Question about Xerox WorkCentre Pro 90 Copier
Xerox workcenter problems
Xerox workcenter how to rest system error
  • 2072 Answers
SOURCE: scanner locked
There is a lock that has been hit and has the scan lamp locked.
Where to look is on the botom of the scanner. Look in where you remove the copies, on the bottom of the scanner you will see the only green part there, it is about 2 inches long and a half inch wide.
Turn the machine off, reach in and push the latch full IN, toward the back of the machine, then pull it our toward you until it snaps into place fully forward, It may be a little tight with it against the lamp carriage, but once you get it latched forward it will return to normal.
That latch is easy to hit when you are removing your copies from the tray.
Posted on Dec 22, 2008
  • 2072 Answers
SOURCE: Cant locate the printhead on xerox C2424
Remove the covers. But before you go to eh print head itself, there is a print head pivot block that often gets contaminated with ink. The code you are having, is related to the print head not being able to move freely side to side, or tilt properly.
To access that block. You have ot remove the document feeder and scanner. To do that you disconnect the cable, it runs from the back to the scanner to the opening where the power cord plugs in, remove the 2 thumb screws and unplug it. You slide the doc feeder and scanner back, then depress the two tabs and completely remove it.
There is one screw in the back that holds on both the left and right side covers. You have to lift and kind of twist the covers in about the middle of the machine, The front cover will also pop off, it has tabs that holds the front covers together. Then remove them.
Look on the left side of the machine, looking from the front. You will see a stainless steel block, about one inch square, located about 2/3rd of the way back on the lower 1/4th of the frame. It has a spring and a clip over it. Just pull out on the spring bracket and locate it up and to the left, It is meant to be put there for servicing.
Look at the block. it may be filled up with yellow ink. If so , remove it with channel locking pliers. It may be VERY tight, so work it out slowly. Then soak it in hot water, that softens the ink , and clean it and the shaft thouroghly and remove as much excess ink from teh surrounding area as possible. Also, IF that is the problem. Probably a 75 percent chance, then when you return the printer to service. Get a small level, and make sure the printer is level BOTH side to side and front to back. To do that , you place the lecel on the platen glass, sideways then front to back. Often times those printers are not level and that causes the problem. The other things that happens is simple spill over from the ink catch tray, It is imperative you have those printers sitting level.
If thats not the problem. let me know We will go from here.
Posted on May 18, 2009
SOURCE: Xerox 7232 and As400
016-799 is a printer paper conflict error. All you have to do for the AS/400 to print, is to make suree that tray 2 in the printer is set up to do landscape printing. There has to be at least one tray for portrait, and one for landscape in order for the AS/400 to print.
Posted on Sep 17, 2009
  • 24 Answers
SOURCE: xerox workcenter 7665 communication problem
This was an issue with earlier models and is usually attributed to the "USB" connector on the bottom of the control panel not being attched securely. Note: although the connector is USB, it is NOT hot swappable and will crash the machine if unplugged while the power is on.
Power off the machine. Ensure the cable is securely attached and restart the 7665. Make sure when you turn it off that it is completely off before restarting or you could corrupt the system software.
Posted on Oct 25, 2009
  • 21 Answers
SOURCE: system unavailable in xerox pro 255 :(
esto lo puede dar el cartucho de copia mal insertado q produce arcos de la fuente de alta y la desconecta dando error 9060, tal vez el corotron roto del cartucho de copia.... otro padrenuestro
Posted on Dec 02, 2009
Xerox 7242 error 010-328 i have a xerox workcenter 7242, it is giving me error code 010-328. how can i fix this error please
That error points to a fuser problem. Replace the fuser and see if that works for you. If not then you need some add'l parts and a service tech to install and repair it for you. Hope this helps.
Sep 03, 2016 | Xerox WorkCenter Office Equipment &...
13387.48:16806 error code on Xerox Workcenter C2424
From the Xerox Solution center --
Solutions for : Fault Codes 13,XXX.4X: Thermal Error Related Fault Codes: 13,xxx.4x Solutions ranked by relevance:
  1. Make Sure the Room Temperature is Within Operating Temperature Specifications
  2. Make Sure the Power Source is Not Causing the Behavior
A previous firm I worked at had these units. Do not plug them into a surge protector of backup power supply system.
Mar 22, 2011 | Office Equipment & Supplies
FAULT CODE 124-373 ON WORKCENTER 5225 WILL NOT CLEAR
Xerox 5225 keeps showing error 124-373 and cant one to enter into set-up or status mode.How to correct this error?.I have jobs to copy for urgent meeting soon.your email is needed
Aug 28, 2010 | Xerox Workcentre 5225 / Copier, With...
Our xerox workcenter 7235 fault code 024-360 and copy service is disabled
024 360 An error has been detected by the Controller during communications with the Printer. User intervention is required to Power Off/Power On the machine, Field Service is required if the problem persists. Printing is disabled.
http://www.support.xerox.com/go/results.asp?Xtype=docs&prodID=WC7228_WC7235_WC7245&Xlang=en_IN&Xcntry=IND
You will have to either get this printer repaired or replace it.
Aug 05, 2010 | Xerox Office Equipment & Supplies
Xerox PE220 workcenter shows LSU Error message.
XEROX WORKCENTER PE220 , ITS SHOWING LSU ERROR . ITS NOT PRINTING OR COPYING ANYTHING . PLEASE GIVE SOLUTION
Dec 17, 2009 | Xerox Phaser 8500/DN Printer
Xerox PE 120i workcenter. Error says
you need to remove your paper tray.take your toner carriage out ,yurn the mc and assess
Nov 29, 2009 | Xerox PE120i Laser Printer
System unavailable in xerox pro 255 :(
Oct 08, 2009 | Xerox WorkCentre M-24 Color Copier
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
