Question about Troy Bilt 31cc Quickshift Blowervac, Model No. Tb310qs
How to measure 2 stroke oil gas - Troy Bilt 31cc Quickshift Blowervac, Model No. Tb310qs
  • 1,057 Answers
Depending on the mix of oil to gas you can purchase a small bottle to add to the gas. I believe it is 8oz. to a gal. of gas. This should give you approx. 50:1 ratio. Hope this helps.
Posted on Oct 19, 2016
What's the gas to be oil mixed at for McCullough blower B256
When using McCulloch two stroke oils, the gasoline to oil mix ratio is 40:1 (1-gallon of gasoline to 3.2oz. of McCulloch oil). Oil is offered in pre measured 3.2oz containers to mix with 1 gallon of fuel. Oil is offered in pre measured 6.4oz containers to mix with 2 gallons of fuel. Other pre measured and bulk oil ...
http://husqvarna.custhelp.com/app/answers/detail/a_id/844/~/product-support---what-is-the-correct-fuel-%2F-oil-mix-ratio-for-mcculloch
User manuals
Mar 28, 2018 | Garden
What kind of trimmer is this? 2 stroke or 4 stroke? Is it just gas or a mixture? If a mixture, what type?
We would need a make and model to be able to tell you this. NORMALLY, if a two stroke, the mix is stamped into the gas cap.
If it is a two stroke, you use two stroke oil, mixed to the correct amount. Again NORMALLY you are supplied with a measure to put the oil in with one gallon of gas.
May 02, 2016 | Garden
What is the gas oil mixture ratio 40:1 and 2 cycle engine oil
40 parts of fuel to 1 part oil
that is for example 40 litres of fuel to 1 litre of oil
most 2 stroke oil bottles have the measure required for the container size
May 17, 2015 | Garden
I can't find were to put the oil on the 1000w 2 stroke generator
Hi, For a 2 stroke you will not need oil in the engine. When you mix the fuel you add oil in the gas.
See the owners manual for details.
Jul 22, 2011 | Watts 1000w 2 Stroke 1000 Portable Camp...
The person I bought it off said it takes 50 to 1 don't know how to measure that
50 to 1 means that for every 1 unit of (2 Stroke) oil you use 50 of the same units of petrol. Most 2 stroke oil bottles have a measure on the side which you use to measure how much oil you're using so for 5 Litres of petrol (approx 1 gallon) you would use 100ml of oil.
50 to 1 which is usually written as 50:1 is a very light mix. Husqvarna saws use 40:1. You need to use good quality 2 stroke oil from tool hire shops rather than the cheaper stuff you can buy at petrol service stations. Some makes of 2 stroke oil, like Stihl, have a measuring cup on them with ratios marked on the side. To fill them you take the cap off the measuring cup and fill to the mark at 50:1 by squeezing the oil bottle. Then pour that into 5 litres of petrol. You can also buy mixing bottles in some hardware stores with ratios marked on them. You fill the oil up to the mark 50:1 and then fill it up with petrol to get the right mix.
Dec 23, 2010 | Garden
WHAT TYPE OF FUEL, STRAIGHT OR OIL/FUEL MIX & WHAT PROPORTIONS ?
Determine if your engine is a two-stroke or a four-stroke. Check the gas tank on your lawnmower or the owner's manual to determine what type of engine you have.
Read the label of your two-stroke oil. Follow the directions on the package to ensure the right mix.
Measure and pour the gasoline in to the empty gas can.
Add four ounces of two-stroke oil per each gallon of gas.
Replace the cap on the gas can and shake the oil and gas to mix. Add fuel to your engine.
Take care.
Jun 01, 2010 | Garden
What is the gas oil mixture for the 2 hp craftsman tiller One gallon of gas to ??? what type oil and how much per gallon of regular unleaded gas
You want 2 stroke oil, if it uses premix. You can buy little bottles of two stroke oil that are the exact amount you need for a a gallon of gas, or you can buy bottles with built in measurers to measure for whatever amount of gas. I usually use a 32:1 or 40:1 ratio on my equipment. You will find the two stroke oil in the lawn and garden section, automotive section, and in the marine section of most super stores (i.e. Walmart)
Apr 20, 2010 | Garden
How much is 25 1 for a 2 stroke fuel mix
25 ounces of gas / 1 ounce of oil . many places sell measures than let you measure oil to add per gallon of gas .
Mar 17, 2010 | Boating
MY MAKITA DPC6410 PETROL SAW IS RUNNING SMOKEY
It uses 2 stroke oil during combustion as it is a 2 stroke powered engine..Sometimes it may be a small deposit of oil and the bottom of the gas container which causes this smoke or else you may have added a bit more oil than needed in the fuel..I assume it is a 2 stroke engine and also note these do give out a little bit of smoke..
Dec 08, 2009 | Makita DPC6410 64cc 12" Power Cutter
I dont have the manual and Im not sure what ype of oil I should put on this chain saw. On the left The nob sais oil (which kind?) and on the right side it sais oil/gas mix (which kind?) what do i put on...
The Left knob needs chain oil. Available in most hardware stores. The right is gas mixed with 2 stroke motor oil. Usually a 50:1 mix. Ie. 50 parts gas to 1 part oil. 2 stroke oil comes with a built in measuring tool and directions printed on the bottle.
Jun 03, 2009 | Garden
Troy Bilt 31cc Quickshift Blowervac, Model No. Tb310qs Logo
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
