Question about Craftsman 48" Cut Riding Lawn Mower Deck Belt 174368
Keeps braken deck belt - Craftsman 48" Cut Riding Lawn Mower Deck Belt 174368
STX46 belt keeps coming off the mower deck, John Deere
check to be sure the pulley isn't damaged. there should be belt keeps that help hold the belt on the pulley. be sure the belt isn't stretched and the deck is not damaged. be sure the belt is on correctly.
Aug 06, 2016 | John Deere Garden
Belt keeps slipping on treadmill and belt is all the way back
If you have adjusted the tension on your belt to the max, it is more than likely time to replace your running belt. The running belt naturally stretches over time. I would suggest replacing the belt and flipping your deck. If the deck has already been flipped once, then you would need to replace the deck as well. Life Fitness Treadmill Belt and Deck Replacement Video 95T
Apr 01, 2014 | Life Fitness 91Ti Treadmill
Drive belt on deck keeps jumping off
The belt tentioner is loose.
Jun 22, 2013 | Craftsman Garden
Toro 17-44 can't keep deck belt from coming off
is the deck adjusted level?is it the right belt?
Apr 23, 2012 | Garden
Sony dual deck, deck B works fine, deck A won' run the tape but just keeps clicking as it auto-reverses.
Hi amitchell47,
The rubber belts that turns the gears is already worn out. Usually, there are two rubber belts in a cassette deck. You have to replace both belts. I hope everything works out. Good luck.
Jul 25, 2011 | Sony CASSETTE DECK Single Dual Cassette...
My proform crosswalk 590 circuit breaker keep turn off after run for five mins
Have you lubricated the walking belt & deck?? Are the deck and/or belt worn out and require replacing??
Check the deck for damage and wear, check the belt (feel the outer edge and then the center. Is the center fuzzy??)
If the deck and belt are good, lubricate them and try again.
Is the belt to tight??
Are you using an extension cord??
The machine is drawing too much current, usually deck & belt or defective motor will cause your breaker to go..
Dec 14, 2010 | Proform Exercise & Fitness
Why does the drive belt keep coming off?
This is usually caused by a stretched belt or a broken or disconnected bracket causing the deck to go out of alignment. Also check to insure your belt guides are in place (usually close to the pulley on the deck) they assist in keeping the belt in the groove, there should be two, close to the pulley.
Apr 28, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Have a 2006 145 automatic riding mower. Belt keeps
idler or adjustment pulley bearings worn allowing belt to ''run off''as it wobbles.stays on.check spring tension of idler.
Sep 20, 2009 | Garden
Deck belt
Look at the Idler pully on the deck ther should be a Spring that keeps tension on the belt if it does not have that feature on that deck then there is a stay pin missing or the belt has just gotten to big (streached)
Apr 08, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman 48" Cut Riding Lawn Mower Deck Belt 174368 Logo
18 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
