Question about Homelite Consumer Products 9.0 Amp, 14 In. Chainsaw
Verry little spark homelite 330 - Homelite Consumer Products 9.0 Amp, 14 In. Chainsaw
5 Suggested Answers
  • 211 Answers
SOURCE: Homelite 330 has no spark
Hi
First check if the plug wires is conected with the terminal from the rubber boot,pull the terminal out of the boot,crimp it with pliers and slide it back into the boot(has to fit snugly on the plug.Let me know
please.
regards savumihai71
Posted on Dec 10, 2008
  • 4088 Answers
SOURCE: hi how to tune homelite 330 chain saw carby, idle
Before adjusting anything, check the fuel filter, air filter, and muffler for plugging. Check the condition of the fuel lines for decay or other damage. Tighten all carburetor fasteners. Make sure you have fresh fuel mix in the tank. Does the primer bulb pull fresh fuel into itself when pumped? Turn both jet screws CW to stops (lightly), then back out CCW 1-1/2 turns each. This is a basic setting and should allow the engine to start and run. Start the engine and allow it to warm up, then pull the throttle full on. Adjust H needle CW until the engine starts to speed up, but still 4-stroking. Proper final adjustment is when the engine 4-strokes unloaded, but immediately 2-strokes when cutting. Release the throttle and adjust L needle CW for fairly good idle, but still allows the engine to 'follow the throttle'. Adjust idle speed screw so that the chain stops turning, but the engine will continue to run. Hope this helps!
Posted on Jul 15, 2010
roadtech7
  • 293 Answers
SOURCE: no spark on homelite 330
The switch grounds the coil and kills the spark. Make sure you dont have a rub through on the wire coming from the coil. Better yet disconnect the coil wire. If this works you will have spark but wont be able to shut it down. Verify good spark, then repair the wire.
Hope this helps, Matt
Posted on Dec 13, 2010
  • 130 Answers
SOURCE: Need gas/oil mix for Homelite 330 10604A, HJ
To the best of my recollection the 330 is an older model saw and should be running about a 16:1 ratio. 8oz. of oil to 1 gallon of fuel. Hope this helps.
Note: You're always better being a bit richer (lower ratio) than you are leaner (higher ratio).
Posted on Feb 20, 2011
Need to know; oil mixture spark plug setting for a homelite textron 330, ser.#3D2360270, Ut#10609
Hi gandp1993..
50 to One...oil to gas ratio 1 pint of 2 cycle oil to 6 gallons of gasoline.
Spark plug setting... .28 - .32
Please take time to rate me
Sep 22, 2011 | Garden
I would like to know where I can buy or order an inlet manifold boot for Homelite 330 Chainsaw. I am having difficulty finding this part.
hi photobil
pauly46 here
here is web site for parts
http://www.odref.com/homelite/chainsaw/ut-10540.pdf
go to page 9
part ref # 26 number 93838b boot connector
save a copy of this file
here is another web site
http://store.chainsawr.com/collections/homelite-1?page=11
he has had them but o/s at present but order 1 anyway
check out www.chainsawr.com , go to parts by brand homelite ,
cheers hope it helps
pauly46
May 29, 2011 | Homelite Zama Rb3 Carb Kit 330 Chainsaw...
Feb 20, 2011 | Homelite Gas, 20 In. Bar, 46 CC, Chain...
No spark on homelite 330 chainsaw. wire on on\off switch broke. thought to be ground wire. attached to block, still no spark switch in either direction.
Dec 12, 2010 | Homelite Garden
I have a Homelite chainsaw 330 and want to know the ratio for mixing my oil with gas. An early reply will be greatly appreciated!
50 to 1 or on oil it will say 50:1. It means 50 parts gas to 1 part oil.Usually 3 to 4 ounces of oil to 1 gallon of gas. The truth is it will not hurt to put in slightly too much oil. It will just smoke more out of exhaust & prematurely foul your spark plug. If you put in too little it will hurt the engine.
Sep 24, 2010 | Homelite Garden
Chainsaw will not run, there is no spark detected
Homelite 330 – no points
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/baf9791bfc773f1a88256c2600142688?OpenDocument
Please try this
Ignition Coil Test by SmallEng.com
http://www.youtube.com/watch?v=L7WNBDRG4C4
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You don’t have to bend up the electrode. HTH
Lou
Oct 27, 2009 | Remington Electric Chain Saw
Hi
please.
regards savumihai71
Dec 10, 2008 | Homelite Consumer Products 9.0 Amp, 14 In....
Homelite Consumer Products 9.0 Amp, 14 In. Chainsaw Logo
51 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
