Question about Air Tools & Compressors
How do you change the element on a kaeser in line air filter model KPF250
  • 98 Answers
Relief all pressure and push up and turn to left might have to use pliers to turn if it has not been changed in a while
Posted on Jul 22, 2009
Dryer not heating
Check Heating elements if ok check the in line fuse that go to drying element and if it open replace it and clean filter and check pipe that blow out side make sure it not stop up because if in line fuse is open stop up filter and pipe that blow air out side will cause the heating element in fuse to open up. And check for lose wire going to element to.
May 30, 2014 | Kenmore 98702 Stacked Washer/Dryer
My Ryobi start great but when I change it from start to run stays few seconds and died
  • Alow the engine to run for longer on the start setting before you switch to run
  • Ensure air filter is clean. Foam elements can be washed with hot water and detergent. Paper elements can be cleaned with compressed air blown from the inside of the filter but ideally should be replaced.
  • Check fuel lines aren't kinked or blocked restricting fuel flow.
  • Ensure fuel filter isn't dirty. This is probably located at the end of the fuel line in the tank.
  • The fuel lines may have become airlocked.This can happen if the tank is run dry. If the trimmer has a primer bulb, alternatively press it several times and then try to pull start the engine with choke on. Repeat this several times. The primer bulb should feel spongy and fill with fuel.Once the engine kicks, switch to run.
Apr 05, 2011 | Ryobi Gas Hedge Trimmer
Replacing air filter on 2000 buick lasabre
To change the air filter disconnect the electrical connector on the large hose that runs from the air filter assembly to the throttle body assembly. Slowly and carefully remove the large hose from the throttle body and air filter assembly. Some of the 2000 models have spring type clips holding filter cover while others have two screws. Either unhook the clips or ree.move the screws and lift the cover. You'll see the filter element. Remove and replace it. Reverse order to reassembl
Sep 14, 2010 | 2000 Buick LeSabre
How to change cabin air filter?
Place the ignition switch in the Off position, remove the supplemental inflatable restraint fuse from the rear fuse panel. On 1997 models, the rear fuse panel is located in the luggage compartment. On the 1998-2003 models, the rear fuse panel is located under the rear seat. Remove the two retaining screws from the rear edge of the left sound
insulator. Push in on the snap tabs to release the insulator. Disconnect the left sound insulator electrical connectors, then remove the insulator. Twist the shift cable grommet and position away from the cabin air filter access door. It may be necessary to cut the tie strap and peel back the foam insulation to position the grommet away from the door. Remove the cabin air filter access cover from the A/C and heater module.
Remove the tape, then pull out the first cabin air filter element using the filter tab. Remove the tape, then pull out the second cabin air filter element using the filter tab. Remove the tape, then pull out the third cabin air filter element using the filter tab.
To ease installation, lubricate the new filter guides with silicon spray. Install the first clean air filter into the case. Using a long thin blade screw driver and filter tab, raise the filter until it is parallel with the A/C and heater module. Ensure the leading edge of the filter engages the filter case holding rib. Engage the new second cabin air filter in the tab of the first filter. Slide the second filter into the remaining channels of the first filter. Using the filter tab, raise the filter until it is parallel
with the A/C and heater module. Ensure the leading edge of the filter engages the filter case holding rib. Engage the third new cabin air filter in the tab of the second filter. Slide the third filter into the remaining channels of the second filter. Fold the tab of the second filter down. Fold the tab of the third filter up and over the second filter.
Install the A/C and heater module filter cover. Ensure the cover is properly seated. position the shift cable grommet. Position the left sound insulator to the instrument panel, then connect the electrical connectors. Install the left sound insulator fasteners. Torque the fasteners to 18 inch lbs. Be sure to install the fasteners in the proper locations, then install the SIR fuse. From a position off to the side of the air bag module, place the ignition switch in the "On" position. The air bag warning lamp should flash 7 times and then turn Off. Place the ignition switch in the "Off" position.
Jun 22, 2010 | 1999 Cadillac Seville
Where is the fuel filter on a turbo desail
Your fuel filter is mounted on the rear of intake manifold, under air cleaner or on rear firewall.
Just a little hint on replacing it, remove your fuel tank cap to release pressure or vacuum in the tank. I'm sending you a diagram the fuel filter assembly so it will make it a little simpler for you to replace your fuel filter. Start by removing the filter element nut. Remove filter element by lifting straight out of filter housing. It is not necessary to drain fuel from filter housing when changing the filter element.
Installation, ensure mating surface between filter element assembly and filter housing is clean. Install new filter element by aligning widest key slot located under element assembly cap with widest key in filter housing assembly.
Tighten element nut by hand. Bleed air from fuel manager/filter assembly. Connect a hose to air bleed valve and place other end of hose in a container.
Disconnect fuel injection pump shutoff solenoid wire. Crank engine for 10 to 15 seconds. Allow starter to cool down for one minute between cranking intervals. Repeat procedure until clear fuel is observed at the air bleed hose.
