Question about Motorola Mobility ATRIX HD MB886 Android Smartphone
SITTING AT MY DESK WITH MY PHONE PLUGGED IN AND WENT TO USE IT AND THE SCREEN IS BLACK AND I CANT GET IT TO POWER UP. I DO HAVE A GREEN FLASH ONCE IN A WHILE. ANY THOUGHTS ?
THE SCREEN IS DARK. I CANNOT TELL IF IT IS EVEN ON. I PUSH THE POWER BUTTON AND IT DOES NOT TURN THE PHONE ON OF OFF. IT WAS ON WHEN I PLUGGED IT IN TO CHARGE IT. BUT WHEN I CAME BACK 20 MINUTES LATTER TO USE IT IT WAS DARK. I THOUGHT MAYBE IT HAD SHUT OFF SO I HELD THE POWER BUTTON AND IT VIBRATED ABOUT 6 TIMES AND THEN JUST STOPPED. I STILL HAVE IT PLUGGED IN AND I GET A GREEN FLASH LIKE IT IS CHARGING ONCE IN A WHILE. ANY THOUGHTS ? YESTURDAY I HAD TROUBLE WITH SENDING EMAILS. I TURNED IT OF AND RE STARTED IT AND THEY ALL WENT THRU VERY FAST AND I RECEIVED OTHERS THAT WERE SENT TO ME VERY FAST TILL I GOT THEM ALL.
  • Official Brand Answer
  • 3,100 Answers
I would contact motorola http://www.motorola.com/support or go to http://forums.motorola.com
Posted on May 11, 2014
ryanriopel28
  • 130 Answers
SOURCE: help my screen is white!
Did you try taking the battery out for a couple minutes, putting it back in, and trying again?
Posted on Aug 18, 2007
  • 4102 Answers
SOURCE: wont charge or is locked
if you plug the charger in and you can see the battery bars going up and down then it is phone problem if the scrren is blank then it is either the charger but if you have a car charger aswell and both chargers worked before then it is probably the phone that has a problem check where the charger plugs in that their is nothing blocking the terminals like fluff or bit of paper check that none of the terminals are bent or coroded if you have used phone in rain they might have got coroded this can be solved by cleaning the terminals on the charging part of the phone but be carefull when you do this not to wreck any thing check the charger make sure nothing bent or blocking the charge the problem with these phone is the pins on the bottom where the charger plugs in these get damaged really easily and they can be replaced but will have to take to phone shop and get repaired hope this is some help to you....................................
Posted on Nov 15, 2007
  • 111 Answers
SOURCE: blank or black screen
there is a problem with the flex..might be damaged..have it replaced by a cellphone technician
Posted on Jan 28, 2008
SOURCE: Battery Too Dead to Charge?
The issue is probably not the battery but the charging port. I'm having the same issue. I happen to have Motorola Phone Tools on my computer. It works with the W385 but sometimes doesn't recognize the phone. Battery has 2 bars. If I wiggle the cord, it will recognize it. Then 4 seconds later, lose the connection. I already replaced this phone 5 months ago for the same issue.
I think the problem is the charging port is not working.
Posted on Jan 21, 2009
kaseybaldwin
SOURCE: motorzor
I NEED MY PHONE TO TURN ON. IT POWERS UP AND SHOWS THERE IS NO BATTERY CHARGE AND KEEPS BLINKING "SAMSUNG", BUT WON'T GO ANY FURTHER THAN THAT. I PUT THE BATTERY IN ANOTHER PHONE THINKING I FRIED THE BATTERY, BUT IT WORKS FINE AND I WAS ABLE TO TURN AN OLDER PHONE ON TO USE UNTIL I FIGURE THIS PHONE OUT.
Posted on Dec 11, 2013
I have rooted my phone all was going great went to download muiu rom and phone went to samsung screen then to black screen then samsung then black repeatedly. No programs will recognize my phone on...
Hi Michele. Thank you for choosing my Android service on Fixya. Im sorry for the late response.
If you're stuck when flashing then do the following:
1) Power down/turn off the phone.
2) Unplug it from the computer
3) take out the battery.
4)Put the battery back in, but dont power on yet.
5)Put your fingers firmly on both VOLUME buttons and the POWER button and let the screen flash the SAMSUNG logo once, keep holding and when it shows the samsung logo the second time let go of all the buttons and leave the phone alone.
6) You should be in Red CWM Recovery and.............you've done it.
You can now restore or fix your phone.
If it didnt work then your timing is off. You can try again
I hope that this works for you. It should.
Thanks.
Oct 06, 2011 | Samsung Infuse 4G Smartphone
Not able to turn it on. for no apparent reason the screen was black after setting overnight. The pilot light was on. tapped the space bar a couple of times thinking the computer would wake up and desk top...
I have the same monitor & just had same problem. Did you find a solution to your problem? This is the second time my monitor has done this. The first time I had problem i unplugged it and disconnected it from pc. Plugged it into power source and blue pilot light came on then went off. I did see the LG logo on screen before it shut down. After several times doing this and pressing the power switch repeatedly it seemed to reset and recognized it was not receiving a signal and indicated this. I then reconnected monitor to pc and all appeared to work fine for several days. Now I again have same problem after sitting over night.
Dec 02, 2009 | LG W2252TQ Monitor
Installing battery in tom tom 910. Unit non-functional.
#1
Insert your ( memory card , flash disk , cellphone , .... ) into your computer.
#2
Open up 'My Computer'. You should see it under the list of available drives.
#3
Check its contents first to make sure that you have the right drive.
#4
In 'My Computer', right-click on the drive and choose 'Format'.
#5
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
#6
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
May 28, 2009 | Tomtom GO 910 GPS Receiver
Reassembly problems.
WOW it goes beyond my understanding why anyone takes the bios or bios battery out it dosnt reset anything it just means youve lost your bios and need to re flash the bios again which without sitting infront of your computer i cant do. the first thing i would recomend is strip it all right down to basic so that the screen is connected the power supply and a keyboard if it dosent work then you got a buggerd motherboard
Apr 02, 2009 | ASUS M2N-E SLi Motherboard
Blank Screen problems
go ahead the workshop and figure out the problem ... this is common problem nowadays since not every n85 is good in quality so i think u was the unlucky who bought the low quality n-85 key un-sensitive is a very common problem with n-85 ..but not so serious..the black screen i think is ur ram overload or something... so the only way u can solve is go ahead the workshop
=D
Mar 15, 2009 | Nokia N85 Cellular Phone
Black Screen on Razr V3
at first try changing Software of your cell. If the problem not fixed, check disply IC,Connector and finally the disply
Dec 15, 2008 | Motorola Mobility RAZR V3
Black screen
Hey... friend,
It's seems your backlight inverter is burnt out...need to replaced a new inverter. Visit this site @ www.3rd-rocks.com There's a replacement parts for your FP988D LCD. Have a nice day!
Aug 05, 2008 | Fuji FP-988D 19" Flat Panel LCD Monitor
Picture gone
Is the set completly dead...does the green light flash then go off. or when you plug it up does it come on for a moment?
Jan 02, 2008 | RCA HD52W56 52" Rear Projection HDTV
Motorola Mobility ATRIX HD MB886 Android Smartphone Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
