Question about Furniture
How attach to wall
What size screwsare used to attach wall mount
Wall mount for what size TV?
The answer is probably in the instructions that came with the wall mount.
I need: Size of TV.
What kind of wall you want to attach this TV to.
Remember, I am far away and can't see what you are doing.
Aug 19, 2014 | Televison & Video
How can I attach my wine rack to the wall?
Most of the wine racks designed for free standing although it is recommended to anchor them to the wall. In order to do so, you should drill through the rear spacer bars of your rack and attach it to the studs in your wall or you can simply use an "L" bracket.
Aug 13, 2012 | Furniture
Philips splitter doesn't attach to wall
its a male connector, call a technician to help you
okay
Aug 05, 2009 | Toshiba 26HF85 26 in. Television
Attaching Wall Mount Support to AKAI Flat Panel
You use the four outer holes as suggested in the manual on page 12, see below:
Apr 23, 2008 | Akai LCT2721AD 27 in. LCD Television
How do i attach a Wall Mount to the TV?
I have the same TV, and I bought a mount with 4 connector holes. I was able to connect 3 of the 4 and it has been fine as the TV does not weigh too much. The TV was not designed with the current mode of either wall or stand mount. It was just intended for stand. I have had it on the wall for over 2 years.
Apr 23, 2008 | Televison & Video
Antenna problems
where to attach the antenna? becoz my tv is attached too close to the wall. i can't see the backpanel
Nov 17, 2007 | Televison & Video
Hi, Ok, great.Look at the back panel and you can see four holes spaced 4" between the top and bottom, and 16" from side to side. these are for universal mount. http://www.bestbuyplasma.com/Plasma/tvmounts_land.asp I think this clears your problem regards sreejith "Please use caution if wall mounting this product. Follow all directions from the manufacturer of the wall mount and be sure to securely fasten the product to the mount. While the TV can be wall mounted, improper wall installation may void the warranty."
Jul 16, 2007 | Akai LCT3285TA 32 in. LCD Television
Attaching to wall mount
The 4 screws that are commnly used are short because they are ususally wide in diameter. Besides if they are too long then they might damage the boards on the TV.
Apr 13, 2007 | Akai LCT2716 27 in. LCD Television
Furniture Logo
148 people viewed this question
Top Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Furniture Expert? Answer questions, earn points and help others
