Question about Danby Refrigerators
Why freezer is cold but not freezing totally> ice cubes only have frozen qnd dial is turned to full? model dff280wdb
mikedurland
  • 481 Answers
SOURCE: bosch frost free fridge freezer not freezing ice cream/pops at all and meat not totally frozen
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/board
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items. If it still has a problem then it might be the compressor and you should probably replace the machine.
Posted on Jun 28, 2008
SOURCE: Sub-Zero 550 - freezer unit is chilling, but not freezing
Ice maker was intermittent at best - ice was often just a shell. After two failures to correct we had the ice maker (a Whirlpool - on a Sub Zero - Go figure) replaced. Then the paddle that detects the ice level broke. Next step a new GE.
Posted on Aug 22, 2008
tborn6
  • 700 Answers
SOURCE: Ice turning into a solid block in freezer. Samsung Refigerator
when you look into the freezer where the ice maker is do you see something hanging underneith the ice maker? if you doi that is the sensor. If not contact me and I will walk you thru the steps to correct the problem.
Posted on Feb 01, 2009
SOURCE: freezer not getting cold
Call local Repair shop, No Fix possible, leak in the coils, can't repair.
buying new fridge.
Posted on Mar 23, 2009
  • 146 Answers
SOURCE: Ice Cream and frozen waffles won't freeze.
LOL ! SO in other words in plain english your repair man told you needed a brand new refrigerator - Ok from your description here we can rule out low refrigerant or compressor problems, defrost timer and controlboard issues. I too have waffles and they DO get frozen although not as hard as ice - the less water molecules they have the less they are frozen hard. but nonetheless, my waffles are NOT soft, neither is ice cream
What I would ike you to do is put one of those refrigerator/freezer type thermostats, you can get those round ones, place it in your freezer leave it there 24 hours and look again - Optimal freezer temps is 0F once compression cycles off - if you areusing the extra cold setting, -10F - For refrigerator don't go over 40F - optimal temp of 36-38F.
Another method you can place a bowl of water and use one of those probes and measure the temp of the water in your fridge. If your temps are within safety levels do not worry - your ice is frozen and your frozen food is frozen - Some ice cream tend to be softer, especially the extra creamy type. If your refrigerator has a dial to adjust temps, raise it slightly and wait 24 hours and check your temps again you might need to bump down the temps a bit - if you have a control panel and 2 settings they are usually COLD or COLDER, set it to COLDER and check again - in the COLDER setting your compressor will shut down once your freezer hits -10F that should be quite enough to have even your waffles and extra creamy icecream frozen - if some of the liquids in your refrigerator is too cold or freezes, set it back to COLD or re-adjust the dial. Once you determined that your freezer AND refrigerator are within SAFETY levels as per the food safety guidelines and using the proper methods of testing, then you have nothing to worry about. Make sure your fridge and freezer are not leaking cold air by checking your door gaskets using the famous dollar bill technique by closing the door on the dollar bill and trying to pull it out - if there is no resistence and can easily come out, you have a gasket leak - check in different places on the gasket. As long as you can determine that your freezer and fridge temps are SAFE don't spend a dime ! If your temps are NOT in the safe range you probably have leaky gaskets - if the compressor seems to run all the time, you probably have dirty condenser coils that need to be vacuumed cleaned or dusted off using a condenser brush.
Posted on Aug 17, 2009
Frozen freezer water line
Odds are your temperature is too cold in your freezer. If when you moved you just plugged in your freezer without adjusting your temperate for your new location you accidentally froze whatever water was coming into your freezer.
First you will need a cooler for whatever you have in your freezer, unless you have wonderful neighbors who will let you keep your food in their freezer for couple of days.
Take note to see what your freezer thermostat is set to. Turn off your freezer. Take out all the food. Keep the door open. This would be a great time to clean your freezer. Let the freezer thaw out for at least one day. Check the line to make sure there is no ice. Once everything has melted turn your freezer back on. Turn your freezer back on but this time set the thermostat to three or maybe 4 levels below what you had it set to before.
