Question about Frigidaire FAFS4473LW Washer
Frigidaire Affinity front load washer model # FAFS4473LW . The washer tries to drain during when clothers are not being washed. This happens at all times of the day or night. Setting all of the washer setting back to factory default will temporarily fix the problem. The message window states that the washer is draining, even though the washer door was open and clothes were not being washed. Any idea how to fix the problem ?
  • Frigidaire Master
  • 5,323 Answers
Washer fills with water then drains:
My advice is free because God is so good!
The critical question is. Is the water is just running down the drain but the pump isn't running. If it is being pumped out, and you can hear the pump running just the same as when it's emptying prior to spin then it could be aborting the wash because it is, or it thinks it's overheating. ( due to defective water temperature switch)
If the pump is failing to shut off then there is something wrong with the electronics. If your washer is a mechanical timer controlled device then you may have a sticking switch (which may explain if switching cycles does something for you). But if you have an electronic timer then you may be experiencing a board failure, where a cycle is being commanded when it is not intended to by design.
If water isn't being pumped out, but just draining away all the time, the washer will keep detecting there isn't enough water inside and top up with more.
Modern washing machines should be sophisticated enough to realize something's wrong and abort with an error, but if not, it may continue washing or rinsing for a short while before losing enough water to trigger more coming in again. It can get stuck on this cycle indefinitely and it's called siphoning.
Siphoning occurs when the end of the drain hose is lower than the level of the water inside the washing machine.
Try raising the hose and see what happens.
Also the drain hose should have some type of air gap where it fits into the stand pipe. It should not have an air tight fit.
Again Either it's siphoning down the drain due to an issue with the plumbing, it's overfilling, or also if it ( THE WATER) overheats then in some machines the software will employ a fill and drain tactic to cool down the water. The important thing is to work out which of these different faults is causing the problem by careful observation.
Other switch's to check would be the water inlet valve and the water pressure switch with a multi meter for continuity or OHMS.
Frigidaire Affinity front load washer model # FAFS - 24377401-vy3qd1rc3oikbunb5kfp1hkm-3-0.jpg
Posted on May 15, 2015
catriver
  • 878 Answers
SOURCE: Frigidaire front load washer (LTF600ES1) Error E20
holla, Im not showing a E20 code on the tech sheet. There is a E21. Water not draining fast enough. Try holding the start/pause and cancel key together for 3 seconds. The door lock, wash, rinse and final spin leds should light. Any error codes should be displayed when holding those keys. If you see a different error code, post it. If not, I would suspect a clogged pump...Catriver.
Posted on Aug 04, 2007
SOURCE: ATF6000ES front load washer won't spin during regular cycle.
clogged filter will cause this error code. I have the same washer and the filter located inside the rubber boot attached to the pump was full of junk. there was enough room for water to get thru but not enough for full volume. clean it out and it should work. note : its a pain to get the boot back on so be ready and take it slow. this worked for me.
Posted on Aug 30, 2009
beltronic205
  • 1466 Answers
SOURCE: fabric softener will not drain
Try cleaning out ..this should cure . the other thing that can cause this is a faulty solonoid valve as some machines have a seperate valve for this action....
Posted on Nov 25, 2009
SOURCE: My Affinity Front load washer, Model #ATF7000ES1
I am having this same exact issue, have you figured out what the was?
Posted on Sep 11, 2010
  • 196 Answers
SOURCE: How do I access the drain pump on a Frigidaire
If you cant access it from the front You will have to tilt the machine back as far as safely possible to access the bottom of the machine. Locate the drain pump which will be at the bottom font or back corner and remove the hose that connects the pump to the tub, you will need to have a basin ready to catch any water. You most likely have a sock or something stuck. Hope this helps
Posted on Mar 01, 2011
After washing bathroom rugs, my Frigidaire Affinity front loading washer would not drain the water out or refill with water
Often washing things like rugs and matts can cause real problems for the drain pipes on you machine. Have you tried clearing out the drain plug, located at the bottom of the front of the machine? If that doesn't work, the whole drain hose from the drum will be blocked.
thanks
www.recycledrum.com
Jan 12, 2013 | Frigidaire Affinity ATF7000E Front Load...
Fridgidaire affinity not pumping out water
Possible the drain pump is defective , check voltage to the pump during the drain cycle to confirm that the program controller is outputting voltage to the pump.
Check this link: drain pump replacement
Jul 04, 2012 | Frigidaire Affinity ATF7000E Front Load...
My frigidaire affinity washer doesnt spin during the rinse cycle.
Hi javierc569,
Before the Spin Cycle should start, all water must be drained out of the machine. If it does not start, it could likely mean the Drain pump may be clogged. Please follow my below tip on the fix:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER...
If this does not help, the drain pump may be faulty.
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Jul 26, 2011 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire Affinity Glacier Stackable upright washer. Washer will not agitate and makes a buzzing sound from the pump that extracts water from the drum. Water collects and remains in bottom of washer.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 29, 2010 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
Fabric softener will not drain
Nov 25, 2009 | Frigidaire Affinity ATF7000E Front Load...
Water level too low. clother wet. No water visible or suds. What is wrong.
Your expectations are based on top load washers.
Front load washers use only a very little water, and suds are an enemy. (HE soaps are designed to clean without suds. Suds are really for show and cause drag on the wash tub during spin.) If you start a load with no clothes, you will see that the water level never gets above a couple inches in the tub. That is the correct water level for front loading machines. PS. Because of the low water use, make sure you use very little soap. (one to two tablespoons per load only!)
Aug 12, 2009 | Frigidaire Affinity ATF7000E Front Load...
How to diagnose
Sounds like your motor is blown. That's going to require a repairman.
Mar 31, 2009 | Frigidaire Affinity ATF7000ES Front Load...
My front load washer affinity pauses 3 or 4 times during a cycle
the unit is waiting for something,,,like water ,,,or a slow drain..you must see where the unit is ,in the cycles,,and make sure that action the unit is trying to do is able to do...onthejob
Jan 18, 2009 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire FAFS4473LW Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
