LENOVO LAPTOP 575 ADAPTER - Computers & Internet
Format lenovo laptop
If the rescue sector is still intact on your hard drive press F12 as you boot the laptop. That will restore to the factory set up.
Oct 16, 2013 | Lenovo 3000 G230 4107 Laptop AC Power...
Hi, i am using a lenovo w 500 for gaming, on battery power i can play games, but when i plug in the ac adapter and start the game, 1 minute in the game my laptop dies, it just went off, can you help...
hi, i think it is ac adapter problem. If the laptop charger's Voltage is overhigh,laptop will go wrong. You can test that by change another ac adapter. If the problem is solved. You only change a replacement new lenovo laptop ac adapter.This website(www.aubatt.com) have many replacement laptop accessories,you can look it up.
Hope these can help you.
Nov 21, 2012 | Lenovo Computers & Internet
My Lenovo ac/dc adapter (charger) whose model number is PA165052LC does not work. The lenovo on it will not light up and it will not charge my laptop. What caused it to stop functioning and how can I fix...
I would plug it in without the battery first and if the laptop stays powered on your adapter probably is fine and you have an issue with your motherboard or battery. If it still does not work replace the power adapter they are cheap and its technology sometimes it just breaks! hope this helps!!
Feb 24, 2011 | DSMiller DS Miller Inc Equivalent of...
Camera initialization failed, Lenovo easy capture closed. this message comes when i open lenovo easy capture .
Welcome to Fixya
This means that the software failed to load up. Try to reinstall the easy capture software by going to the lenovo site. You can try also to disable/enable the camera by pressing the Fn key + Esc key.
Thank you for using Fixya!
Feb 20, 2011 | Lenovo 3000 G230 4107 Laptop AC Power...
Thinkpad T500 lenovo laptop will not start but battery power light is one
  1. Shutdown laptop.
  2. Remove battery, other external peripherals connected, disconnect from ac adapter.
  3. Press and hold power button for 10 seconds to drain power.
  4. Restart laptop.
May 20, 2010 | Lenovo ThinkPad T500
How to turn on wireless on Lenovo T61 laptop?
I checked the manufacturer's web-site:
http://www-307.ibm.com/pc/support/site.wss/product.do?brandind=10&familyind=374625&machineind=0&operatingsystemind=49979&template=%2Fproductselection%2Flandingpages%2FdownloadsDriversLandingPage.vm&validate=true
but did not find any device-driver for the wireless-adapter for your Operating System.
This might imply that the wireless-adapter is fully supported by the Operating System, i.e., no additional device-driver is needed.
Open the "Network Connections" window, and display all the currently-defined network-adapters -- the wireless adapter should be present. Select it, and right-mouse click on its icon, and choose "enable".
Apr 29, 2010 | Lenovo (40Y7026) Wireless Adapter
Will not charge or run off 120 power
The only way to charge the battery is with a _WORKING_ AC adapter.
Find a technician with a MultiMeter, and test to confirm that the AC adapter is putting out the correct voltage and amperage.
Take the laptop to an electronics store, and ask if they have a "universal" AC adapter that is compatible with your Lenovo,
and get them to "test" the adapter. If your laptop runs, then buy that adapter, from them, of course.
If not, then something else is wrong "inside" your computer,
and only Lenovo's technicians can trouble-shoot and repair.
Jan 09, 2010 | Lenovo 3000 Y410 Laptop
Computers & Internet Logo
David Payne
David Payne
