Question about Frigidaire FGF316 Gas Kitchen Range
Where can i find the model number? We had a power outage and now the electric ignition isn't working. It doesn't click like it use to when trying to start. Just gas comes out.
  • roeder3 Jun 22, 2009
    Is there a way to test and see what my problem is? Or maybe a way to reset the ignitor? Model # FGF335CGSA
    President:
  • 744 Answers
Normally you can find the model number inside the drawer at the bottom. It's normally on a plate along with serial number..right side. You may have a problem with the igniter module.
Posted on Jun 22, 2009
  • Mike Price
    Mike Price Jun 22, 2009
    Normally when the ignition keeps clicking it means there is a bad switch, when you have nothing it's a bad module. I did once have a melted wire to the module so you should visually check the wires too and from the module, this can normally be located in the control panel and can normally be accessed from rear.
Emerson 2.8 Cu. Ft. doesn't automatically turn on after power outage
Check breaker. Was there a surge of electricity when the power went out. This may be a simple fix. Sounds like the breaker is tripped. Test the outlet with a light to see that power is to it.
Feb 04, 2013 | Emerson 2.8 Cu. Ft. Refrigerator - Silver
My 2000 lincoln ls doesn't crank or click when trying to start it, it does nothing? all the lights work, radio, signals and horn, I checked the fuel relay and the starter relay and the ignition fu
Sounds like an Ignition Module or similar device. Does it have an alarm? Turn the key to ON - not start - and put into Drive and then back into Park. It may be the shifter isn't fully engaged. Also, w/your FOOT ON THE BRAKE shift to Neutral and try to start it.
GL,
Td
Oct 01, 2012 | 2000 Lincoln LS
Had a storm the range works but the oven went out model number 8114P732-60 Maytag advance cooking system super cap. is there a reset button
There isn't a reset per say but you can turn the unit off at the breaker box for the home for 1 to three minutes. If this does not work...either the heating elements were blown during the power outage or the control board is now fried from the surge and needs replaced.
Sep 01, 2011 | Maytag MER5775Q Electric Kitchen Range
We had a power outage for several days. Now that power is back on, the electric igniter will not work. We have to light the burners manually. There is no "clicking sound" indicating the...
See where the range is plugged in. Check to see if there is power there. If so, the igniter must be replaced. This is not a difficult repair. I would guess there is a power problem, blown circuit breaker, open GFCI outlet or the plug is out.
Gary
Sep 01, 2011 | Jenn-Air 30 in. CCG2423 Gas Cooktop
Stove top ignitors do not ignite but oven does.
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Mar 20, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
I have a kenmore gas range with electric ignitors. My question is that my stove top doesnt ignite but lets gas by and I can use a lighter to lite them. However my oven doesn't do anything...no gas no...
Nov 06, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Refrigerator will not reset after a power outage
just unplug it wait 5 minutes and plug back in. If this doesn;t work, replace the mother board.
David
May 16, 2009 | Samsung RS2534 Side by Side Refrigerator
Water heater with electonic igniter will not work in power outage
What type of heater is this? I need to know the model name and make and then we can go threw the process of how to do it. Most gas heaters do not have power to them and I only know of a few tankless heaters that do.
Feb 08, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
No burner/oven heating after house power outage.
try reseting the clock as lots of ovens will not work untill clock is set
Jan 19, 2009 | Amana AER5515QA Electric Kitchen Range
Thermador SC302T clicking noise, locked door after power outage
iodine, open the upper oven, look thru the grill below the control panel on the right side and there is your model number. The issue here is that when the power came back on the oven run thru a test and your lower lock motor has failed. It will need to be replaced. Yes the only way to stop this is to shut off the breaker.
Feb 03, 2008 | Thermador SC302T Electric Double Oven
Frigidaire FGF316 Gas Kitchen Range Logo
118 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Justin Duby
Justin Duby
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
