Question about Troy Garden
DOING A OIL AND FILTER CHANGE , HOW MUCH OIL GOES BACK IN.
HOW MUCH OIL GOES BACK IN AFTER A OIL AND FILTER CHANGE
2 Suggested Answers
  • 653 Answers
SOURCE: how much oil goes in when doing a full oil change
Should be abt 3.5L or to be safe just fill about 2.5L then using the cap dipstick check the level indicator.
Posted on Apr 26, 2010
How do I change the oil on my 2007 Chevy uplander?
crawl under it and remove the drain plug .when drained put plug back in , change filter and add new oil
Aug 11, 2015 | Cars & Trucks
I have a ford Focus 2006 1600TDC EURO45CAA MJ. The engine oil light goes out after starting then comes back on after a few minuets if the engine is running at 1200 rpm and above it goes out oil level is...
The light works off pressure and it's saying there is not enough pressure when it is in idle but when you bring the rpms up it forces the pump to work faster and causes your pressure to go up thus turning the light off. you probably have an oil pump going bad but a clogged oil filter can do this too. Recommend doing an oil and oil filter change then buy a can of seafoam motor treatment and put all of it into your oil. what it will do is break down any deposits that are built up. It's cheaper to try this than to jump straight to replacing an oil pump. The Seafoam is usually around $10 a can.
Mar 12, 2014 | Cars & Trucks
How much oil goes into my van when doing an oil change??
it will take you 4 quarts of oil with out changing the filter.. and 5 quarts when changing the filter.well really more like 4 1/2..and there is no point in changing it if you arent going to do the filter
Feb 22, 2011 | 1994 Plymouth Voyager
2004 Saturn Ion oil change
Oil drain plug is its on the back passenger side of the engine out of sight unless you under the car itself .
It's a cartridge filter that goes into a canister.You'll need a 32mm oil filter canister socket to remove the cover to access the filter. You can find it at PepBoys for less than $10 by the other oil change supplies.
Jul 18, 2010 | 2004 Saturn ION
How do I change the oil filter on the 2004 pontiac grand am ?
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
May 03, 2010 | 2004 Pontiac Grand Am
How much oil goes in when doing a full oil change with new filter?
Apr 25, 2010 | 1997 Honda CBR 600 F(3)V
Change the oil filter of a daihatsu copen
unless there is something unusual about it... the filter unscrews and you install a new one. you should put a drop of oil on your finger and rub it around the filter gasket before you screw it back on the motor. often you will need an oil filter wrench, abit of a misnomer as it is basically a band that goes around the oil filter with a handle. the newer style is a large socket piece that fits over the end of the oil filter and you turn with a rachet.
Oct 05, 2009 | Daihatsu Charade Cars & Trucks
Garden Logo
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
