What does error code f772 mean for a konica mfp?
4 Suggested Answers
  • 19 Answers
SOURCE: bizhub 350 error code
c3852 means low fuser(hot section) temp setting. hold down utility or stop key, then you should be abel to do trouble reset. if problem persist it would most likely be a lamp or a sensor, which will require a technician to come out.
Posted on Apr 16, 2008
  • 168 Answers
SOURCE: konica 3135 error code 41
41-3 Error Code is an Optical return problem. The Scanner is not returning back to home position like it should.
A common problem with this model machine is a small black gear on the drive motor cracks or ovals out. If you can locate this gear, you can try placing a drop of super glue on it and see if it will hold. This works if the gear is ovaled out. If it is cracked or split then you will need to replace this gear.
Hope this helps a little.
Feel free to post another question if you need more help.
Good luck,
Mac =)
Posted on Jun 26, 2008
acdr
  • 1913 Answers
SOURCE: Konica Minolta 1390MF Error
reset your printer settings to default configuration.also refix your ram intro slots.
Posted on Dec 28, 2008
When turn on the machine the error code c-c170 indicates
NVRAM and or MFP Board failure. Recommended you get a qualified Konica Minolta Tech out to correct. as The Firmware for the machine may need to be re-flashed. The firmware is at a secured website, for Konica Minolta Technicians. The board might also be bad. the NVRAM is memory that stores major info on the copier. The code is telling you not enough memory for the MFP board or that the MFP board is having issues. MFP are not cheap$$$$$$$$$$$$$$$$$$$.
Jun 11, 2015 | Konica Minolta Bizhub c203 Copier
How do I fix error code c-6740 on Konica Minolta c7000pro
C6704 Description Image input time out
Image data is not input from the scanner to the MFP board (MFPB). Remedy 1 Select [Service Mode] - [State Confirmation] - [Memory/HDD Adj.] - [Memory Bus Check] - [Scanner-Memory], and conduct the memory bus function. 2 Check the connectors between scanner section and MFPB for proper connection and correct as necessary. 3 Replace MFPB. 4 Replace CCDB.
Dec 09, 2014 | Konica Minolta bizhub Office Equipment &...
Bizhub C450 has error code C-F023
CF023
MsgQue OverFlow
An exceptional instance occurred due to the unexpected Parameter in the System F/W.
Relevant Electrical Components, Units, and Options - MFP Control Board (PWB-MFP)
Try to reset it. If it is still showing up, you should try a new firmware version. If it is not working with a new firmware, you should check all the connection to the MFP Control Board. In the worst case scenario, you should change the board. I hope a reset will do the job
Aug 23, 2014 | Konica Minolta bizhub C450P Laser Printer
Why C-FA14 error came in C364e Model MFP?
Any of the following boards may have gone bad. This Series of codes are call abort codes. MFP, Dual Scan Image Processing Board, Memory #1 and Memory#2. Recommend you have a qualified Konica Minolta Rep look at this problem
Jun 19, 2014 | Konica Minolta Office Equipment & Supplies
Error code 4701 for Konica Minolta bizhub pro C6500
- 4701 error
Communication fifo problem error 4702/4701 of 5500;6500;6501 konica minolta mfp printers
1) reseat all connectors in Ipb
2)image memery controle board
Inspite doing all these if the problem persists please reload the firm ware/flash firm ware.
Last one is to replace image memory board only .no need to replace prcb; overall status board; nvram
Jan 09, 2012 | Office Equipment & Supplies
C1220 and C350 Error codes
this error code means image data is not input from the image processing board(pwb-c) to the mfp control board(pwb-mfp)
so i would think it would have to be one of those two boards or the wiring going between those boards
Nov 21, 2009 | Konica Minolta Office Equipment & Supplies
My machine tries to initialize and before it finishes it gives an error message C0F32 what can I do
if this is a konica minolta c350 mfp that code means you have a abnormaly low toner density in your magenta IU
Nov 03, 2009 | Office Equipment & Supplies
Error code c-fb58
Hi Wazza,
CFB58 relates to an internal bus error on the MFP control board. To reset you simply turn the machine on/off (main swithc inside front door) If the fault reoccurs, you may need an engineer to flash your firmware/replace the MFP control board.
If it's the latter, I suspect it will be more cost effective to replace the machine. Average cost of a MFP board for your model is £1200.00
Hope this helps
Regards
Taminol
Apr 17, 2009 | Konica Minolta bizhub C250 All-In-One...
Erroe code
You post a wrong printer nr, you must have bizhub C350 not bizhub 350, beacause 350 doesnt have that kind of code.
In Bizhub C350 that code means:
C12C0: Hard disk recognition error
You have the following options:
- reinstall the hard disk
- change hard disk
or as a last chance change PWB-MFP
good luck
Feb 06, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
26 people viewed this question
jasbo
jasbo