Finding Freezing level:
Fill an ice cube tray or small plastic cup with water. Put it in your freezer and come back in about three hours to see if has begun to freeze. If it has not begun to ice raise your thermostat to make you freezer colder by half or 1 level. Leave the ice tray or cup of water that you originally placed in the freezer but add another one. Come back in three hours to see if the water has frozen or has begun to freeze.
You want to leave the original water because you need to make sure the new water does not freeze solid as fast as the original water. If it does your freezer is too cold again.
Repeat "Finding Freezing level" until the water begins to freeze but does not freeze solid. Once your ice begins to free you can put your food back into the freezer. Wait a couple of hours more to see how much more your cubes freeze. If they are hollow or still watery in the center you should go up another half level and check on it the next day.
Once your cubes freeze solid you should be all set. If you don't get at least one tray of ice per day from your freezer you could go up another half level so your ice freezes faster.
Be careful about making your freezer colder because you might end up with the same problem you started with depending on how sesitive you thermostat is.
May 03, 2012 | Maytag MSD2578VEM (254 cu ft) Side by Side...
My icemaker is making hollow ice cubes what is causing this?
I would guess that the freezer is turned down too low to give the water in the ice maker time enough to freeze solid before the action of the ice maker completes it's cycle. Turn the freezer thermostat up to max and see if this makes a difference. After checking, if the ice is frozen solid, then dial it back half way between where you had it set and max, then check again.
Dec 27, 2010 | Whirlpool Refrigerators
Ice is dumped before totally frozen.
Sounds like a water valve problem. The hollow ice cubes are the giveaway. This means not enough water. only things it can be is the ice maker is not turning on the water valve long enough or the water valve is restricted or the water valve has been leaking and has frozen the fill tube. and is only leting out a small amount of water in this case as well you will still need a new water valve.
start with water valve and if that does not solve the problem you will need to replace the ice maker.
Jan 12, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Ice cubes not freezing completely before dumping
check evaporator fan if working or u may have a leak , or check condsr fan motor :)
Aug 28, 2009 | Amana ARS2464B Side by Side Refrigerator
Aug 17, 2009 | Amana Refrigerators
Freezer not keeping things frozen
Hi Jody,
The only thing you give me that would allow me to solve this issue, is based on the fact that the freezer is getting warmer, and fresh food section is staying cold. So, knowing nothing more than that, I must sadly say that you need a new refrigerator to solve this issue 100%, as it sounds like you have a failing compressor, or a slow leak in the sealed system. Both scenarios are terminal.
Thank you for contacting me at Fixya.com
Dave E. (Illeagle)
Jun 12, 2008 | Freezers
We have a Whirlpool gb22dk refrigerator freezer. The bottom freezer keeps meat frozen but will not keep sea food ice cream bread ect frozen. This fridge came with our house which we purchased 2 years ago...
1st.Check the freezer door gasket for any place it maybe torn or not making a 100% seal when you close the door.That would make temperature drop. 2nd.take off bottom kick plate so you can look under the refrigerator.Using a flashlight make sure there is not alot of lint / dust stuck on the coils .If there is remove it carefully and you will see temperature lower. PLEAS RATE THIS!
Jun 09, 2008 | Whirlpool Refrigerators
Icemaker
You might have a frozen line. Also and this seems more important to you its prob to cold, Trust me to cold of a refrig will cause hollow ice cubes first leading to a frozen line. Clean your coils, if you have another refrig empty out into that, unplug it leave doors open a couple days. If you can get to water line use a hair dryer from a distance defrost line, turn down freezer half knotch 1 full one at maximum. should fix issues, especially if filter already changed. If this all check prob a clogged line, not just frozen.
Mar 15, 2008 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Refrigerators Logo
27 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
jason
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
