Question about ASUS F5R-AP038A Notebook
How to 1/2unlock asus keyboard windows 8 - ASUS F5R-AP038A Notebook
Need help with key board
If you are using a bluetooth keyboard, you shoud turn it on, turn your tables, go to setting, enable bluetooth and get it pair with keyboard.
If any other question, be specifi about help you need
Watch video hor to pair tsblet with keyboard
Bluetooth Keyboard Pairing Windows 8 Samsung Series 7 Slate Tablet
May 02, 2015 | EEEKit Portable Office 4-in-1 Kit for 8...
How do I turn on my Asus keyboard?
Most likely your OS is windows 8 or 8.1. Place the carrot/cursor anywhere on the screen where there's no icons and just type in the word keyboard. You have the options there to do whatever you wish.
Dec 01, 2014 | ASUS X53e-xr1,intel Core I3-2310m...
How to make at sign work on asus laptop?
If your @ sign is not working it is probably a regional setting in your control panel. Your Keyboard is probably set to the the wrong layout
This will be slightly different for Windows 7 vs Windows 8 so check the control panel for Regional settings, input, keyboard settings. you will need to change your keyboard layout. If the @ sign is ontop of the number "2" then select US otherwise select UK. That should help.
Aug 31, 2014 | ASUS Eee Computers & Internet
Why won't ASUS G laptop boot up?
Yes; Batteries at the end of their life cycle do act like that.
support.asus.com/
Jun 30, 2014 | ASUS G Series 17.3" Full HD Gaming...
Keyboard volume control
You can check the latest audio driver on https:\\support.asus.com
Apr 07, 2014 | ASUS M51AC-US004S Desktop PC Windows 8
Locked keyboard on windows 8 with asus q200
well I know something that might work. don't shoot me if it doesn't.
first of all, make sure you're laptop isn't charging, then take out the batery from the underside. then press on the ON button for about 30 sec. when you've done that you can put the batery back in and start your laptop. your keyboard should be working.... hope it helps :)
Nov 23, 2013 | ASUS Computers & Internet
I nd 2unlock my nokia 5300 security codeIMEI 355550/01/990466/8
Hi you can try here http://www.mobileunlocksolutions.com/ to get unlock code for your mobile and get it unlocked safely..
May 18, 2011 | Nokia 5200 Cellular Phone
My keyboard don't work properly since i install windows 7 ultimate what i suppose do to fix?
go too the ASUS link below and get your keyboard driver for Windows 7, select the keyboard you have
i hope this helps you
http://support.asus.com/download/download.aspx?SLanguage=en-us
Nov 01, 2010 | ASUS 90-A4C1K1000 Keyboard
When I type on my ASUS U50A notebook, the cursor jumps ahead and behind, especially when I'm tying the letter "o". How do I fix it?
Please try to clear the connector of the keyboard and fix it correctly, it may solve the problem.
We are committed to supply a variety of laptop parts for fulfilling your needs.
<a href="Asus'>http://www.laptopparttips.info/2012/09/09/asus-n53sv-keyboard/">Asus N53SV Keyboard</a>,
<a href="Asus'>http://www.laptopparteshop.com/asus-n53sv-keyboard-replace.html">Asus N53SV Laptop Keyboard</a>,
<a href="Asus'>http://www.laptopparteshop.com/asus-g53-white-keyboard-replace.html">Asus G60jx White Keyboard</a>,
<a href="asus'>http://www.laptopparteshop.com/asus-g60jx-keyboard-replacement.html">asus g60jx black keyboard</a>,
<a href="asus'>http://www.laptopparteshop.com/asus-g60jx-cpu-fan-replacement.html">asus g60jx laptop fan</a>,
<a href="replace'>http://www.laptopparttips.info/2012/09/09/how-to-replace-fan/">replace cpu cooling fan</a>,
<a href="Asus'>http://www.laptopparteshop.com/asus-g53-white-keyboard-replace.html">Asus g53 keyboard</a>,
<a href="Asus'>http://www.laptopparteshop.com/index.php?target=products&mode=search&subcats=Y&type=extended&avail=Y&pshort=Y&pfull=Y&pname=Y&pkeywords=Y&q=asus+a52f&cid=0">Asus A52f laptop Part</a>,
<a href="asus'>http://www.laptopparteshop.com/asus-a52-a52f-lcd-cable-replacement.html">asus a52f lcd cable</a>,
<a href="asus'>http://www.laptopparteshop.com/asus-a52-a52f-keyboard-replace.html">asus a52f keyboard</a>,
<a href="asus'>http://www.laptopparteshop.com/asus-a52-a52f-battery-replacement.html">asus a52f battery</a>,
<a href="asus'>http://www.laptopparteshop.com/asus-a52-a52f-cpu-fan-replcement.html">asus a52f laptop fan</a>,
<a href="asus'>http://www.laptopparteshop.com/asus-a52-white-keyboard-replace.html">asus a52 keyboard</a>,
<a href="asus'>http://www.laptopparteshop.com/asus-k53-keyboard-replace.html">asus k53 keyboard</a>,
<a href="asus'>http://www.laptopparteshop.com/asus-k53-lcd-hinges-replacement.html">asus k53 lcd hinges</a>,
<a href="asus'>http://www.laptopparteshop.com/asus-k53s-cpu-fan-replacement.html">asus k53s cpu fan</a>,
<a href="asus'>http://www.laptopparteshop.com/asus-k53s-lcd-cable-replacment.html">asus k53s lcd cable</a>,
<a href="asus'>http://www.laptopparteshop.com/asus-u50-keyboard-replace.html">asus u50f Keyboard</a>,
<a href="asus'>http://www.laptopparteshop.com/asus-g73jw-g73s-keyboard-replace.html">asus g73 black keyboard</a>,
<a href="asus'>http://www.laptopparteshop.com/asus-g73-white-keyboard-replacement.html">asus g73 white keyboard</a>,
<a href="asus'>http://www.laptopparteshop.com/asus-u50f-u50a-keyboard-replace.html">asus u50a keyboard</a>
Mar 24, 2010 | ASUS Computers & Internet
ASUS F5R-AP038A Notebook Logo
16 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
