Condura what is SL error?
What does it Mean if there's a cf error code in condura Window type aircon?
That code means COOLING failure and could be a variety of problems from something as simple as a dirty filter to a bad compressor. More info would help me narrow it down
Feb 05, 2018 | Heating & Cooling
I have condura non-inverter. When I turn on the unit, the led display keeps on blinking
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Jul 02, 2016 | Televison & Video
What's the original capacitor number use by condura aircondition model NG 070...
Ano po ang value ng compressor capacitor ng condura room aircon na ang model ay NG090DLX? Naerase nakasi ang number sa metal case ng capacitor .
Dec 21, 2015 | Heating & Cooling
Run capacitor mfd for cd090dlx model
sorry we are not sellers of anything here
May 30, 2015 | Heating & Cooling
How to fix the water at condura jr aircondition
check the drain line for blockage there should be a drain line hooked up
May 26, 2013 | Heating & Cooling
Why does the fridge of condura does not get cold but the freezer gets iced
Its ok that on and off every day to consume much lower charges
Dec 24, 2012 | Refrigerators
Problem with a Condura A/C. It displays an "FL" error on the LED display. What does this mean and how do I get rid of it?
FL means, filter check warning. To get rid of it, Press the 'mode" and " " (down) buttons simultaneously for 3-5 sec.
May 22, 2011 | Carrier 38CKC024 Air Conditioner
Window type condura aircon noisy
check fan or blower is unbalancedor touch the frame or fan motor bearings or sleeves defective.
Aug 28, 2009 | Carrier 52CE-307-3 Air Conditioner
Heating & Cooling Logo
18 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
