Question about Jenn-Air JMV8208A Microwave Oven
JMB8208BA has no power, What fuses could be blown?
The microwave lost power. The nothing works, like it is unplugged. I tested the bus fuses, fine. Thermal Fuses behind control panel, one has continuity the other does not, but the new thermal fuse also did not have continuity.
  • 5 Answers
SOURCE: No power on Jenn-Air JMC 7000 ADB Microwave
I have a different Jenn-Air built in microwave & oven combination but I'm sure my solution will work for you as well.
My microwave was plugged into an outlet located on the top of the oven. This outlet has a "circuit breaker" that tripped while we were using the self cleaning feature on the oven. You just need to reset the breaker button right next to the wall oven outlet. Why it tripped is a mystery since the microwave was not in use at the time. Bad design.
Of course, getting to the reset button is your only challenge. You need to pull the microwave and oven out of the wall/cabinetry in order to get to it. The unit is heavy so you will need help. Or, call a certified repairman and they should be able to do this for you in 30 minutes or less so the service call should not run you more than @$85 if it is no longer under warranty.
I would also suggest you contact Jenn-Air to complain about this issue and seek reimbursement from them if necessary.
Posted on Jan 04, 2008
SOURCE: Jenn-Air Microwave - no power
Had the same problem. Removed the unit (snapping off the upper and lower trim rings was a chore but they do snap off) and tested the power. Plug behind the unit was good. Pulled the cover and checked the thermal fuse with ohm meter. No good. Replaced fuse, microwave would run for a second, then light goes dim and it buzzes, then it blew the fuse. Per above suspected Capacitor. Changed that, and we are back up and running. Thanks!!
Posted on Sep 27, 2008
  • 4088 Answers
SOURCE: HOW TO REPLACE BLOWN FUSE
Look for a reset button on the back--push to reset. If trips again, unit has probable short.
Posted on Jul 12, 2009
  • 949 Answers
SOURCE: I have a blown internal fuse on my JennAir M170b
The information on the fuse is the maximum rating. The holder may not match the rating.
The 'A' is the very important part of the size. You will need a 15 Amp fuse. The best fuse to use is 'ceramic'. You can find them at Radio Shack in the back of the store there are drawers with electrical parts.
15 Amp ceramic
Posted on Jun 10, 2010
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave oven was very hot and shut down with blank display.
For future reference, I always recommend that you turn on the microwave's hood vent exhaust fan whenever you're cooking on the stovetop or oven.
Depending on the brand and model, there will be either a thermal cutout or thermostat on or near the magnetron. There is also one on top of the oven chassis ceiling, but under the outer cover.
Either device may have opened.
In many brands there is a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Accessing some components (especially the oven cavity thermostat / thermal cutout) for testing and possible replacement will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
You can download owner's manuals and installation instructions for several brands (including Amana, Frigidaire, Jenn-Air, Kitchenaid, Litton, Maytag, Roper, Tappan, Thermador and Whirlpool) here.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer
Posted on Jun 26, 2010
Testimonial: "Tnx. 20A brkr. on therm. oven tripped."
Whirlpool over the counter microwave stopped working
SEE THE steps and fix it. and diagrams attached.use the DVOM.God bless you
Line Fuse
Every microwave oven has a line fuse. This fuse is designed to blow if too much current is drawn through the microwave circuitry. The fuse can be replaced, but the underlying issue should still be investigated and resolved. Otherwise the new fuse will blow also.
Main Control Board
If the microwave is not working the main control board may be defective. This is not common. When a microwave stops working the problem is usually the line fuse or within the high voltage circuit; either the high voltage capacitor, diode, transformer or magnetron.
Thermal Fuse
If the microwave is not working the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Thermoprotector
If the microwave is not working the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown2_6_2013_8_43_03_pm.gif2_6_2013_8_43_37_pm.jpg
Feb 06, 2013 | Microwave Ovens
GE microwave oven model#JVM1441BH04 when you close door on switch activates and oven comes on. Only goes off when door is opened.
HELLO.
the problem your are experiencing with your microwave oven is a failed interlock switch.
Be careful when closing your microwave door. Slamming the door too hard is one of the main reasons that the interlock switch is damaged.
Slamming the microwave door shut can easily blow the microwave fuse, but they can also blow due to problems with the interlock switches.
A microwave oven will not function until the fuse is replaced.
Instruction on how to replace fuse on microwave.
1. Unplug the microwave from the electrical outlet to prevent electrocution. Place the microwave in a well-lit area to be able to locate the fuse.
2. Use a screwdriver to remove the outer cabinet of the microwave, and follow the power cord to the fuse. The fuse is located 2 to 3 inches within the microwave and is attached to the power board.
3. Observe the fuse to determine if it is blown. Blown glass fuses will produce burn marks on nearby surfaces, or the internal fuse wire will be black and melted, while ceramic fuses show no outward appearance of being blown.
