Question about Refrigerators
Maytag MZD2665HEQ won't change from ice to water
4 Suggested Answers
erpaalai
  • 999 Answers
SOURCE: Maytag Model MSD2651HEW - Changed Filter and
Was the pressure ok before you changed the filter? The water valve itself could be partially plugged or the supply line may be filling with minerals. Usually happens in the piercing tap used to attacc to the house line. Difficult to say for sure without seeing the way it is installed. If it was just the drinking water I would suggest the reservoir being froze up but since it affects both look at my initial comments...
Eric
Posted on Oct 12, 2009
SOURCE: The Maytag side by side
maytag mzd2665heq refridgerator not cooling. compressor is humming for a few seconds and then kicks off. im thinking maybe the starter compacitor is bad, but im no expert.
Any ideas?
thanks Dan
Posted on Dec 12, 2010
imufo2
  • 3773 Answers
SOURCE: Maytag MSD2651HEW only sends cubed ice - won't
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
If you still have trouble GO HERE:
hhttp://www.applianceaid.com/procedures.htm
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Posted on Oct 02, 2011
I have a Matag MSD2458GE refrigerator. Water dispenser on the door works but, the ice maker doesn't work at all. Seems no water reaching it. Needs new filter, but no ice before replace filter light.
According to your user's manual, "If water flow to the ice maker or dispenser decidedly decreases or if an objectionable taste or
odor returns,change the filter sooner than
recommended."
"Leave the refrigerator door open while removing and installing filters or plugs; this will prevent water
from flowing through the system and running into
the fresh food compartment.
• A newly installed water filter cartridge may cause
water to temporarily spurt from the dispenser"
Automatic ice maker not operating
the stop arm in OFF (up) position
•the water supply turned off
•the water pressure too low
•the freezer too warm
Ice dispenser not operating
ice jam in the dispenser
•ice maker not operating
• lock switch on (see page 11)
Water dispenser not operating
• water pressure too low
• lock switch on (see pg. 11
To locate an authorized service company in your area,contact the Maytag dealer from whom your appliance was purchased; or call Maytag
Appliances Sales Company,Maytag Customer Assistance at the number listed below. Should you not receive satisfactory warranty service,please
call or write:
Maytag Appliances Sales Company
Attn:CAIR
Center
P.O. Box 2370
Cleveland,TN 37320-2370
U.S.
1-800-688-9900
CANADA
1-800-688-2002
U.S. customers using TTY for deaf,hearing impaired or speech impaired,call 1-800-688-2080.
Feb 24, 2017 | Refrigerators
My Maytag M1TXEMMWWB00 (209 cu ft) Top Freezer Refrigerator will not make ice. I checked the solenoid where the water comes in to see if it has a current and it doesn't (no juice). I looked at the owners...
The ice maker tells the water valve to open so you will not see the power until the ice maker ask for water. Does the ice maker have ice remaining in the ice slots? If not then fill with tap water and after the water freezes and ice maker cycles dropping the ice into the ice bin if it does not refill with water then you will only need to change the=> 2315576 Water Inlet Valve If the ice maker does nothing you will need to change the ice maker=> 4317943 Ice Maker Assembly You can find trouble shooting info at Appliance 911
, Thanks John Tripp
Feb 19, 2014 | Maytag M1TXEMMWW (209 cu ft) Top Freezer...
Ice maker won't eject icre
you need to replace the ice maker because the heater inside the ice maker is broken thats way its not ejecting the ice
Jan 18, 2013 | Maytag Refrigerators
My Maytag msd2556ae will not dispense water throught the door. It makes ice just fine, and will dispense ice through the door, but not water. I've replaced the filter in the fridge, but no change.
There could be a blockage of its iced up. A complete defrost might fix it.
you'll have to leave it switched off with the doors open for 24 hrs.
Sep 01, 2012 | Maytag Refrigerators
My ice maker on Maytag MF12468AE stopped making ice. When I add water to the tray, the cubes form but are not ejected. Is the the water valve bad or is the entire ice maker itself bad?
The ice maker is bad and they have been discontinued by the manufacturer. Luckily, there is a replacement part that works in your machine, part number W10477228. The reason I say its bad is because it should have atleast ejected the ice that was made when you poured water in it if it were working properly. The only other thing it could be is that the temperature is not cold enough in the ice maker area, which is 10 degrees F or colder. If the temperature isn't at least that then the ice maker won't cycle at all.
Jun 05, 2012 | Maytag MFI2568AES Stainless Steel Bottom...
The switch on maytag water and ice dispenser won't turn off
It sounds like your micro switch on the dispensor is dirty or broken. if you can not find the micro switch the whole assy. part #13005705.
http://www.on-timeappliance.com/refrigeratorrepair.html
Mar 26, 2012 | Maytag Appliances Maytag 26 cu. ft....
The Maytag side by side MZD2665HEQ just start to pour water into the freezer compartment and into the icecube holder. What the problem????
Any ideas?
thanks Dan
Nov 09, 2010 | Maytag MSD2454G Side by Side Refrigerator
When water dispenser is pushed the water supply line rattles and very little water comes out. The water supply line has good pressure and the ice maker works. I also changed the filter.
Our water dispenser will work for about half a glass then the pressure immediately stops and the water flow goes to a small stream. Maytag MDZ2667HES Wide by Side. HELP! Filter was changed approx 3 months ago.
Oct 12, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Icemaker makes ice but wan't despense, also water wan't despense
i have model mfi2067aeb . the ice maker won't dump the ice. the arm is up that tells when the tray is full. can't get it down.
Jul 16, 2009 | Maytag MFI2067AES Stainless Steel Bottom...
Refrigerators Logo
15 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
