Question about Craftsman Saws
Murana mitre saw
How to replace safety guard
thabrain
  • 76 Answers
SOURCE: How to replace lockdown pin DW708 12" sliding compound mitre saw
you are going to have to drill the inside pin out. be sure to center punch and drill a pilot hole. hope this helps
Posted on Oct 28, 2008
efs_perpends
  • 1996 Answers
SOURCE: I took the guard off the 10" Makita Mitre saw (spring loaded)!
Oh, you got it off. I bet you can put it back on again.
It's much easier if you take the blade off first. Then you'll be able to reach inside when you need to. Be patient, don't force it, and make sure when you get the spring reconnected properly that the guard moves freely out of the way when you chop, and returns when you raise the saw back up.
It's a bit of a trick, but I bet you can manage it..It's been awhile, but it seems to me there's a way to get the bolt started before you engage the tension on the spring...I'd have to have it in my hands to say exactly.
Here's a link to the exploded parts view at the Makita site, just in case. And it might help to have an extra pair of hands, or a piece of duct tape to hold the guard in place when you go to put the blade back on.
Posted on Apr 10, 2009
  • 8404 Answers
SOURCE: Compound mitre saw won't shut off unlss unplugged
Relace the switch.
I am presuming the lock button has not been inadvertently pressed ... Check that first.
The condition you deacrive is dangerous. Please fix it before you use it any more.
If you require additional assistance, let me know.
Otherwise, check RepairClonic.com for parts and technnical instruction from their crack crew.
Thanks for the opportunity to lend you a hand
a
Posted on Sep 26, 2009
  • 12 Answers
SOURCE: Mastercraft 10" compound mitre saw model #
Mastercraft's toll free help line is 1-800-689-9928. They will need your product code and are very helpful at getting you replacement parts.
Posted on Aug 31, 2010
puertobori
  • 7733 Answers
SOURCE: blade guard for Ryobi 254mm Slide Compound Mitre
Try at eReplacementParts.com : Power Tool Parts and Tool Repair Diagrams or ToolPartsDirect.com - Your Tool Repair Supply Store.
If you need more help come back.Post / thumbs / testimonial are welcome!
Posted on Nov 17, 2010
Replacing blade guard on a 1700W sliding mitre saw
There is an upper (fixed) blade guard and a lower (moving) blade guard which has the added complication of being connected to a linkage or mechanism to swivel the guard away from the workpiece as it approaches the cut.
Mostly careful inspection, once the blade has been removed, will show removal of the guards to be a faily intuitive process. It is inevitable some makes of saw will be more complex and in the absence of official detailed instructions, it will mean a process of removing clips and screws until the part falls off and then remembering what you did so you can put it back together with no parts left over.
Jun 12, 2016 | Saws
Where do I get a bushing for the guard on a 10 inch mcculloch mitre saw
You probably mean a Milwaukee mitre saw. McCulloch does not make a mitre saw. Go to eReplacementparts.com and enter your make and model number. If they don't have it, its probably not available anywhere. You'll have to go to a machine shop instead. Look it the yellow pages for "Machine Shop".
Oct 04, 2014 | Saws
HOW DO I CHANGE THE BLADE ON A 36-070C MITRE SAW
Not sure about the Delta. I've had both a Craftsman and a Dewalt. On both of those, the pivoting plastic guard pivots on a plate on the side of the metal guard. The plate isnt easy to see. You rotate the plastic guard all the way open and you see the edge of the plate held in place by a screw. Remove the screw and the plastic guard and the hub along with the plate it's mounted on can lift up an half inch or so--far enough to get the blade screw off the arbor.
There's a push button somewhere that locks the blade from turning so you can turn the screw in the center of the arbor with a wrench.
Sep 16, 2014 | Saws
Blade guard for power craft compound mitre saw WK 1200
Lows, Home Deport, Ace Hardware, Tractor Supply, Target, Wal-Mart. Kmart, about any major store. Harbor Fright. Etc.......
Jun 23, 2013 | Saws
Need to replace the blade on the saw. mastercraft 10" mitre saw. i've managed to loosen it but can't seem to get the blade out of the machine to put the new one in. what am i not doing?
Lifting the safety guard maybe? The blade will not pass through the opening with the guard down (it's one of the purposes of the guard).
Jun 13, 2011 | Garden
I have a ryobi 10" mitre saw and i took the guard
I don't know but if you have figured it out let me know. I have same prroblem.
Apr 19, 2011 | Ryobi 10 In Miter Saw With Laser
Mastercraft 10" compound mitre saw model # 55-6895A , broken plastic safety guard , can it be replaced serial #W034453
Aug 20, 2010 | Saws
Concept MS100 mitre saw blade guard dillema.
I have changed the blade a few times, There is no need to remove the spring, etc. All you do is remove the bolt holding the guard and rotate it counter clockwise and it exposes the blade.
I am looking for parts for this saw. Anyone know where to get them?
Jul 06, 2010 | Makita 10" Dual Bevel Sliding Compound...
I have a mastercraft mitre saw. The blade blocks midway when I am
The picture I could get only shows one side. From my experience, these guards operate using leverage, where a little motion results in a lot of movement to the guard. That means a little damage or wear in the linkage can make a big difference. A bushing may have shattered, or a pivot hole may be worn out. Reviews of this machine mention dust not going into the bag. Make sure dust is not jamming the guard works. Take care, having to move a guard while the blade is spinning is scary.
Mar 28, 2009 | Dewalt Mitre Saw Workstation
Saws Logo
44 people viewed this question
Top Craftsman Saws Experts
Mike
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
