Question about Panasonic KX-TGA101S Cordless Handset
The phones will not got a ring tone to make calls or answer
SOURCE: First line does not ring..
Hit the reset button on the bottom of the base unit and reinitialize your setup.
Posted on Oct 10, 2008
  • 12 Answers
SOURCE: i have no dial tone on one line. call my number and it rings
IT IS DUE TO NETWORK FAILURE OF THAT LINE
Posted on Jan 05, 2009
  • 78 Answers
SOURCE: My phone rings a half a ring then stops. The
you more than likely have "short rings" turned on, in the options of that phone. you'll have to go into the options menu, and look for setting that pertain to ringing and / or rings or ring length.....DON'T change DTMF tones though, that'll get annoying, as thats what you hear when you are calling someone else. hope this helps.
Posted on Sep 21, 2009
SOURCE: Can't change ring tone on Panasonic KX-TCA175
I had the same problem. I was advised by Panasonic support that the PBX system needed a firmware upgrade to solve the issue. (still waiting for technician to do this...)
Posted on Jul 28, 2010
  • 225 Answers
SOURCE: Phone (base and both handsets) rings once, then
This is likely caused by a trouble from the service provider. It is caused by a partial short on the phone line. The service provider can usually test the line remotely when you call the trouble in. Occasionally this problem is caused by faulty equipment(phone, answer machine, modem, etc.), bad line cord, bad outlet or bad building wiring. Inside the outside telephone interface box there is a modular test jack that has a short line cord connected. Remove this line cord and connect a standard telephone to test the phone line. Make a call to your number, if the problem occurs with the phone connected to the test jack, then the problem is with the service provider. If the problem does not occur with the phone connected to the test jack then the problem is in the building wiring, outlets, line cords or devices connected. Use a process of elimination to determine where the problem is. Example: disconnect all phones and devices and line cords, make test call with one phone connected, if problem continues inspect outlets and wiring.
Posted on Dec 29, 2010
Testimonial: "Our phone actually started working correctly again, so I think you were correct in saying it was the service provider. Thank you for your help!"
On incoming call phone lights up with number and you can answer but no ring tone
Hi David.
if the all setting are ok??
then you have to check its ringing tones ,simply go to ringing tones under the settings and try to change the tone and you can increase the volume in this menu too.
if no ringing ton hear.
it is hardware issue.
regards.
nuwan
Jan 16, 2014 | Cell Phones
Merlin BIS-10 no dial tone and can't answer but phone rings
I have a dial tone but can not make calls. and if the phone ring they can hear me but I cannot hear them
Apr 01, 2013 | Avaya MLS 12D Corded Phone
How can I get the telephone on my Brother Fax T96 to work?
Step by step information at the link below.
Brother Fax T96
The F/T Mode is used to allow the fax machine and the telephones to share the same telephone line. When a call comes in, the fax machine and all extension telephones on that line will ring according to the number of rings you have set for the Ring Delay.
When the Ring Delay is completed, the fax machine will answer the call and determine if it is a fax call or a telephone (voice) call.
The fax machine can determine this by the signal it is receiving on the telephone line. If someone is sending a fax automatically , the sending fax machine will transmit a fax tone (a series of beeps every 3 seconds).
If your fax machine hears these tones, it will receive the fax.
If the fax machine does not hear any fax tones, it assumes it is a telephone (voice) call and will begin ringing the F/T ring tones (double ring) for the length of time you selected for the F/T Ring Time. These tones will only ring on the fax machine's handset (extension or external phones will not ring). At the end of the F/T ring time the fax machine will go into the receive mode in order to receive a manual fax.
(If the call was a voice call and was not answered, the caller will hear the fax receive tones also).
  • If you answer the call before the fax machine(during the ring delay period) and determine it is a fax, you can transfer the fax to the fax machine for receiving.
  • If you answer the call on an "extension" phone and hear a beep every 3 seconds (automatic fax) or silence (manual fax), press *51 or *91 for New Zealand (remote activation code) on the telephone keypad, wait to hear the fax machine turn on (chirping sounds) and then hang up.
  • If you answer on the handset of the fax machine and hear a beep every 3 seconds or silence, press the Fax Start or Start/Copy key on the control panel of the fax machine and then hang up the handset.
