Question about HP LaserJet 4345mfp Printer
49.4c02 error on my printer please help - HP LaserJet 4345mfp Printer
There's an error 5100 appear on my printer canon mp770. I need some help,please.
Problem You are unable to print and receive the message Error 5100 on the computer or printer display screen.
Cause Error 5100 is a carriage error that can usually be fixed by using service mode and flushing the printer heads when it has a blockage.
Solution Try the following:
If this doesn't work then the printer may need repair.
Canon Printer Error 5100
Oct 19, 2012 | Canon LASER SHOT LBP-2900 Printer
HP Color LaserJet CP1515n Printer is showing error 51.23. please help
error 51.23 on the hp color laserjet cp1515n printer. please help
Apr 28, 2011 | HP Office Equipment & Supplies
Sir, there is an error i.e system error e225 in my canon mf 4350d machine please help me shut out this problem
Sir, there is an error i.e system error e225 in display my canon mf 4350d machine please help me shut out this problem
Apr 11, 2011 | Canon ImageCLASS MF4350d Laser All-in-One ...
The printer will not print because of service error 49,4c02
Hello thanks for using FixYa
error 49.4c02 is a critical firmware error that occur which cause the processor on the formatter to abort operation.This type of error can be because of invalid print commands,corrupt data,or invalid operations. Sometimes electrical noise in the cable can corrupt data during transmission to the printer. Other causes include poor quality parallel cables or poor connections,
To solve this try this solution step by step
  • Turn the printer off and then back on.
  • Try printing a job from a different software application. If the job prints, go back to
  • the first application and try printing a different file. If the message appears only with a certain software application or print job, contact the software vendor for assistance.
  • f the message persists with different software applications and print jobs, disconnect all cables to the printer that connect it to the network or PC.
  • Turn the printer off.
  • Remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM in slot J1.)
  • Remove all EIO devices from the printer.
  • Turn the printer on.
  • If the error no longer exists, install each DIMM and EIO device one at a time, making sure to turn the printer off and back on as you install each
  • device.
  • Replace a DIMM or EIO device if you determine that it causes the error.
  • Remember to reconnect all cables that connect the printer to the network or computer.
  • If the error persists, final option is replace the firmware
Please see my this Solution (Same as your's), 2 people thought it as Helpful for them So
I hope this solution will also helpful 4 u
Please don't forget to click on Four thumbs which are given below & then write testimonial in your words for appreciation if it is helpful
THANKS & Keep Using fixya
Feb 10, 2011 | Office Equipment & Supplies
I Have Fault Codes on the Display.
Problem solve someone tried to print a PDF file which lodged the fault our It Dept deleted the print spool and Re-set the printer all ok.
Jan 14, 2010 | HP Color LaserJet 5550hdn Printer
49,4c02 error to continue turn off then on
I would try clearing your print que as it could be a corrupt print job and disconnecting your network cable and reboot the printer, make sure you have the latest firmware. hope this helps
Nov 24, 2009 | HP LaserJet 4700 Printer
HP Laserjet 5m, appear error code 50...please help.
Error 50 will be a faulty fuser unit or DC controller board. Try replacing the fuser unit.
May 20, 2009 | HP LaserJet 4m plus Printer
Got error of "PC cannot send datga to printer. Please check power
my printer, I got error of "PC cannot send data to printer. Please check power and printer cable connections and retry printing". Please help me.
Apr 02, 2009 | Sharp AL-1642CS Copier
Hp laserjet 4650n
Hi 123sha:
49.XXXX
PRINTER ERROR
To continue
turn off then on
A critical firmware error has
occurred that caused the
to abort operation. This type
of error can be caused by
corrupt data, or invalid
operations. In some cases,
Other causes include poorquality
parallel cables, poorconnections,
or home-grown
programs. On rare
occasions, the formatter is at
fault, which is usually
indicated by a 79 Service
Error.
1 Press CANCEL JOB to
clear the print job from
the printer memory.
2 Turn the printer off and
then on.
3 Try printing a job from a
different software
program. If the job
prints, go back to the
first program and try
the message appears
only with a certain
software program or
software vendor for
assistance.
4 If the message persists
programs and print jobs,
disconnect all of the
or computer.
5 Turn the printer off.
6 Remove all memory
7 Remove all EIO devices
from the printer.
8 Turn the printer on.
9 If the error no longer
DIMM and EIO device
off and on again as you
install each device.
10 Replace a DIMM or EIO
Try new network card
pdouglasss
Jun 18, 2008 | HP LaserJet 4650 Color Printer Manual...
HP LaserJet 4345mfp Printer Logo
Seeker5211
Seeker5211
