Question about Crafts & Hobbies
Maine: map and state simboles - Crafts & Hobbies
My Suzuki jimny stoped whiledriving
many suzuki have 2 baros, mine has 3.
one for altitude, inside ecu,
one for map TBI engine, (map sensor main 108 fails )
one for EGR map, to test EGR only. (my G16b has it)
we dont have 1.3 Jimny's here so can look it up for you.
but the FSM for your car (book) has this.
the P0108
is the main engine map sensor. (using usa fed rules for OBD2)
yours is EOBD rules. (im clueless with those)
that is used to calculate all air flow through the engine
it's output is stuck high,,
it's unplugged is my guess.
our map does 3.9V with the vacuum hose pulled. or just key on.
over 3.9v is illegal voltage and is bad map or unplugged.
when it goes to near 0v.volts at full vacuum 29"
this page may match your map for all voltages and states.
http://www.fixkick.com/sensors/my-map.html
that is my best idea here , lacking non USA books,
Apr 15, 2015 | 2007 Suzuki Jimny 1.3
Garmin troubleshooting
When updating your map you may have chosen a version that does not have your state.... like canada and eastern USA... etc... try reloading your map and select via mapsource the map that carries your state. Or install a 4 gb sd card with the full map if your nuvi has the card slot on the side... good luck
Sep 04, 2014 | Garmin nuvi 200W GPS
Garmin nuvi
Take a look at what map is on your unit. Press the wrench/tools icon on the main menu, then the map icon, then the map info button. Most likely, you do not have all of the states in the map and probably a limited region like lower 49 states, southwest or lower 49 states, northwest, etc. You will need to download the full US map. However be aware a full map may not fit on your unit and may have to put the map on an external SD card.
Sep 30, 2013 | Garmin Nuvi 350 Car GPS Receiver
Garmin nuvi 350
You may not have a complete US map on the unit. You may only have the NW SE OR NE states. AT the main menu, press the wrench/tools button, then the map icon and then the map info button. What does it say?
Sep 30, 2013 | Garmin nuvi 350 GPS Receiver
Garmin Nuvi 1450LMT, after entering a state, then attempting to "spell City" after entering city, and touching "done" unit indicates, "no matches found". For example, Minnesota, Minneapolis, unit...
Is the map turned on? At the main menu, press the system tools icon and press the map icon. Then press the map info button.
What does it say? Does a map show up and is there a checkmark in the box next to the map description? Also, if the map is for a certain area, say lower 49 states, SW, well you won't be able to find a city in the NE because the map is only showing a limited area. If you have ample memory on the unit or have a 2GB or larger SD card, installing the full US & Canada map is the way to go. Make sure the map installed on the unit covers where you are and where you may be going.
Sep 27, 2013 | Garmin Nuvi 1450LMT
How to input an address that is in France?
Many Garmin units have a menu item that shows a list of installed maps. The main map is usually located on the GPS's internal memory. Any additional is likely found on the SD card.
When you access the menu / setup and choose maps, you will see both maps. Make sure that you uncheck the map in the main memory (USA perhaps?) and check the map that holds the area you wish to use (Europe?).
When you view the maps on the GPS next time, you should see the maps for the selected area and be prompted for locations that make sense for that area. Simply reverse the steps above to get back to the main internal maps when you return.
I hope this helps!
May 29, 2013 | Garmin Nuvi 350 Car GPS Receiver
After updating my maps, it only show highways and main streets. how can i restore to its original state.
  1. Press the spanner symbol on the WHERE TO screen
  2. Press MAP
  3. Press MAP DETAIL and set it to maximum
  4. Press MAP INFO at the bottom of the screen and check that the map is selected. If not press the map name to select it.
I hope that solves your problem.
Dec 05, 2010 | Garmin StreetPilot c340 GPS Receiver
Canadian Postal codes cannot be entered
it has to be set in the right region (Canada, if the map is installed) by defualt, the 1212 is set for the lower 48 state in the usa.
to check or change the region
From the Main Menu, tap on the right arrow to access the second page of the Main Menu.
Tap on User Options.
Tap on Region.
Tap on the map region desired.
bill
Dec 31, 2009 | Magellan RoadMate™ 1212 Car GPS Receiver
Add Europe sd card to Garmin 660
No. When you plug in the SD card, the Nuvi will load the map from your SD card. Once you get to the main menu, select the wrench symbol, then the map symbol and then "map info". You should see both the US and Europe map. Make sure the Europe map is checked. You can uncheck the US map. This is how you switch between maps. The reason why you have to have the extra map on the SD card is because the Nuvi can only have one map on it's internal drive, one at a time.
However, backing up your US map is a good idea.
Good luck,
- Jim
Nov 21, 2008 | Garmin Nuvi 660 GPS Receiver
Crafts & Hobbies Logo
395 people viewed this question
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Debbie
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
