Question about Nikon COOLPIX L20 Digital Camera
Is there a reset button on the nikon coolpix s5200
Is there a reset button on the Nikon Coolpix s5220
    Guru:
  • Nikon Expert
  • 362 Answers
Nikon cameras do not have a reset button. Nikon cameras are reset using the Menu selections. Press the Menu button. Scroll to the wrench icon and press the right arrow, find the selection "Reset All" by scrolling down and press the OK button. If you want clarification, this link will take you to your camera's manual where you can look on page 107 in the Reference Section: http://download3.nikonimglib.com/archive1/aYteu00GjpLw00zsmUU460eHgc05/S5200RM_(En)03.pdf
Posted on Feb 14, 2015
dlundmark
  • 797 Answers
SOURCE: Nikon Coolpix L3 51 megapixels lense error
You may not be able to... but may be worth a try.
See my posts on this problem.
Posted on Jun 21, 2008
SOURCE: black monitor Nikon Coolpix S4 Digital
Give the lense side of the camara a few moderate slaps while moving camara from bright to dark obgects back and forth. the shutter gets stuck and doesn't respond to changing light. that's why outdoor pictures are usually too bright and indoor pictures are black.
good luck.
Posted on Aug 19, 2008
  • 4 Answers
SOURCE: Problem with nikon coolpix 8700
Same problem that would not allow me to take a picture without pressing the LOCK button on my Nikon 8700. Here is how I believe I fixed the problem:
Turn the camera ON.
Press MENU button on your camera to bring up the menu.
Scroll down to SET-UP, open the SET-UP menu by scrolling right.
In the SET-UP menu, scroll all the way down to FUNC (Controls) on page 2/3 , open the FUNC (Controls) menu by scrolling right.
You are now presented with 2 options:FUNC and AE-L, AF-L)
Select the FUNC option by right scrolling.
Choose the 2nd option: i.e the mountain, flower and timer icon (distance, macro and self-timer icon) by right scrolling.
Press the MENU button to get out of the menu.
Attempt to take a picture without pressing LOCK.
Should work! Anyways, it worked for me.
Cheers.
Posted on Jan 22, 2009
olasNick
  • 20 Answers
SOURCE: system error message nikon coolpix 950
Any good with a small screw driver?
Posted on Apr 23, 2009
BillB-SA
  • 2761 Answers
SOURCE: My Nikon COOLPIX S51 Will not turn on.
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
Posted on Nov 08, 2009
Nikon COOLPIX S5200 will not charge or come on.....almost new!!! :(
You need to return it for a replacement while it is new. Try returning it to the store for a replacement first. If they won't replace it, contact Nikon. Never try to fix a brand new item. It will void the warranty.
Oct 01, 2014 | Nikon Coolpix S5200 16 Megapixel Digital...
Nikon coolpix s5200
Please try removing the battery and after a few moments replace the battery. This should "reset the camera. It has the same effect as a cold boot on a computer.
Never try o switch on a camera, when an USB cable is connected. Only certain camera's, and only when special software is installed on the commuter, can work with the USB cable.
Most cameras, play "dumb" and only accept 5 volt, to charge the battery, or will transport pictures to the computer when connected and the correct software is installed.
I hope the camera will work again.
Success
Jul 25, 2014 | Nikon Coolpix S5200 16 Megapixel Digital...
Frozen in on position
This happened on mine once and I had to do a hard reset by removing the batteries then restarting...
Feb 15, 2014 | Nikon Coolpix S5200 Digital Camera, 16...
My nikon coolpix s5200 will not turn on and it is fully charged
The same thing happened to my camera. It's practically new, I've used it twice and it stopped working. i tried almost everything but can't find a solution. Any suggestions?
Aug 04, 2013 | Nikon COOLPIX L20 Digital Camera
Flash on Nikon Coolpix s200 camera not working
hi try to reset ur camera...To do such reset, turn on the camera and hold the menu button down for longer than 5 seconds. A message should hopefully come up on your LCD asking if you want to reset the camera. Select Yes...
thank u!!!
rate me!!
Jun 28, 2009 | Nikon COOLPIX S200 Digital Camera
Nikon D40x indicate battary low
Rechargeable Lithium-ion 7.4V 1000mAh Nikon D40x battery for sale,20% off! Full one year warranty! For more info visit: http://www.nikon-coolpix-replacement-battery.com/d40x.htm
May 13, 2009 | Nikon D40x Digital Camera
Coolpix 4300 needs driver & update for vista
this solution was originally written by a fellow expert dauphine
You can download PictureProject software from this address: http://chsv-soft.nikon-image.com/jpn/software/win/S-P2____-175WU-JPNJP.exe
That is the only Nikon software that supports Vista since your camera is "outdated".
Here is a quote from Nikon site:
  • We had released a Windows Vista-compatible version of PictureProject, v1.7.5, for use with the models listed below, and all models that followed. PTP (models supporting the PTP protocol) and Mass storage USB transfer options can be used for camera connection. However, the camera's transfer button can not be used to transfer pictures over a PTP connection. Set the USB transfer option to Mass storage to enable the camera's transfer button.
    Currently, the new Nikon Transfer and View NX will replace Picture Project as our new Image Transfer and Browser applications. These applications support the same Nikon products as Picture Project.
COOLPIX P4, COOLPIX P3, COOLPIX P2, COOLPIX P1,COOLPIX S10, COOLPIX S9, COOLPIX S8, COOLPIX S7c, COOLPIX S7, COOLPIX S6, COOLPIX S5, COOLPIX S4, COOLPIX S3, COOLPIX S2, COOLPIX S1,COOLPIX L6, COOLPIX L5, COOLPIX L4, COOLPIX L3, COOLPIX L2, COOLPIX L1/L101,COOLPIX SQ, COOLPIX 8800, COOLPIX 8700, COOLPIX 8400, COOLPIX 7900, COOLPIX 7600,COOLPIX 5900, COOLPIX 5700, COOLPIX 5600, COOLPIX 5400, COOLPIX 5200, (COOLPIX 5100), COOLPIX 5000, COOLPIX 4800, (COOLPIX 4600), COOLPIX 4500, COOLPIX 4300, COOLPIX 4200, COOLPIX 4100, COOLPIX 3700, COOLPIX 3500, COOLPIX 3200, COOLPIX 3100, COOLPIX 2500, COOLPIX 2200, COOLPIX 2100, COOLPIX 2000,COOLPIX 995, COOLPIX 885, COOLPIX 775.We do not plan to offer compatibility for COOLPIX 990 OR COOLPIX 880 connection to a computer with Windows Vista preinstalled. Use a card reader or card slot to transfer images.
Jun 15, 2008 | Nikon COOLPIX S5 Digital Camera
Nikon 5700 coolpix
Try the menus, if they work, possible that the ccd is bad.
Here is a link to the Nikon Advisory.
http://www.nikonusa.com/email_images/nikonusa/service_advisory/coolpix.html
May 24, 2008 | Nikon Coolpix 5700 Digital Camera
Apr 20, 2008 | Nikon Coolpix 4300 Digital Camera
Nikon COOLPIX L20 Digital Camera Logo
553 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
