Question about Vtech V.reader Reading System
How to get out of Engineering mode?
Adc value
When i devide whole numbers into decimals i get exponent answers??
The correct answer would be 8.22E-6 . Even if you're not in scientific or engineering mode, the calculator will automatically switch to scientific mode if the absolute value of the number is less than 0.001 (or won't fit in ten digits).
Nov 30, 2012 | Texas Instruments TI-83 Plus Calculator
Tip
Motorola Secret Codes
<span>Motorola L6:<br />-----------------<br />hold * 65512890 for reset<br />hold * 5806 sw version<br />hold * 487989 NS lock menu<br />hold * 482896 CP<br />hold * 574243 NS<br />hold * 967678 SP<br />hold * 362628 IMSI<br />hold * 787090 Lock net level<br />hold * 787292 Lock net level<br /><br /><br /><br />Reset L7 security code without any cable<br />------------------------------------------------<br />press menu button enter 6 time 0 and then press ok<br /><br />*#06# IMEI<br />in permament test mode<br />(* hold 2 sec)<br />***113*1*[OK] net monitor<br />T205/T19x (ACER)<br />*#300# OK List the Software and Hardware version<br />*#301# OK Full Keypads functional Test<br />*#303# OK Set Default Language to English<br />*#304# OK Set OFF engineering mode<br />#304*19980722# OK Set ON engineering mode<br />*#305# OK Location: 1 OK<br />*#307# OK Engineering Test Mode<br />*#311# OK Phone code changed to default code<br />*#400# OK ADC, Cal val*<br />*#402# OK Adjust Display Intensity / Contrast<br />*#403# OK List the Manufacturing Informations<br />19980722 OK Master Unlock code for Phone and Sim Lock<br />*#302# OK Acoustic test*<br />7.1 Greeting<br />7.2 Main VlmGain<br />7.3 Input Cal<br />7.4 Output Cal<br />7.5 Side In Gain<br />7.6 Vox Gain<br />7.7 Min Mic Engy<br />7.8 More<br />(a) In Vlm Gain<br />(b) Aux Vlm Gain<br />(c) Silence Prd<br />(d) Supp Prd<br />(e) In Volume<br />(f) Out Volume<br />(g) Icon<br />(h) Image<br />(i) Animation<br />*3370# EFR ON (enhanced full rate)<br />#3370# ERF OFF<br />*#72837726# OK Confirm ?, Data saver<br />1234 OK Phone code default<br />*#0000# OK Setting saved, restore set phone do default language<br />*#0048# OK Fast change polish langpack<br />*#0007# OK Fast change russian langpack<br /><br /><br /><br />MOTOROLA 3xx<br />------------------------<br />*#06# and quick 'menu-key' and 048263* (Push the key quickly!)<br />and entering at field "OPTCODE" you must try several times.<br />If not working try with MOTO TEST CARD inserted.<br />Security code - 32*118*1*0*0<br />Model - 32*279*1*0*8<br />Flex ver - 32*383*1*0*0<br />Master Reset - 18*0<br />Master Clear - 18*1<br />Set band GSM 900 - 10*0*3<br />Set band DCS 1800 - 10*0*4<br />Set band PCS 1900 - 10*0*5<br />Set dual band GSM 900/1800 - 10*0*6<br />Read band - 10*1*0 =&gt; 3-GSM, 4-DCS, 5-PCS, 6-GSM/DCS<br />User code - 32*116*1*0*0 /coded:00310032003300340000 - 1234/<br />Read imei - 32*4*1*0*0 "OK" /coded:083a05092700247709 - 350907200427799/<br />47*4*1*0*9*081A32547698103254 =&gt; IMEI=123456789012345<br />it is possible to change IMEI<br /><br />ENJOY</span>
on Jul 11, 2011 | Cell Phones
Tip
MOTOROLA CODES
>>All Motorola Secret Code<<
Motorola L6:
hold * 482896 CP
hold * 574243 NS
hold * 967678 SP
hold * 362628 IMSI
*#06# IMEI
(* hold 2 sec)
T205/T19x (ACER)
7.1 Greeting
7.2 Main VlmGain
7.3 Input Cal
7.4 Output Cal
7.5 Side In Gain
7.6 Vox Gain
7.7 Min Mic Engy
7.8 More
(a) In Vlm Gain
(b) Aux Vlm Gain
(c) Silence Prd
(d) Supp Prd
(e) In Volume
(f) Out Volume
(g) Icon
(h) Image
(i) Animation
#3370# ERF OFF
MOTOROLA 3xx
Master Reset - 18*0
Master Clear - 18*1
Read band - 10*1*0 => 3-GSM, 4-DCS, 5-PCS, 6-GSM/DCS
47*4*1*0*9*081A32547698103254 => IMEI=123456789012345
it is possible to change IMEI.........
on Feb 09, 2008 | Motorola Mobility L6 Cellular Phone
Fridg. not cooling. digital display not working, frezzer thawing.
he refrigerator/freezer defrost system can be checked by manually initiating a defrost cycle. There
are two methods of initiating the ADC Test Mode.
