Question about Plumbing
Water does not shut off
Toilet flushes, but water does not shut off
    Problem Solver:
  • 9 Answers
This has 3 common reasons and easy fixes to each: 1, the stopper or flapper ball at the bottom where the water exits the tank may be worn or improperly seating on so the water keeps leaking down into the bowl. The tank will lose water, the supply will keep feeding the tank. Turn off the supply valve to the tank. It may help to apply a little petroleum jelly to the flapper ball to get a water-tight seal. If it's worn, replace it. If the water is running into the over-flow tube, you may be able to fix this by adjusting the water level by either turning a screw on the water supply assembly on some models, or by lowering the float ball or float coupling on the water supply stem assembly. If none of these seem to help, new inserts for tanks are easy to replace and relatively inexpensive.
Posted on May 12, 2014
Why does the toilet flush shut off too soon
Check your water level it should be about 1/2" below the top of the overflow pipe. Also if its American Standard the flush adjustment on their flapper valve is very finicky (the type with small round chain links) if its too tight or too lose it will not flush properly.
Jul 27, 2014 | Home
Wont complete flush
Could be low water level in the reservoir, otherwise the flapper may be shutting to quickly to allow enough water to properly flush. You could try holding the flapper open or watch it's operation as you flush the toilet to see if it's allowing enough water to drain into the toilet. It's pretty easy to replace the flapper on most toilets and cheap as well.
Jul 25, 2014 | Home
Koehler one piece toilet trickling water into tank
The flapper at the bottom of the tank is leaking and needs replacement.
Feb 08, 2014 | Kohler SAILE ELONGATED ONE-PIECE TOILET...
My toto neorest 500 "burps" when I flush but the water does not go down
The problem may be in the venting of the toilet. If the vent for the toilet is plugged or in the northern climates frosted shut the air in the toilet drain has nowhere to go when displaced by the flushing water so it backs up through the toilet and causes the "burping" you mentioned. Hope this helps.
Dec 12, 2013 | Toto Home
When I flush thenwater fills to the fill line and slowly keeps on dripping over the top of the flush valve tube.
I would ckeck to see where water fill line is inside toilet tank and then adjust flush valve to try to get it to shut off at this point. Not knowing whether your toilet still has original flush valve it is hard to tell you how to fix it. If it has float mounted on rod to flush valve there is usually a set screw on the top of the flush valve in the center. Turn this screw clockwise to make valve shut off sooner. Try to set it so that water shuts off when it is at fill mark. If float is mounted on brass float rod you can support rod closest to flush valve with left hand and carefully bend rod down a little with your right. This will cause flush valve to shut off sooner. If the seat is worn to badly in flush valve you will need to replace it.
Nov 18, 2010 | American Standard 2004.014.178 Champion 4...
I have a Carlyle water saver toilet. The one that has two push buttons built into the toilet tank lid. It is a solid 1 piece toilet. My problem is every hour the toilet is flushing by itself. Had a...
Hello. Your lid has two buttons so you can do a half flush or a full flush. A water saving feature. Since the toilet is flushing by itself every hour or so, you must have a leaking flush valve. Replace the valve to solve that problem. Joe
Oct 12, 2010 | Toto Carlyle 1-piece Elongated Bowl Toilet
I just installed a Kohler Wellworth toilet. Wheni flush the tank only empties about 3 or 4 inches and then shuts off. The water level is at the highest. How do I correct this. Thanks
As long as this toilet is NOT a pressure assist toilet. Then it probably has a water saver flapper that you can replace with a non water saver flapper. This will allow it to flush more. Be advised you may have to adjust the water level after the change to prevent it from double flushing. Hope this helps.
May 21, 2010 | Home
Have a vitra dual flush toilet we have no water pressure when you flush the toilet
check to make sure the water level in your tank is sufficient, if not you'll need to ajust your float. otherwise your flapper is shutting too soon, you'll need to shut the water valve off and flush untill the water in the tank is gone, letting air back under the flapper slowing it's desent when submerged. then turn the water back on. if the problem continues repace the flapper.
Sep 19, 2009 | Home
No water at flush
sound like the water shut-off needs to be replaced.
if you turn on/off the shut-off, the tank get enough water to flush, then you get less water every time you use the toilet. that is the shut-off valve problem.
you may able to to just change the rubber seal.
I have not found change the seal will last as long as a new valve. better off, just change one.
Feb 11, 2009 | Eljer Aqua-Saver 12" Two-Piece...
Plumbing Logo
166 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
