Question about Toastmaster 277 Belgian Waffle Maker
I have a green light and a red. what do they mean?
There is no on or off switch, just a red light and a green. when do I put the batter in and when is it done?
  • 2,119 Answers
Red means that it has power. Green means the heating element is on. The green light will cycle on and off as the thermostat controls the temperature. Allow the iron to heat til the green light goes off before adding batter. Watch for steam coming from the iron. When the steam stops the waffle should be done. Keep track of the time that it takes to cook. Experiment with cooking time for the best results.
Posted on Jul 30, 2014
There are 3 lights on the front of the Zanussi Freezone. The green one on the left doesn't light up. What does that indicate? The red light on the right is on constantly. Does this mean that the freezer is...
Starting the Appliance
Insert the plug into the wall socket. The green pilot light will illuminate to show that the appliance is switched on. The red alarm light will also illuminate until the freezer reaches the correct temperature.
Alarm Light
The red alarm light will illuminate when the temperature in the freezer is higher than the thermostat setting. This alarm light will illuminate if:
- The appliance has just been started.
- Fresh food has been put in the freezer.
- The lid has been left open, opened frequently or open for too long.
The red light will go out when the freezer has returned to the correct temperature
Dado
Oct 14, 2013 | Zanussi 14.62 cu. ft. / 414 liter Chest...
I bought a Utilitech Self Adjusting In-Wall Timer #0192773. The Timer has 4 wires....a black wire...a red wire...a green wire...and a white wire. The switch that I am replacing has 2 black wires and a bare...
The reason there is 2 black in the wall is because a standard line breaking switch was used. Meaning the hot side of the light was the black wire once broken light goes off. You would hook the black from switch to black in wall and white from switch to other black in wall green is ground and red put wire nut on. Red is for a 2 switch system. Where one of two switches in same room controls same light. Its not needed. Take caution when doing this trun light on goto breaker box and flip breakers till you find the right one that powers that light. once lights off then do your thing replacing.
May 06, 2011 | Intermatic Inc. ST01C Digital In-Wall...
Green and orange led ok but can not see anything
Most of the LED's colors are Green on/off switch, Red for IR light. When you take a look see in the eye piece what do you see, white, white on white, green 18mm image, or just plan nothing. stewbison. It could be number of things, battery OK, just because it lights the LED doesn't mean it has the power to iignite the image tube----try a new batter---If it's not this, there could a number of things that have stop operating.; such as, image intensifier tube, ccfl inverter, voltage multiplier, toloidal coil, control panel. Some of the NV devisies are micropressor control. stewbison
Mar 05, 2011 | Night Owl Optics Explorer NOCX3 Monocular
What does it mean if theres no green light
A green light should mean that it is not ON. red light generally means that power is reaching the device. green and sometimes yellow/orange is the working of the device. If you are not having the green light but have the red one on then the power is reaching the device but it is not ON may be because of the defective power on switch or whatever. You should concentrate on the switch.
Nov 20, 2009 | Dell A215 Computer Speakers
When connecting up to charge red light comes on 'power on' button on front and no charging happens - any ideas? thanks
What does indicator light mean?
  • Steady red light: Battery is charging.
  • Steady green light: Battery is fully charged.
  • Flashing red light: Battery needs charging.
  • Flashing green light: The music receiver is switched on.
  • Flashing red/green light: The music receiver is available to be added to your phone.
Aug 24, 2009 | Sony Ericsson T303 Mobile Phone (Shadow...
How to remove bathroom fan pull switch?it doesnt click
1 turn power off remove appropriate fuse
2 UNSCREW PROTECTIVE CAP
3 screws aqre visible they usually hold 3 wires
black green and red. if they have losts of black wound together it means they are in series with other lighyt switches. Ideally get an electrician in.
anyway unscrew the wires from their holders and attach a new swtch placing wires basck in the same congfig. RED is LIVE Black is RETURN ( Usually) and Green EARTH.
(Sometimes live and return may be blue and brown)
put cover back on replace fuse and turn power on and hope there is no "bang" because you put wires in wrong way
Jun 12, 2009 | Electrical Supplies
New fan light running continuosly
lets see if i can help you out here, okay . Red is your hot power wire, Green is the ground which is screwed to mounting plate, black is negative, meaning no power.... connect your wires by color Red to Red , Black to Black , And if there is a green coming from the ceiling connect to mounting plate of fixture or vise versa. Remember to use eletrical scew caps, on all connections and do not leave any wires uncovered. Basically all your doing is a seperation of a wire from wires as you seperate a wire cap it off. then move to the next set and do the same. red to red black to black green to mounting plate . YOU WIL NOT BLOW ANYTHING UP IF THERE IS A WRONG CONNECTION, if all wires are of color follow these steps, if no color switch one wire try switch and vise versa YOU can do it
Jun 02, 2009 | Frigidaire 13.7 cu. ft. / 388 liter...
Toastmaster 277 Belgian Waffle Maker Logo
272 people viewed this question
Top Toastmaster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Oscar Netto
Oscar Netto
Mohamed Ismail
Mohamed Ismail
Are you a Toastmaster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