First Test Method:
1. Turn the thermostat off for 15 seconds.
2. Turn the thermostat on for 5 seconds.
3. Turn the thermostat off for 15 seconds.
4. Turn the thermostat on for 5 seconds.
5. Turn the thermostat off for 15 seconds.
6. Turn the thermostat on for 5 seconds.
7. Turn the thermostat off.
In 3 to 8 seconds the ADC should turn on the defrost heater (with the bimetal closed). NOTE: The test mode will terminate when the bimetal opens. If the refrigerator/freezer is already in defrost, Test Mode can be terminated by unplugging the refrigerator/freezer from the wall outlet and waiting 30 seconds before plugging it back in. The refrigerator/freezer should immediately go into cooling mode if the thermostat is closed.
If this first test procedure fails to make the ADC initiate a defrost cycle, try the following procedure to make the ADC begin the Test Mode.
Second Test Method:
1. Disconnect the refrigerator/freezer from the wall outlet for at least 30 seconds.
2. Turn the thermostat off.
3. Reconnect power to the refrigerator/freezer.
Within 3 to 8 seconds the ADC should turn on the defrost heater (with the bimetal close). If the unit fails to go into the defrost mode during this test, the problem may not be with the ADC. A defective bimetal may be the cause of the failure. The ADC will only go into a test mode if the bimetal
is closed. If the ADC senses an open bimetal it will return to the cooling mode within 3 to 8 seconds.
HELPFUL HINT: Upon entering the Test Mode, the relay mounted on the ADC board should turn off the compressor and turn on the defrost heater. Listen for the relay to click.
• If the relay clicks one time when entering the Test Mode, check for continuity in the defrost heater.
• If the relay clicks two times, check for an open bimetal.
Jun 11, 2011 | Whirlpool Refrigerators
Code manuelle
T205/T19x
*#06# -> Displays imei
*#300# OK -> List the Software & Hardware Version
*#301# OK -> Full Keypads Functional Test
*#303# Ok -> Set Default Language to English
*304# OK -> Set OFF engineering mode
#304*19980722# -> Set ON Engineering mode
*#305# OK -> Location: 1 OK
*#307# OK -> Engineering Test Mode
*#311# OK -> Phone code changed to default code
*#400# OK -> ADC, Cal val*
*#402# OK -> Adjust Display Intensity/Contrast
*#403# OK -> List the manufacturing Informations
19980722 OK -> Master Unlock code for Phone & Sim Lock
*#302# OK -> Acoustic Test*
*3370# -> Enhanced Full Rate
#3370# -> Deactivate Enhanced full Rate
*#72837726# OK -> Confirm?, Data Saved
1234 OK Phone Code Default
*#0000# OK -> Settings saved, restore set phone to default language
Dec 19, 2010 | Motorola Cell Phones
How do i get unit to go in deforst
The refrigerator/freezer defrost system can be checked by manually initiating a defrost cycle. There
First Test Method:
Second Test Method:
Nov 26, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
My i9 3g mic does not work I can hear the caller but they cant hear me help!!!
go to engineering mode http://www.iphoneclone.de/SciPhone/SciPhone-Engineer-mode/Index.html and change microphone volume to a value of 6. I had the same problem, my microphone level had been at zero. Good luck and best regards. Hansi
Feb 17, 2010 | T-Mobile Sidekick
What to do?
hi friend,
Look at these service phone codes of Motorola mobile, may be it will help you in your mobile phone settings
*#06# imei
in permanent test mode
(* hold 2 sec)
T205/T19x (ACER)
*#301#­ OK ­ Full Keypads functional Test
*#403# OK List the Manufacturing Information's
7.1 Greeting
7.2 Main VlmGain
7.3 Input Cal
7.4 Output Cal
7.5 Side In Gain
7.6 Vox Gain
7.7 Min Mic Engy 7.8 More
(a) In Vlm Gain
(b) Aux Vlm Gain
(c) Silence Prd
(d) Supp Prd
(e) In Volume
(f) Out Volume
(g) Icon
(h) Image
(i) Animation
#3370# ERF OFF
MOTOROLA 3xx
Master Reset - 18*0
Master Clear - 18*1
it is possible to change phone's imei
or u can even try last 4 digits of ur mobile number
hope this helps u
thank u for using fixya
regards
sivaranjini
Nov 26, 2009 | Motorola Mobility RAZR V3
Whirpool frost free-fridge temp is not working
First Test Method:
Second Test Method:
� If the relay clicks one time when entering the Test Mode, check for continuity in the defrost heater.
� If the relay clicks two times, check for an open bimetal.
Jan 06, 2009 | Whirlpool Refrigerators
Vtech V.reader Reading System Logo
14 people viewed this question
Top Vtech Toys Experts
relojmesa
cloudranger
Level 1 Expert
Are you a Vtech Toy Expert? Answer questions, earn points and help others
