Question about Whirlpool 24 in. DU915PWP Built-in Dishwasher
Dishwasher doesnt drain
After the cycle is complete water is left at the bottom of the dishwasher, I have to drain it twice before everything is cleared up
  • garg_sanjay Jun 22, 2009
    I should have added more information. It is a new dishwasher.
    The dishwasher is connected to a separate drainage system (i.e. not through the kitchen sink). The plumber says that the drainage line is fine and the dishwasher technicians says that the dishwasher is operating correctly (he showed me that the dishwasher draining completely when not connected to the drainage). The builder has recommended we reroute the dishwasher drainage through the kitchen sink but that will leave a air hole on the side of the sink.
    Is it possible that the height of the drainage is more than what the pump can handle?
We had the same problem there is a piston valve that had to be replaced. We just has our dishwasher fixed.
Posted on Sep 04, 2009
  • 3,600 Answers
Replace the water pump and belt.
Posted on Jun 22, 2009
  • Bruce Hathcock Jun 23, 2009
    yes it is possible but just buy a plug and my opinion.a hose clamp to block the hole or buy a new drain assembly but I still think it's the pump.
Dishwasher won't drain completely
perhaps it need that air gap device added .we call it a siphon break here .
Sep 06, 2015 | Bosch Dishwashers
Water sits in bottom
If water does not drain at all then the drain pump could be blocked.
If only a little water is remaining but cycle is complete, then this is normal.
However, do check the kitchen drain is clear and you do not have a garbage disposer (insinkerator) in sink which is full. Normally empty it before you start the dishwasher.
Do you get any alarms (lights flashing etc)
Jan 03, 2013 | Frigidaire 24 in. FDB1050REC Stainless...
I HAVE A WHIRLPOOL DISHWASHER MODEL DU890SWKU0, MY QUESTION IS: EVERYTHING WORKS BUT THE WATER DOESNT GET FULLY DRAINED WHEN CYCLE IS COMPLETE. WHAT CAUSES THIS? THANK YOU
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Sep 09, 2010 | Whirlpool Dishwashers
My dishwasher does not drain completely. There is
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Jun 04, 2010 | GE 24 in. Profile PDW7800 Built-in...
Water left in bottom of dishwasher after cycle
a little water is supposed to remain in bottom so that pump will not lose prime
Nov 07, 2009 | Dishwashers
Water left in the bottom of dishwasher after cycle was complete
If the water doesn't drain from your dishwasher, check these:
  1. Drain line/air gap--A clog in this part is the usual reason that a dishwasher doesn't drain. Remove the drain line to clear any debris from the hose or hose connection at the household drain line connection. Reattach the hose before starting the dishwasher again.
  2. Pump--You can reach the pump from inside the dishwasher. Remove the lower rack, spray arm and support. Look for an impeller, a device that spins around and forces water through the spray arm. This is the wash impeller and beneath it is the drain impeller that pushes the water into the drain port. Replace it if found defective or worn out.
  3. Drain valve/solenoid---The drain valve may have a solenoid with lever that sticks or frozen and prevents the dishwasher from draining. Free up the solenoid and lubricate the lever.
  4. Belt---A certain brand of dishwasher uses a belt to drive the pump. Replace it if broken or worn out.
  5. Motor---Check it if turning or working.Turn the rotor manually to see if stuck and free it up. Replace if defective, it is not serviceable.
Aug 27, 2009 | Frigidaire Dishwashers
Dishwasher not draining
try pressing the cancel/drain button.Do you hear water draining into sink freely?? if not i would disconnect drain undersink look for a clog right there first
Feb 22, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Kitchenaid dishwasher - water standing at end of cycle
less than 2 cups of water in left after cycle complete
Dec 02, 2007 | Siemens 24 in. SE25A266 ExtraKlasse...
Shu9915uc dishwasher wont drain
it should have water just below filter tray, if it does not actually empty then you have a blockage ,remove left side panel to gain access to drain pipe and side chamber. Regards Engineer
Aug 05, 2007 | Bosch SHU9915UC Dishwasher
Dishwashers Logo
395 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
