Question about Exercise & Fitness
Jillian cross train manual - Exercise & Fitness
Can't get the top frame to extend even though i pull the knob out.
I am sorry I do not know how to help. But may I ask if you happen to have the assembly instructions still that I could use? I lost mine when I moved before I could put it together. Thanks.
Apr 19, 2014 | Jillian Michaels Ultimate Body Shop
Do we need to follow some any diet plan along with Jillian Michaels Body Revolution Training System?
Every workout needs a diet plan to follow in fact it is important without a diet plan doing work out is use less. I've been following this Jillian Michaels Body Revolution Training System since a long time and in it they recommend a diet plan which we have to follow.
Source
http://productreviewandrate.com/jillian-michaels-body-revolution-complete-body-transformation/
Feb 06, 2013 | Majesco Jillian Michaels Fitness Ultimatum...
Need diagram for hooking up #252 Lionel Crossing Gate
Here's a link to the Service Manual to the 252 Crossing gate.
http://www.lionel.com/media/servicedocuments/71-2714-250.pdf
Dec 31, 2012 | Lionel O 27 252 Auto Crossing Gate
The gate stays down when the power to the train is on
The breaks should be on one of the outside tracks along with a wire to the gate and the ground wire from the transformer is attached to the other outside track. Power wire is attached to the center track and the power terminal on the crossing gate. When the train passes the break the metal wheels connect the ground rail to the rail with the break that is wired to the gate. This completes the circuit and the gate goes down. Once the train passes the other break the connection is lost and the gate goes up.
Dec 04, 2011 | Lionel Auto Crossing Gate
I am looking for a manual for a Tunturi C20 Cross trainer
http://tunturi.crealisten.com/js/admin/kfm/get.php?id=292
May 15, 2010 | Exercise & Fitness
Jillian Michaels won't allow Wii Balance Board for weigh in
Actually, I had the same problem and discovered that you have to have the wii remote in your hand and that you must push the A button once you're on the board. Otherwise it just keeps telling you that you're moving too much.
Feb 08, 2009 | Majesco Jillian Michaels Fitness Ultimatum...
Exercise & Fitness Logo
62 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
