Question about Emerson MW8107WA Microwave Oven
What is the power output - Emerson MW8107WA Microwave Oven
What is the output power of National NN-C2000P microwave oven?
the pwr rating is normally on the label.
google for a manual
Feb 02, 2016 | Microwave Ovens
What is the actual power wattage? on the back it says single phase 1200 w and out output is 800 w.I dont understand the difference
1200 watts in to operate the appliance then 800 watts power output emitted in microwaves for cooking.
Sep 16, 2015 | Microwave Ovens
What wattage is toshiba er6860w microwave?
You can do an exact power measurement by putting exactly
500 ml of water in a glass (Pyrex) or plastic measuring cup in the microwave. Measure the beginning temperature and record it, preferably with a digital thermometer. Run the unit on high for exactly 18 seconds. Use a digital watch or a stop watch, not the timer on the unit. Remove the measuring cup and stir the water to make sure that all the water is a uniform temperature. Record the temperature rise. Say the temp rise is 20 degrees Fahrenheit Multiply that figure by 38.75, this would indicate that the power delivered into the cavity is 775 watts. This is the old standard of measuring the power. The new standard called the IEC 705 would add 10% to that for a total of 852.5 watts. This matters more than the rating of the unit because if the power output is more than 15% below the units rated power, the magnetron is probably getting weak and needs to be replaced. Probably not worth the cost to repair. The voltage at the wall could also cause a low power output output. 'Google' the model # to see if you can find any info on this model #......
Nov 04, 2013 | Microwave Ovens
On model mw8626w can i use it in my semi with a 1000 watt inverter?
Take a look at the oven's electric rating information. It should be on the label with the model and serial number, and it will tell you how many amps the oven needs. Power in watts is volts times amps, so a 1000-watt inverter is good for about 8 amps at 120 volts output. Some inverters also use a peak rating, meaning power than can be delivered for a short time. The continuous power may be less than that; you'll need to look at the inverter. As long as the power needed by the oven is within the inverter's ratings then you'll be able to use it. Otherwise you'll need to shop for one with more output power.
Jul 15, 2011 | Emerson MW8626W Microwave Oven
Wattage Power
Unfortunately, the old owner's manual doesn't say, but you can do a test to see what its heating power is:
MICROWAVE HEATING POWER TEST
The following test will provide a suitably accurate measurement of the output power of any microwave oven. Variations or errors in performing this test will produce uncertain results. If the line voltage (from the electrical outlet) is low, the magnetron output will be correspondingly low.
Equipment needed:
- Microwave safe container with 1000 mL (1 Liter) gradation.
- Fahrenheit or centigrade thermometer
Procedure:
Pour exactly 1000 mL (1 Liter) of cool tap water into the container. Using the thermometer, stir the water, then measure and record the temperature. For accurate results the water should be about 60 degrees F (20 degrees C).
Place the container on the center of the oven cooking shelf (do not leave the thermometer in the container and remove any metal racks), and heat the water (at full power) for 63 seconds. Use the second hand of a watch, not the oven timer.
After the heating time is completed, immediately remove the container, stir the water, re-measure and record the temperature of the heated water.
Subtract the starting water temperature (step 2) from the ending water temperature (step 3) to obtain the temperature rise.
To determine the output power in watts, multiply the total temperature rise by a factor of 38.75 if you're using a Fahrenheit thermometer or by 70 if you're using a centigrade thermometer.
Apr 28, 2010 | Hotpoint RVM1435 Microwave Oven
What is the wattage?
Oddly, the owner's manual doesn't say.
You can contact GE customer service here, or if it's working properly, here's a test that will tell you how much output power it has:
Equipment needed:
Procedure:
Apr 28, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave not working Goldstar MV1610ST
hi
probably not if it is the magnatron then it usually not worth ityou when you say no output do you mean from the trany our on the microwave itself if it is the trany then you need to check the diodesand cap if they are ok then it will most likely be the magy
cheers grant
Oct 21, 2008 | Goldstar Microwave Ovens
How can you check to see if your microwave oven is working at full power
Equipment needed:
Procedure:
To determine the output power in watts, multiply the total temperature rise by a factor of 38.75 if you're using a Fahrenheit thermometer or 70 if you're using a centigrade thermometer.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 06, 2008 | Microwave Ovens
Microwave wattage at different power levels
Usually the output power is adjustable from 10% to 100% in 10% steps relative to the full output power rating.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Apr 15, 2008 | Panasonic NN-MX25 800 Watts Microwave Oven
Emerson MW8107WA Microwave Oven Logo
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