  • If you answer a call on an "extension" phone during the F/T Ring Time, you will hear the F/T ring tones.
    To release the call from the fax machine, press #51 or #91 for New Zealand (remote deactivation code) on the telephone keypad and you can speak to the calling party.
  • If you pick up the handset of the fax machine during the F/T ring time, you may talk to the calling party immediately.
Mar 28, 2011 | Office Equipment & Supplies
To increases volume
first of all u can increase volume during call by pressing right button (middle one). but i think ur phone is set to max and u dont hear much - in this case probably some "metal dust" sticks on your speakers membrane - open case clean speaker gently or replace with new one...
Feb 07, 2011 | Nokia 1600 Cellular Phone
When dialing with my logitech skype phone I can't hear any sound until the other person answers the phone. It only happens with skype to skype calls. It works perfectly calling regular phones.
This is probably because dial tones and ringing tones are part of an archaic system. Your cell phone still makes these noises as a courtesy, and you hear the dial tones/ringing tones when you make regular calls because your phone is communicating with the standard phone system.
Jul 12, 2010 | Logitech Cordless Internet HandsetĀ for...
What is answer mode?
The answer mode determines whether the HP Fax answers incoming calls or not.
Different answer modes are :
* Fax
The HP Fax will automatically answer all incoming calls using the Rings to Answer setting. This is the default setting.
* FaxTel (unit with handset model only)
The HP Fax automatically answers all incoming calls using the Rings to Answer setting. If the call is a fax call, the HP Fax will receive the fax. If the call is a voice call, the HP Fax will create a special ring to indicate it is a voice call. The incoming voice call will need to be answered using the attached handset.
NOTE: If the HP Fax determines the call is a voice call, only the HP Fax will ring with the special ring tone. The other phones on the same phone line will not ring at all. You will not be able to pick up the voice call using the other phones.
* Tel
The HP Fax will not automatically answer calls. Faxes will need to be received manually.
* AnswerMachine
The HP Fax will monitor the line when an incoming call is answered by a person or by the answering machine. If the HP Fax detects fax tones on the line, it will receive the fax.
Jun 07, 2010 | HP Officejet 4315v All-In-One InkJet...
No ring tone canon jx200
sounds like you have phone problem call local phone company to check out line
Jan 13, 2009 | Canon FAX-B160 Plain Paper Bubblejet
Answering phone system cannot handle nuisance calls
i have problem with my phone (TX TCA115UA B)
i can not turn on the tone regime (now is on pulse regime when i dile the number)
Feb 05, 2008 | Panasonic KX-TG5632 Phone
To recieve fax on brother
Press the 'RECEIVE MODE' button on the right side of the control panel, its next to the large 'FAX START' button. Here are your options :
Select Receive Mode
MANUAL
—You must answer all calls yourself. If you hear fax tones, press
Fax Start
to begin receiving the fax, then hang up. You can use this mode with
Distinctive Ringing. (See
Distinctive Ring
, page 8-1.)
FAX ONLY
—The fax machine automatically answers every call as a fax call. You
cannot receive a voice call, but you can dial out and make a voice call.
FAX/TEL
—The fax machine automatically answers every call. If the call is a fax, it
prints the fax. If the call is not a fax, it signals you with a double-ring (ring-ring),
different from the phone company ringing, to alert you to pick up the call. If you select
this setting, you’ll need to set the Ring Delay and F/T Ring Time features (on the
following pages). If you have extension phones on the same line as the fax machine,
set Ring Delay to 4. (See
For FAX/TEL Mode Only
, page 5-5.)
TAD:ANSWER MACH.
—This is the only setting in which you can use an external
answering machine. Your telephone answering device is connected to your fax
machine, and answers every call. Once the TAD answers, the fax machine listens for
fax tones. If it detects fax tones, it prints the fax.
The TAD setting works
only
with an external telephone answering device (TAD); it
does not work with telephone company Voice Mail. Ring Delay and F/T Ring Time
do
not
work in this setting.
Nov 27, 2007 | Brother IntelliFAX 775 Plain Paper Thermal...
Panasonic KX-TGA101S Cordless Handset Logo
20 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
