky wheels
My tires squeak how can i fix the problem and what ... - Fixya
www.fixya.com > ... > Pride > Jazzy Select 6 Indoor Power Wheelchair
Apr 14, 2012 - my tires squeak how can i fix the problem and what can i use - PrideJazzy ... Question about Pride Jazzy Select 6 Indoor Power Wheelchair ... I have a mpv 5 hoveround wheel chair and I now have a flat on the front left tire.
[PDF]Jazzy Select Series Owners Manual - Pride Mobility Products
www.pridemobility.com/...jazzy/us_select_series_om.pdf
Pride MobilityJazzy Select 6 with Power Seat. JAZZY. SELECT SERIES. Including Models: Jazzy Select, Jazzy Select 6, and .... Battery charger for indoor use only. .... Take wide swings with your power chair's front wheels around any tight corners. ... desired, allow it to come to a complete stop by releasing the joystick, then push the ...
[PDF]Jazzy Select Series - Pride Mobility Products
Dec 28, 2015 | Pride Jazzy Select 6 Indoor Power...
What will replacebattery charger 2904jt24
Hi IF U GO TO E/BAY THERE IS A SCHAUER PARTNo JAC0724 charger suitable for pride jazzy select 6 COST US $139 GOOD LUCK
May 12, 2014 | Pride Mobility Products Jazzy Select 6...
My jazzy select 14 on the controler near the joystick lights up what looks like a yellow wrench in a 9 flash. Lights 9 times stops then lights nine more times over and over . please help
well a wrench means the obvious that something needs adjusting , if it came with an instruction manual search for the code 9 blinks will mean.
Oct 16, 2010 | Pride Mobility Products Jazzy Select 14
Jazzy Select 6 Indoor Power Wheelchair: Hi! I just inherited a used Pride Mobility Ja...
There should be a place to plug the charger in on the front of the joystick. It is a round three pin connector
May 17, 2010 | Pride Jazzy Select 6 Indoor Power...
Jazzy select 14 won't charged - have replaced batteries
At a minimum your batteries need to be charged for 12 hrs a day for the first month if not they will not build the capacity and will dwindle and die for example it is at only 25% capacity it says it fully charged but will die quickly this happens because it is charged to its full capacity but that is only 25% of the batteries true potential resulting in short battery life. Also the new batteries need to be charged before they are put on your jazzy. Then its a matter of if not in use put on charge. I think you need to have a word with your dealer.
Oct 06, 2009 | Pride Mobility Products Jazzy Select 14
Pride Jazzy Select batteries not charging
If you use an automotive charger you have to charge each battery individually as they should be 12vdc hooked in series.
Clean contacts and assure yourself that each lead is charging properly. Jazzy has many different models so it impossible to know which you have. But there should be some info on the charger to tell you if your output is 24v or 2-12volt DC leads.
Jazzy has a web site and there is a member section where you can ask questions.
May 16, 2009 | Pride Mobility Products Jazzy Select
Pride Mobility Products Jazzy Select Logo
140 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Robin Hill
Robin Hill
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
