Question about Dometic Rooftop RV Air Conditioner
Where is switch for ac located - Dometic Rooftop RV Air Conditioner
    Genius:
  • Dometic Master
  • 1,363 Answers
Other then breaker and fuses the only switch is your thermostat.
Posted on Aug 17, 2015
Location of the Ac low pressure switch 2007 Mkz
The low pressure switch (also known as the AC compressor switch) will be under the hood, it will be located in the low side AC line from the AC compressor, this is the larger of the two lines from the AC compressor. See picture below, looks like it has a three wire connector. Also what is the AC doing that makes you think this switch is defective? Cycling on and off constantly?
Jun 26, 2016 | 2007 Lincoln MKZ
07 Chevy Aveo, location of AC Low Pressure Switch
LOCATE THE LOW PRESSURE LINE AND FOLLOW IT, THEY ARE GENERALLY NEAR THE FIREWALL AREA, IF THAT DOESNT WORK, TRY A STANDARD HELMS REPAIR MANUAL, AS IT SHOULD BE LISTED THERE. WORST CASE SENERIO, JUST CALL THE DEALERS SEVICE DEPT. AND THEY SHOULD TELL U WHERE ITS LOCATED AT, AS IT HAS WORKED FOR ME IN THRE PAST.
Jul 01, 2012 | Cars & Trucks
My ac does not have power to clutch. I changed compressor and the ac switch where is the relay switch on 1987 nissan pick up
The A/C Compressor relay is located on the firewall, there should be a couple of relays in this location. I have added a diagram which should assist you in locating this relay.
Hope this helps...
Sep 20, 2011 | 1987 Nissan Pickup
Location of ac high pressure cutout switch on a 97 Plymouth voyager. Could it be a different problem? Had to replaced the PCM and a couple sensors because of a short in the wiring cluster. Now the ac...
HIGH PRESSURE CUTOFF SWITCH LOCATED ON AC COMPRESSOR DISCHARGE LINE LEADING TO THE CONDENSOR.THE HIGH PRESSURE CUTOFF SWITCH WILL CUT OFF THE AC COMPRESSOR IF SYSTEM PRESSURE RISES TO HIGH CAUSED BY RESTRICTION IN THE REFRIGERANT CIRCUIT OR OVERHEATED CONDENSOR.MAKE SURE COOLING FAN IS RUNNING WHEN THE AC SWITCH IS ON.THE COOLING FAN KEEP CONDENSOR COOL, IF COOLING FAN DONT RUN.YOUR AC WILL STOP BLOWING COLD AIR.HAVE THE REFRIGERANT SYSTEM CHECK OUT.MAKE SURE YOUR LOW SIDE PRESSURE IS 10 - 37 PSI. THE HIGH SIDE PRESSURE SHOULD BE 112 - 210 PSI. CHECK THE AC COMPRESSOR CLUTCH FUSE AND RELAY.
Jul 29, 2011 | Plymouth Voyager Cars & Trucks
Air conditioner suddenly not working.. No funny noise, just acts like it is not getting power. compressor kicks on and off checked relays behind glove compartment. Was told ac relay may not located with...
AC COMPRESSOR KICKING OFF AND ON.SOUND LIKE REFRIGERANT LOW.LOW SIDE SHOULD BE 20 - 36 PSI AND HIGH SIDE SHOULD BE 215 - 310 PSI. AC SYSTEM COULD HAVE A LEAK WHILE YOUR COOLING STOPPED. DRIVER SIDE WINDOW MOST TIME SWITCH WILL BE THE PROBLEM.REMOVE SWITCH SEE IF POWER GOING TO POWER WINDOW MOTOR.YOU HEAR WINDOW MOTOR TRYING TO WORK WHILE USING SWITCH.WINDOW REGULATOR COULD BE BINDING DAMAGED OR NEED LUBRICATING.OR MOTOR NEED REPLACED.IF POWER NOT GOING TO POWER WINDOW MOTOR THE CONTROL SWITCH IS BAD IF ITS THE ONLY SWITCH.TO TELL IF WINDOW SWITCH IS BAD SHAKE POWER WINDOW SWITCH WIRES WHILE OPERATING CONTROL SWITCH.IF POWER WINDOW WORKS YOU KNOW SWITCH IS BAD.TAKE CAR TO AC SHOP BECAUSE LET THEM CHECK AC SYSTEM BECAUSE IF YOU BUY 2 CANS OF R134 REFRIGERANT. AND YOU TRY CHARGING AC SYSTEM YOUR SELF AND ALL REFRIGERANT LEAKS OUT. YOU GOING TO BE OUT OF $30.00 STILL NO AC.THAT WHY ITS BEST TO LET SHOP PUMP DOWN AC SYSTEM CHECK FOR LEAKS BEFORE RECHARGING AC SYSTEM.
Jun 26, 2011 | 2000 Acura TL
Where are all the ac switches and relays located
Check the low pressure switch,it is on the dryer or on the low side line,the large ac line,this can be the problem,try jumping the two wires that are plugged into the switch.If the freon is low,or out,this switch will not allow the ac compressor to come on.
Jun 21, 2010 | 1997 Chevrolet S-10 Pickup
Does a 1986 Ford f-250 have across over switch between fuel tanks and if so where is it?
It should be located near the ac controls. I have an 86 F-150 with dual tanks, and my tank selector switch is in the ac control panel near the glove box. If it is not located in the ac control panel, then it should be located in the dash near the door.
Jun 16, 2010 | 1986 Ford F 250
2001 ford ranger 2.3L the ac clutch does not get voltage
BUY A HAYNES REPAIR MANUAL.IT HAS THE AC + HEATING ELECTRICAL DIAGRAMS ALSO SHOW YOU FUSE LOCATION.BUT IF FUSE CHECK OUT GOOD.PROBLEM COULD BE AC + HEATER CONTROL SWITCH BAD.OR AC CLUTCH CYCLING PRESSURE SWITCH IS BAD.
Apr 14, 2010 | 2001 Chevrolet Silverado
Dometic Rooftop RV Air Conditioner Logo
32 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Dan Webster
Dan Webster
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