4. Determine if a ceramic fuse is blown by testing it with an ohmmeter. If the ohmmeter reads zero ohms, your fuse is not blown. Other readings on the ohmmeter show that your fuse is blown.
5. Replace the blown fuse by popping it out of its holder, and snapping a new fuse in its place. Tighten the fuse clips by squeezing them together with your fingers.
6. Replace the outer cabinet of the microwave, and plug the microwave back into the electrical outlet. Test the microwave to see if it's working properly.
thanks.
Sep 22, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My old GE Spacemaker II microwave (JEM21K001) died. I was using it, heard a little pop, and it lost all power. Is this something simple to fix like replacing a fuse or is it bulk trash at this point?
HELLO.
take on these steps to solve the problem.
Check if there is electric power on wall outlet.
If the microwave plug has fuse,check if it has not burnt.if these are okay there is need to take the last step.
things needed
1.Screwdriver
2.Ohmmeter
3.New fuse
Thanks.
Sep 18, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE over range microwave. It work fine until one day the power goes out n nothing seem to work. Could it be a blown fuse or it's time to replace a new one. Thanks
first check the fuse in the plug, if thats ok, then there is a fuse in the microwave itself that could have blown, have that checked out first.
Aug 16, 2011 | Microwave Ovens
Nothing happens. it death. was working fine. an them .. the next day nothing ...
Sorry to read about your problem, I hope this helps you out.
here are some problems you may have.
  1. No power to outlet (blown fuse or tripped breaker or GFCI).
  2. Blown main fuse - likely due to other problems.
  3. Open thermal protector or thermal fuse.
  4. Defective controller or its power suppy
Microwaves must be serviced by technicians due to the inherent dangers involved in repairing these appliances. Internal capacitors can retain a lethal electrical charge even though the unit is completely unplugged. A microwave radiation leakage test must be performed on the unit following any internal component repair.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 05, 2011 | Frigidaire FMCB115GC Microwave Oven
There seems to be no power. No clock. no nothing. It was working fine and then jut stopped. Circuit is not tripped. I tried unplugging and plugging again.
most likely you will have to remove the louvers or trim above the cooking cavity to get to the fuse, look for screws holding the trim/louvers on, if no screws are apparent, the piece may slide to the left or right and pop off.
Unplug your microwave. Although it might seem like no electrical current could possibly be running through your appliance, it could still have stored electrical current somewhere in the system. Be safe rather than sorry and unplug it before you begin.
  • 2
    Find the wiring diagram for your model of GE microwave. You can contact GE directly to get this if you cannot locate your owner's manual. Note the fuse locations and get a screwdriver. Some GE fuses are located under the louvers, while others are located in the door.
  • 3
    Open up the microwave and locate the blown fuse. Sometimes you cannot determine a blown fuse by visual inspection so check it with a multimeter for continuity across the terminals.
  • 4
    Replace the blown fuse. Go to your local hardware store and pick up a matching fuse. Make sure you check the model numbers of the fuse as well to be sure you get the right component. Install the new fuse and put everything back together.
  • 5
    Check the continuity of the circuit if you continue to have power problems. If you have a problem with continuity in the circuit, then you may have a bigger problem than just a blown fuse. Sometimes a power surge will fry a GE microwave's circuit board, which you will need to replace.
  • Dec 04, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
    Dead microwave, after power surge
    look for a ceramic fuse in a fuse holder. probably 15 amp or 20 amp. if this is blown (and likely is) the micro won't work at all.
    Oct 16, 2009 | Microwave Ovens
    No power to microwave
    Hi
    When your microwave oven doesn't work at all, it means interior fuse inside the microwave has blown (usually a part inside the microwave makes this fuse blow). Sometimes a bad fuse holder inside the microwave cannot hold the fuse tight enough and the fuse will blow as well. If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work. It can also be due to a stuck or faulty door switch which might have blown the interior microwave fuse.
    Please do rate the solution and revert for further assistance.
    Thanks
    Rylee
    Sep 14, 2009 | Microwave Ovens
    Just quit. No power, no display....nothing
    there are several possible causes, check voltage at outlet
    check the 20 amp bus fuse on the main board ohm out the cavity thermostat, replace the bad part
    Sep 10, 2009 | Samsung MS1040BB Microwave Oven
    Lost power suddenly
    Could be; replacement fuses avail @ RadioShack or a similar place for a few bucks, so it's worth trying. Just remove the outer casing, look for the white plastic snap-on container (might say "FUSE" on the side). See this also:
    http://www.partselect.com/microwave+replace-fuse+repair.htm
    Jan 17, 2008 | Emerson MW8102SS 1100 Watts Microwave Oven
    Jenn-Air JMV8208A  Microwave Oven Logo
    41 people viewed this question
    Top Jenn-Air Microwave Ovens Experts
    William Miller
    William Miller
    Dennis Boxerman
    Are you a Jenn-Air Microwave Oven Expert? Answer questions, earn points and help others
