Question about Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series - Sens - A - Speed Walk Behind Mower - 10685
Have Lawnboy Kohler 149cc smart choke 6.5ft lbs engine bought last year won't start doesn't seem to be firing?
    Top Expert:
  • Tecumseh Master
  • 9,098 Answers
REMOVE THE SPARK PLUG, RECONNECT THE CABLE AND WHILE THE SPARK PLUG IS RESTING ON THE BLOC OPERATE THE STARTING PROCEDURE AND SEE IF THE PLUG IS SPARKING.
Posted on Jun 20, 2015
My toro recycler 6.75 ft-lbs torque, 149cc , self propelled .powered by Kohler , will start then it sounds like the motor is running slow/fast slow/fast then it stops.is a screw missing L of gas fill?
If its one of the guaranteed to start mower they have had a lot of carburetor problems and needs to got to shop for warranty or replacement.
May 26, 2015 | Toro Garden
My Kohler Command 20 HP running fine, shut down, won't restart. How should I troubleshoot this problem?
check for fuel try starting fluid if it fires on that then you have spark if it does not then you have a spark problem and seeing the command engine has two coils check the safety switches on the mower side
Aug 11, 2012 | Garden
Pull cord pulls hard won't start
Remove the top engine flywheel & pull cord cover
Most likely dirty,as well as worn out. or the cord
is in the wrong place,you will see that,once apart
You can work on it some & down the road
get a new one if you have to
Jun 11, 2012 | Husqvarna 6021P 21-Inch 149cc Kohler XT-6...
Husqvarna 6021p won't start
Make sure spark plug wire is connected and that plug is not blackened and fouled out. Also check your fuel filter (plugged?), the handbar safety lever & it pull cable and make sure it is opening the breather assembly down at the motor or closing the proper switch (unsure of the setup) Those are typically the most common problems. Good Luck
Jun 07, 2012 | Husqvarna 6021P 21-Inch 149cc Kohler XT-6...
Kohler 149 cc engine won't start seems to be getting no fuel
This may not fix your problem but it does deal with that engine. I just tried to replace the spark plug in that engine and it took me 5 hours. The Kohler plug in the engine that came from the factory cannot be found in traditional stores and it is a strange size, 11/16 or 12 mm. The Kohler plug is #1413211. I could not find a match in a book. Divine intervention lead me to a place where they were fixing the Kohler 149cc engine that had the same plug in it that mines did. I discovered that a Champion 8815 does fit the engine but it takes a 18mm socket. It did fix the problem and the mower works. Hopefully this will save someone my hassles.
Apr 28, 2012 | Garden
Toro choke doesn't work
try cleaning out the carburator.
May 23, 2017 | Toro Lawn Mower With Toro Power Tools
Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series -  Sens - A - Speed Walk Behind Mower - 10685 Logo
1,190 people viewed this question
Top Tecumseh Garden Experts
Mike Squire
lnbn1975
Rick Oudette
Rick Oudette
Level 1 Expert
Are you a Tecumseh Garden Expert? Answer questions, earn points and help others