Close air bleed. Connect injection pump shutoff solenoid wire and reinstall fuel filler cap. Start engine and allow to idle for five minutes. Check fuel manager/filter for leaks.9df1ca0.gif
Oct 03, 2009 | 1994 Chevrolet C/K 2500
Sigma air end pump repair
A company in Forsyth , GA tele. phone # 478 974-0018 Simple Air Solutions LLC.
Aug 11, 2009 | Air Tools & Compressors
Open air filter box to replace filter on a 2000 dodge caravan
the filter element is actually below the box that says air filter element. You remove it from air intake and disconnect from frame and element case. The element is in a black box behind drivers side headlight, facing sideways. Its a pain, but working on this particular engine is rough. They designed it to be worked on at a shop with specialized tools. Average wrenches and sockets don't have enough room to turn! Since this element is hard to replace, you'll notice a marked improvement after changing this bad boy/
May 24, 2009 | 2000 Dodge Caravan
Its time to replace my air filter.
Inspect/Replace As a filter gets dirty, the amount of air that can flow through it is reduced. This is not a problem until less air than the engine needs gets through the filter. Without the proper amount of air, the engine will not be able to produce the power it should, nor will it be as fuel efficient as it should be.
Included in the preventative maintenance plan for all vehicles is the periodic replacement of the air filter. This mileage or time interval is based on normal vehicle operation. If the vehicle is used or has been used in heavy dust, the life of the filter is shorter.
Always use a replacement filter that is the same size and shape as the original.
The shape and size of the air filter element depends on its housing; the filter must be the correct size for the housing or dirt will be drawn into the engine. On today's engines, air filters are either flat or round.
fr_12.06.3184.gif Typical flat air filter element. f12-07.gif Typical round air filter for a late-model vehicle. Courtesy of Ford Motor Company. When replacing the filter element, carefully remove all dirt from inside of the housing. Large pieces of dirt and stones may accumulate there. It would be disastrous if that dirt got into the cylinders. Also make sure the air cleaner housing is properly aligned and closed around the filter to ensure good airflow of clean air.
(i searched this info on autozone.com)
Apr 27, 2009 | 1995 Oldsmobile Aurora
Briggs & Stratton engine on Murray lawn mower running rough. Changed spark plug, cleaned filter, drained fuel tank and line. Still running rough. What to do next?
I always replace the air filter if its a paper element, and even if its a foam element I replace it rather than clean it. That said, engine stumbling is rarely and air flow problem - but it could be, so having a new filter assures no air restrictions.
I would drop the carbuerator bowl. On the bottom of the carb, near where the fuel line comes into the engine, should be a nut. Removing this nut allows the bowl to drop off the carb. Some engines the bowl screws off, you will have to look at the bowl. Often the bowl has sediment or sludge buildup inside. Cleaning the bottom of the bowl can prevent that sludge/sediment from plugging the intake tube. Even on newer mower models this is a common problem, the gas line tubing interior breaks down and the inside of the tubing can start degrading - ending up in the bowl as sludge.
After cleaning the bowl, I would add one ounce of fuel line cleaner to a full tank of fuel and run the entire tank of fuel. This will clean any deposits or "varnish" from the interior carb parts. Doing this and the first step will assure your carb is clean and functioning.
If that doesn't help, then I would look at the spacing between the magneto and coil assembly. If you want to do that I'd like you to write down all the model numbers and serial numbers on the engine nameplate, that way I can give you specific directions.
Hope this helps,
Gregg
Mar 29, 2009 | Garden
2000 lincoln navigator 90k mile service
Normal Maintenance Details
90,000 Miles (144,000 Kilometers) : All Applicable Models
PERFORMED OPERATION COMPONENT
INSPECT BALL JOINTS
If equipped.
INSPECT BRAKE SYSTEM
Inspect brake pads, shoes, rotors, drums, brake lines & hoses.
INSPECT COOLING SYSTEM HOSES & CLAMPS
INSPECT DISC BRAKE PADS & ROTORS
INSPECT DRIVESHAFT
If equipped.
INSPECT DRIVESHAFT/PROPELLER SHAFT U JOINTS
INSPECT EXHAUST SYSTEM AND HEAT SHIELDS
INSPECT PARKING BRAKE SYSTEM
INSPECT STEERING LINKAGE
INSPECT SUSPENSION COMPONENTS
LUBRICATE DRIVESHAFT/PROPELLER SHAFT U JOINTS
LUBRICATE STEERING LINKAGE
REPLACE AIR CLEANER/ELEMENT
REPLACE AUTOMATIC TRANSMISSION FLUID
REPLACE CABIN AIR FILTER
If equipped.
REPLACE CLIMATE-CONTROLLED SEAT FILTERS
If equipped.
REPLACE ENGINE OIL
REPLACE ENGINE OIL FILTER
REPLACE FUEL FILTER
ROTATE TIRES
90,000 Miles (144,000 Kilometers) : RWD
LUBRICATE BALL JOINTS
2000 Lincoln Navigator
Maintenance
...sorry if not too readable
Jun 07, 2008 | 2000 Lincoln Navigator
Air Tools & Compressors Logo
147 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
