Question about Poulan Pro Chain Saw 46cc 20"
How to replace the fuel line in a Pro Poulan 4218 chainsaw
    Master:
  • Poulan Master
  • 645 Answers
How to replace the fuel line in a Pro Poulan 4218  - fuel lines-qrelmqk4g3fibgknnkf5eqzm-4-0_0.jpg
Posted on Jan 17, 2018
  • 3 Answers
SOURCE: I have a poulan pro
SOUNDS LIKE YOU FOLLOWED ALL THE CORRECT PROCEDURES. TRY TO GOOGLE SEARCH YOUR POULAN PRO MODEL #, I'VE HAD ALOT OF LUCK GETTING MANUALS AND DIAGRAMS FROM THERE. GOOD LUCK!!!
Posted on Jan 25, 2009
  • 97 Answers
SOURCE: routing of fuel lines from tank to primer bulb to carb
Line with filter goes to carb inlet,
Line from carb goes to inlet side of bulb.
Line from bulb goes to tank
Posted on Mar 21, 2009
dontbother10
  • 2220 Answers
SOURCE: I have a poulan 2150 chainsaw. I replaced the
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer, the output line from the carburetor connects to the suction side of the primer bulb (once bulb is collapsed it draws fuel from the tank through the carburetor to refill the bulb as the bulb refills).
  • The pressure side of the primer returns any excess fuel to the tank as it is depressed.
HTH
Lou
Posted on Oct 25, 2009
jrox55
  • 66 Answers
SOURCE: poulan pro 220 chainsaw owner's manual for tune-up
you could try cleaning the carb and filter. make sure your fuel lines are clean too
Posted on Feb 27, 2010
  • 4088 Answers
SOURCE: Routings of fuel line to Poulan 14 inch chainsaw Model 2025
No drawings or pix, but will try for description--the line from the tank that has the fuel filter is the main fuel source which goes to the upper connection on the carburetor. The lower carburetor connection goes to the intake side of the primer bulb, and the outlet side of the primer goes back into the tank, which has no filter inside the tank. The main problem is determining the correct primer port to connect back to the carburetor. When everything is connected, try priming the carburetor. If fuel fills the bulb, you have everything connected correctly. If nothing happens, try switching the two primer port connections and try to pump fuel again. If still nothing, hook the main supply line from the carburetor over to one of the primer ports and try for fuel again--if still nothing, switch the main supply line to the other primer port and pump again. If still nothing, check for a plugged fuel filter in the tank. If the filter was plugged, then go through the previous procedure again. Make sure to replace the fuel lines with original rubber lines, not plastic. Hope this helps!
Posted on Jul 16, 2010
Poulan 4218 runs good for 5 min when you cut it off let it set and try to re start seems to kickback like timing off
Some of these models did have a kickback issue. Check the flywheel side of the saw, make sure the key has not been sheared. This would allow the timing to be off. One time kickback can shear the aluminum key.
Sep 23, 2016 | Poulan Pro Gas Chainsaw 18" Guide Bar 42cc...
How do i replace fuel lines?
Where do the fuel and primer lines go in Craftsman or Poulan Chainsaw
Hope this helps. Also try to avoid using gasoline with ethanol. This causes the lines to deteriate.
Apr 30, 2016 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Need fuel lines diagram for poulan pro ppb1838 chain saw
How to ... Poulan Chainsaw - replace fuel lines - YouTube
? 5:05
www.youtube.com/watch?v=jZqCNiYgF3g
Mar 27, 2012 - Uploaded by minthillbilly ... and demonstrates how to diagnosis and repair a Poulan 2700Chainsaw. ... I have a brand new Poulan Pro, the hose went bad
Jul 31, 2015 | Poulan Garden
How can i get my poulan pro 4620avhd to idle ?
I have referenced the Poulan Pro 4218 Manual so you can see a similar troubleshooting guide which should be close to the 4620 version.
Nov 18, 2012 | Poulan Pro Chain Saw 46cc 20"
I have a poulan pro 4218 it was running great when i put it away last year . went to start it this year put in fresh fuel i have a spark used starting fluid doesnt even try to start what gives?
If there is good fuel in the tank and there is a good spark, there is only two reasons why it will not fire up, the ignition timing is out ( sheared flywheel key ) or there is too little compression ( engine has seized at some time trapping the rings )
Oct 14, 2012 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Where do i find model no. on my 4218 avx 42cc poulan pro chain saw?or is that the model no.
4218 is the model, the key is part of the flywheel, so if the key has sheared it will require a new flywheel.
Mar 17, 2012 | Poulan Garden
Where can I find a diagram for the fuel system ? I let a someone who new less than I did try to replace old fuel lines. it will crank and run untill carb. runs out of fuel.
An exploded parts list for a 4218 type 2 chainsaw follows (May not be your saw):
Poulan.com The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best. They are also beneficial with disassembly/reassembly. Fuel components and part numbers are listed but may be on different illustrations:
http://www.ordertree.com/modelinfo/PWE/PP4218-Gas-Saw-Type-2/75.PP4218-Gas-Saw-Type-2.1.59.1.html
The dash number of your serial number is the type.
A very good general diagram of a 2-cycle fuel system can be found here:
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using fixya.
Jan 08, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
What size chain does the Poulan Pro 4218 use?
It is an 18" chain .The user manual is at http://www.chainsawsdirect.com/manuals/PP_3516_4218_Man.pdf
On page 6 the part numbers for the bar and the chain are shown
Hope this helps .. if so, pls leave feedback, if not - let me know!
Jan 24, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
No spark from spark plug
New Saw? Warranty time
Electronic ignition? Replace entire module. Pinched wire to metal case part for ignition switch. Permanently shorted ignition switch--replace.
Jun 27, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan Pro Chain Saw 46cc 20" Logo
116 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
