Question about Phil & Teds Baby Gear
Axle diameter? What is the diameter of quick release axle
2 Suggested Answers
Coachphil
  • 347 Answers
SOURCE: Just got this bike it
on my tips and tricks page are links to owners manuals for Schwinn and Huffy. they are all the same, Those respective websites with the links have clear instructions on quick releases.
Your quick release has three parts
1. shaft with lever
2. nut
3. springs x 2
Take the lever apart, remove the nut and both springs. install one spring large side onto the shaft all the way up against the lever side, slide the shaft through the hub axle center, install the other spring on the shaft opposite the lever small side facing the hub, then screw on the nut. look to the video for the rest.
Posted on Mar 21, 2011
How does a quick release go together on a rear wheel of a schwinn hydra bike
Quick release can be fitted to any bike - all you need is to fit hollow axle first.
May 18, 2011 | Schwinn Cycling
Just got this bike it was unassembled. The instruction manual had a different front axle than mine. Mine has the quick release and I can't get the tire tight. I think I am putting the quick release...
1. shaft with lever
2. nut
3. springs x 2
Mar 21, 2011 | TitanNet Titan Fusion Mountain Bike
94 caprice classic rear spider gears shot 12 or 16 possi what other rear ends are compatible for this 5.7 liter
. Axle Code >>>>>>>>>>>Standard
2YN Gear Ratio >>>>2.56<<<<< Ring Gear Diameter 8.5 Standard 2GA Gear Ratio 2.73 Ring Gear Diameter 7.6 Standard 2GB Gear Ratio 2.73 Ring Gear Diameter 7.6 Standard 2GH Gear Ratio 2.73 Ring Gear Diameter 8.5 Standard 2LW Gear Ratio 3.08 Ring Gear Diameter 8.5 Standard 2LR Gear Ratio 3.23 Ring Gear Diameter 8.5 Standard 2LY Gear Ratio 3.23 Ring Gear Diameter 8.5 Standard 2LT Gear Ratio 3.23 Ring Gear Diameter 8.5 Standard 6YF Gear Ratio 3.23 Ring Gear Diameter 8.5
Axle Code>>>>>>>>> Limited Slip
2LQ Gear Ratio >>>>>>>>2.93<<<<<<<<<<< Ring Gear Diameter 8.5 Limited Slip 2YG Gear Ratio 2.93 Ring Gear Diameter 8.5 Limited Slip 2LX Gear Ratio 3.08 Ring Gear Diameter 8.5 Limited Slip 2ND Gear Ratio 3.23 Ring Gear Diameter 8.5 Limited Slip 2LZ Gear Ratio 3.23 Ring Gear Diameter 8.5 Limited Slip 2LS Gear Ratio 3.23 Ring Gear Diameter 8.5
Nov 28, 2010 | 1994 Chevrolet Caprice Classic
Ti lite mAnual chair. hub rubs on axle and i am not sure how to lengthen the axle to hold hub further away...
The quick release axles on this chair have an adjusting nut on the outside end to adjust the length. The nut may have a disc cover on it for decoration. To adjust the axle length hold the end with the two balls on it with an adjustable crescent wrench set for the axle diameter and at the location of the balls. This way when you adjust the nut, the axle will turn until the balls contact the crescent wrench and the axle will stop turning. Turning the nut counterclockwise will lengthen the axle. All the nuts require a 3/4" wrench. Once you have made the axle longer you may need to put a washer between the hub and the axle receiver to keep the hub from rubbing.
In my experience, the hub may be rubbing because the camber tube is not even where the frame connects/clamps to it. Loosen the camber tube mounting bolts or clamps. Measure both sides and correct by marking the original camber tube position first, then adjust left to right for even spacing. Only adjust left to right do not rotate the camber tube since that will change the camber (unless you have zero camber). If you lengthen the axles this way check that the new adjustment allows the axle to lock in the camber tube. Tug on the wheel to make sure it is locked in the tube before getting in to ride. Hope this helps.
Nov 08, 2010 | Tilite ZRa Titanium Wheelchair
I have a Cannondale road bike. There is a quick
You may need to remove the wheel, undo the quick release axle from the opposite side and then use the axle that comes with your trainer.
Jun 11, 2010 | Bell Sports Bell Motivator Indoor Riding...
Does this bike have quick release for the wheels?
If one side of the axle holder has a lever about 2" long it is quick release.
If it has nuts that require a spanner it is not quick release
May 20, 2010 | Schwinn Seneca 700c Road Bicycle
No Rear Quick Release
Some less expensive bikes do not come with quick release skewers. You just unscrew the bolts like you would any other using a wrench or socket. The will probably be really tight so you may need to bear down or use a cheater pipe. Unfortunately, these bolt on wheels tend to be solid axles and cannot take a quick release skewer. You would need to replace the wheel.
May 20, 2010 | Schwinn Miramar Women's 21Speed Bicycle
Will the wheels from a 2000 Harley-Davidson FXDX Dyna Super Glide Sport fit on a 1999 Harley-Davidson FXDX Dyna Super Glide Sport both have dual disc brakes on front?
Check to see if they both have the same diameter axle. Harley went from a 7/8 inch diameter axle to a 1 inch diameter axle sometime around that time period.
Nov 15, 2009 | 2000 Harley Davidson FXDX Dyna Super Glide...
I want convert from a regular threaded axel to a quick release pin on the rear wheel. How can I do that?
You will need to replace the old axel with a hollow quick release axel of the same outside diameter and the correct length to fit between the outside of your rear forks with the nuts and washers in place. In other words you will have to rebuild the hub of your rear wheel. It is arguable as to whether it is easier and cheaper to just buy a new wheel with the quick release axle already in it and just switch the cassette over. You will have to make a trip to your local bicycle repair shop for parts anyways so you might as well do a price comparison. Remember you will need bearings nuts washers and a tool to remove your cassette. Ask and they will probably switch the cassette over to the new wheel for you for a nominal fee. I used to charge $5.00 for this if the customer wanted to switch the tire themselves. It was an extra $5.oo to switch the tire.
Aug 16, 2009 | Cycling
How and where do you hook on the bike trailer to the bike?
Your bike trailer has a washer looking thing with usually-two holes(one large and one small) The smaller diameter hole mounts to your left side rear axle nut or your quick release wheel nut-meaning, take off the nut or flip thumb tab and unscrew, slip on washer thingy and tighten back down.
The larger diameter hole should be in the downward position like a teardrop, this accepts the bent frame pole from the trailer by use of the spring clip/pin. Slip frame pole into larger hole and lock in with clip and your on your way. ***Just don't forget to attach safety strap from the frame pole to your bike -should the clip ever come undone.(unlikely)
***Do have a bike shop or pro look at the finished hookup if your concerned for safety
Aug 08, 2009 | InSTEP 12-QE111 Quick N EZ Bike Trailer
Baby Gear Logo
Top Phil & Teds Baby Gear Experts
Jennifer Rock
Jennifer Rock
ray gallant
Bill Boyd
Are you a Phil & Teds Baby Gear Expert? Answer questions, earn points and help others
