Question about Amana ARGS7650SS Gas Kitchen Range
Digital display is flashing F 5 and won't turn off
Had to unplug range to stop
  • 132 Answers
Maybe you need to replace the electronic range control
Posted on Jun 22, 2009
I'm getting the same message on display and I realize that the ceramic "ignitor" in oven is out and needs to be replaced. Is your oven heating up?
Posted on Jul 27, 2009
Electric blanket flashing f won't stop sunbeam
Hello vinrocof - Please try resetting the unit by either unplugging it or flipping the breaker off. Wait approximately ten minutes and turn the unit back on. Try setting the time and if it proves to be ineffective, the unit may possibly have a faulty EOC, defective wiring harness or damaged cord. I would suggest contacting a professional to move forward accurately.
Jan 13, 2013 | Frigidaire FEF336BC Electric Kitchen Range
Frigidaire oven won't work. top range works fine, but digital clock and digital display stopped working which works oven, so oven also will not work f11 code
Hello steve o - Typically error code F11 indicates a shorted keypad. Try resetting the range by unplugging it or flipping the household circuit breaker off. This usually will clear most false error codes. Wait approximately ten minutes and if the error code does not clear contact a professional to move forward accurately. Most likely the EOC on the range will need replacing.
Nov 12, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
How to set time on timex 1440 sports watch
Welcome to FixYa!
Here's your request.
TIME AND DATE 1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash. 2. Press ADJUST to set SECONDS to zero. 3. Press START/STOP to select MINUTES. 4. Press ADJUST to change. 5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM. 6. Press MODE when done. 7. To display DATE from Time display , press START/STOP. 8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE. 9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
ALARM AND HOURLY CHIME 1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash. 2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM. 3. Press START/STOP to select MINUTES. 4. Press ADJUST to change.. Press MODE when done. 5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
CHRONOGRAPH 1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes. 2. With time displayed, press MODE to select Chrono Mode. 3. Press START/STOP to start. 4. Press ADJUST to view lap time. Press again to sesume lap timing. 5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero. 6. Repeat for successive laps.
Thank you for using FixYa! Have a great day.
Jas247
May 06, 2011 | Timex Watches
My oven was set to self clean. It got extremely hot and the it began beeping and flashing F1. I turned the circuit off, because I wasn't sure if it meant "Fire". So is it ok to turn the circuit...
Frigidaire's slide-in ovens feature an electronic oven controller, which serves to monitor and diagnose most electrical problems within the oven. If any of the oven's electrical systems fail, the controller will prevent the oven from functioning and will display a flashing "F" code on the oven's digital display and produce a beeping sound. To stop the beeping and clear the display, press the "STOP/CLEAR" button on the oven's control panel. Many times, the problem can be remedied by simply resetting the oven's controls. First, turn all of the oven's control knobs to the "Off" position, then allow the oven to cool to room temperature. If, after turning the oven on again, the "F" code still displays on the digital display, contact Frigidaire, as the wiring is likely to be defective.
Dec 06, 2010 | Frigidaire FEF352 Electric Kitchen Range
The machine won`t wash and the letters LD are appearing in the timer slot ?
Hello there:
Ld Long Drain Ld flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets.
Press STOP/CANCEL to clear the display. unplug the POWER cord .or turn off the maching for 10 min and retry if this stil does not help check each of these things i have mentioned below and replace or repair as needed
· Check wiring harness
· Check pump motor
· Check circuit board
Sep 26, 2010 | Washing Machines
How to set the oven timer?
To Program Oven for a Delayed Start Time and to Shut-Off Automatically 1. Be sure that the clock shows the correct time of day. 2. Place the food in the oven. 3. Push "Bake Time". "00:00" and the words "BAKE TIME" will glow in the display window. 4. Push and hold up or down arrows until the desired baking time appears in the display. 5. After the bake time has been set, "----°" will appear in the display and the word "BAKE" will flash. The display will flash and beep once until the oven temperature has been set. 6. Push "Stop time". The time when baking will stop, will appear in the display window. The words "BAKE STOP TIME" will glow in the display. 7. Push and hold up or down arrows until the time that you want cooking to be completed appears in the display. 8. Push Bake (or Conv). "---°" will appear, and the word "BAKE" will glow in the display. 9. Push and hold up or down arrows until the desired baking temperature appears in the display. 10. If the baking temperature is not set, the control will beep. "---°" will flash and the word "BAKE" will appear in the display.
Mar 11, 2009 | Electrolux Kitchen Ranges
Need instructions for Timex 1440 Sport watch
TIME AND DATE
CHRONOGRAPH
Nov 22, 2008 | Timex 1440 Nylon watch
I need help with my frigidaire self cleaning confection range it is flashing F1
Hello traden,
Welcome,
You said, What do I do to get my range to stop beeping and flashing F1
Please send me your complete model number including that number at the end of the model number.
pull open the storage drawer and you will find a sticker down low on one side.
Mean while you may try unplugging the range for 5 minutes and that should reset the system if it is only a glitch!
Waiting for your Complete Model number.
Huuum
Oct 09, 2008 | Frigidaire FEF366 Electric Kitchen Range
Oven stopped 5 to 10 minutes after pressing START
sounds like a wiring problem check your power source
Nov 29, 2007 | Whirlpool RF262LXS Kitchen Range
Amana ARGS7650SS Gas Kitchen Range Logo
111 people viewed this question
Top Amana Kitchen Ranges Experts
Sal De
Ismael Rodriguez...
Oloyede Monsuru
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
