Question about Dell CD-ROM DRIVE 8X 7G828 DVD Drive
Disk storage medium stuck in DVD-Rom.
Have side door panel open(2350 Dell Demension), can't find what is attached to the DVD Rom to remove it.
  • nilo818 Jun 23, 2009
    You are the man.
    Scholar:
  • 109 Answers
If there is a disc stuck in the drive, removing the drive from the case is not necessary. Just take a paperclip and stick it in the manual release hole in the front of the drive.
Posted on Jun 23, 2009
Dvd eject slot not working on dell optiplex gx620 desktopcomputer
Start Menu, Computer, right click DVD rom, scroll down, click eject. If the DVD in the DVD rom is broken,damaged, remove Drive, disassemble. Try to open the front panel DVD rom door and push the button on the DVD rom drive.
Dec 30, 2012 | Computers & Internet
Need graphics driver for dell demension 2350
http://dell.driversdown.com/dell-drivers-list/s_613_1.shtml and scroll down to the list.
Jul 27, 2012 | Dell Dimension 2350 PC Desktop
CD in stuck in the computer and I can't get it out using the eject button. How do I get it to come out?
hi,
its too simple. you dont need to worry.. Check the front side of the CD ROM. you will find there one small hole. Now just take a thing, which is around the 4 to 6 inch (min is 4") long and can pass through that hole (for eg. take medium size U pin, and remove all bends and make it straight or long needle) Now insert this equipment in that hole and press. your ROM will eject...
Hope this has helped you ... Thanks....
Jul 19, 2010 | Computers & Internet
Dell demension 3100 dvd plays any disk ok but will not burn
when you try to save or burn any data to disk, you should use burning programs just like nero or any other burning program. at the time when you click the button burn, it always ask you to insert disk such as CD/DVD +R or RW
Mar 25, 2010 | Dell Dimension 3100 PC Desktop
My CD & DVD ROM drives will not open the door so I can insert a disk. The disk that is in the CD ROM that I can't get back out will play but the DVD ROM will not play anything at all.
Hello and Welcome to FixYa!
Your DVD rom tray may be stuck inside. Try the emergency eject by inserting a paper clip in the small hole at the front.
Regards,
Waqar
Dec 24, 2009 | Dell XPS 400 PC Desktop
Install dvd rom and remove one of the cd rom's
hi! replacing cd room,open your cpu cover by two quick lock bolt at back side of your pc right side,show on figure w/ arrow where the quick lock bolt.c1c13bc.gifthen pull out cover and you'll cd rack inside your cpu as shown on figureba392e9.jpg release 2 lock screw,and pull out i.d.e cable on cd room terminal also the audio cable next to leftside if have one,next the front cover of cpu thats locking your cd room theres a cliff lock on side opposit of the fron cover lift it by flat screw driver slowly and careful it might broke,after cover was detouched,don't remove any wire connection on front cover,pull out your cd room replace by dvd rom and connect all what has been disconnect on cd room put back front cover,and connect pwer,audio and ide cable again then try to switch on your dvd rom is a plug and play you can install your dvd installer and follow wizard instruction and click finish...regards
Mar 27, 2009 | Dell Dimension 2350 PC Desktop
Dvd keeps kicking out of the CD ROM when tring to copy.
Hi ,
The dell desktop demension 2350 that you are using does not have a dvd burner. Hence when ever you are putting the dvd burner it throws it out. Please instert a cd and you would see that it does not behave the same.
Hope this resolves your question .
Please donot forget to rate .
Mar 25, 2009 | Roxio Easy CD & DVD Burning
I have a Dell Demension 2350 tower stuck in DOS safe mode.
restart the system by pressing the power button for 5 to 7 sec and hit the del button to enter the setup and load default setup and run an dell diagonastics
Nov 21, 2008 | Dell Dimension 2400 PC Desktop
CD rom
hi
open your pc case
open screw of rom then remove power and data connection from rom then pull your rom.
then install dvd burner.
power and data code connect.
install burner soft
ok
u have done
Mar 24, 2008 | Dell Dimension 2350 PC Desktop
Computers & Internet Logo
128 people viewed this question
Alun Cox
