Question about Garden
Bought lawnboy 149cc smart choke last year new gas / oil doesn't seem to be firing. Where is sparkplug?
3 Suggested Answers
  • 86 Answers
SOURCE: what is the 2 cycle oil to gas mixture for a 2 cycle lawnboy
20:1 gas to oil is a good place to start. Some mowers thin down to 80:1. If you can tell me the model of the mower I can be more specific, but starting at 20:1 will assure you have adequate protection for the engine. If it's exhausting lots of oil smoke after it has warmed up; you can cut back a little each time until you have minor oil smoke.
at 20:1 you need to add 6.4 ounces of oil to one gallon of gas.
Here's a nifty calculator for various ratios:
http://www.csgnetwork.com/oilfuelcalc.html
Enter 1 gallon of gas, then change the ratio number and then press calculate and the number of ounces per gallon will be displayed.
Posted on Mar 29, 2009
  • 16 Answers
SOURCE: bought yard machine lawnmower new lest than a year
sounds like you may need a new solenoid switch or starter switch I would check them frist hope that helps
Posted on Aug 28, 2009
Testimonial: "very good advice and clear to the point"
Have Lawnboy Kohler 149cc smart choke 6.5ft lbs engine bought last year won't start doesn't seem to be firing?
REMOVE THE SPARK PLUG, RECONNECT THE CABLE AND WHILE THE SPARK PLUG IS RESTING ON THE BLOC OPERATE THE STARTING PROCEDURE AND SEE IF THE PLUG IS SPARKING.
May 09, 2014 | Tecumseh Lawn Boy Push Mowers Insight...
Husqvarna 6021p won't start
Make sure spark plug wire is connected and that plug is not blackened and fouled out. Also check your fuel filter (plugged?), the handbar safety lever & it pull cable and make sure it is opening the breather assembly down at the motor or closing the proper switch (unsure of the setup) Those are typically the most common problems. Good Luck
Jun 07, 2012 | Husqvarna 6021P 21-Inch 149cc Kohler XT-6...
Poulan prolink pp335 wont start
In case anyone else hits this question, I had this weed eater and all of the attachments. I had it in my garage for a good 7 years, and it had gas in it 7 years ago.. I've known for some time that it now had no gas in it & that it wouldn't be easy to start if it worked at all.. I put some normal gas in it and dripped a bit of oil into the gas because i didn't have a can properly mixed and didn't want to oil up my lawn mower gas.. I had a guy cutting my lawn for the past 7 years but he recently disappeared..
I primed the weed eater and attempted to start it for a good 20 minutes yesterday to no joy.. I put it away and figured i'd try it again and more in depth today when I had more time. I wanted to take the spark plug out and make sure it was clean, etc.
On attempting to remove the spark plug, I couldn't find a wrench or socket that would work to do so, so I just reconnected spark plug cable and figured I'd give the pull start method another try.. I pumped more gas into the primer and attempted to start it normally a few times.. It wouldn't even attempt to fire. Just for fun since I was going to have to throw this and tons of never-been-opened attachments away, i decided to try something goofy (in my opinion) and squeezed the trigger as far as it would go (which disengages the choke feature..) and gave it a few pulls on the cord.. It attempted to fire a few times, then it fired! It worked very well although it was a little bit thick on the smoke for a bit..
Maybe this answer will help someone else who hits the problem of leaving gas in a weed eater for years.. don't use the choke feature to start it.. start it at full throttle with the primer perhaps flooded a little bit..
Apr 01, 2012 | Garden
Greetings all. Bought an 1983 Yamaha XJ650 Maxim late last year and love it. It ran great last fall and took it on a 2500 km road trip this June and it ran great. Two days after I got back it started...
Have you changed the oil and cleaned the air filter, after the fuel tap problem.
fuel in the oil can cause this symptom. the fuel ends up in the sump when the taps fail as yours did
also check choke is not stuck open, and battery is in good condition
Aug 15, 2011 | 1983 Yamaha XJ 650
This is a lawnboy mower about twenty years old and has run fine intil about a week ago. Now...after starting...It will surge up and down at full speed...then start to bog down unless throttle is placed...
drain all gas out of the tank and carb the new gas with 10% ethenal is ruining old gas engines after everything sits for a day install a plastic shut off valve in gas line. put high test gas with the seafoam then turn gas valve off after every use it will run good. then call your congressman and complain otherwise we will all be replacing any engine older than 4 years old
Sep 15, 2010 | Garden
I have a Honda XR250 that I am having trouble getting started. I think it is a '96, but honestly I am unsure. It's an MD30 frame bought secondhand in Africa. The frame actually also says Honda XR250S,...
i had the same pronlem this year cleaned the carb emtied the gas changed the oil and it would run but when i got on it it would cough and not produce power so i took the sparkplug outn filed it down and put some gas on it it fired right up n ran great for about 20 min so i replaced the sparkplug n it runs great now
Mar 15, 2010 | 1992 Honda XR 250 R
Engine cuts out as you accelerrate when in nuetral.
You might have a coil problem or you might need a sparkplug cupor you need to synchronize your carbs.get your valves check also.
Mar 24, 2009 | 1999 Yamaha FZS 600 Fazer
Will not start - brand new
i bought a new dirtbike as a kid n same thing.it turned out ,it needed to be a synthedic oil in the mix.try seeing for spark to begin with by putting sparkplug in the wire n touching diode to the engine block while pulling the cord.thats a good starting point to diagnosing your problem.maybe try warming it up in the house then try starting it with no choke needed.the saws i ve used needed you to give it throttle after you pull,n no throttle with choke.
Mar 12, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Garden Logo
13 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
