My Vizio TV is stuck on 480p. No matter which HDMI port I use, it will not recognize a signal. I have tried with the HD Box from comcast and a Sony blue ray player (Works fine on Samsung TV). Any ideas?
SOURCE: My TV has 3 HDMI ports. Originally I had HD cable
Welcome to Copyright Protection, otherwise known as HDCP. Its hell.
Interesting article in Popular Mechanics for you below. Have a read.
http://www.popularmechanics.com/blogs/technology_news/4212508.html
This forum may help.
http://www.avsforum.com/avs-vb/showthread.php?t=842732&page=2
SOURCE: HDMI problems with 40'' bravia
The HDMI reciever board in the TV is bad and will need to be replaced. You should have a technician look at it so they can get the correct part number using the model number and the TV's serial number too.
SOURCE: Pioneer works with cable box but not with new blue
HDMI version is 1.3 in your receiver.The current version is 1.3b. I would suggest calling Pioneer cust assistance and see if there is a firmware update. Your unit has a 2 year parts & labor warranty. Their # is 1-800-421-1404 It sounds like a CODEC issue. Hope this helps
SOURCE: My HDMI connection does not work with Blu Ray DVD
After reading your post a couple of times, it just seems your are in a little of a pickle here. The only thing I can suggest, since your tv will work with fios and not the your BD player(I assuming your using the same port on the tv with the same hdmi cable), is all about firmware. Maybe your tv is not compatible with the the BD player. Try updating the firmware on the tv.
SOURCE: Purchased and set up both Vizio SV370XVT HDTV and
Try setting your cable box for Closed Captioning. Worked for me.
