Gbc h250hs I have a piece of plastic stuck inside. How can I get it out.
How do I remove the back of my GBC laminator to remove paper that is stuck inside the unit?
First, you must take out 4 screws out of the cover on each side of the laminator , then you will see the screws that hold the back panel onto the laminator. West Laminating secs 405-324-6092
Oct 14, 2014 | Gbc HeatSeal Ultima 65 Laminating System
A laminate and paper jam in a Gbc HeatSeal H425 Laminator
You need to loose the vertical plastic wall on the left side, and pull it up and to the left, only then you would be able to take pink rollers and metal piece away. Step by step do this (BTW, make pictures of each step if you think you will not be able to assemble it back) :
Download parts scheme here (if link is broken I can send you; write to ororeivis [at] g mail com):
http://www.gbcconnect.com/assets/docs/H425_PARTS_POUCH_LAMINATOR.pdf
Take the lid (3) off and hang it on the corner.
Next goes off (42) part.
Now focus on the left side. Take to the side part (30) with 7mm wrench. Then both parts (14) from both sides [4 in total]. Then both parts (2). Then take out screws that are holding this vertical plastic wall place. There is two screws from the outside of laminator in the bottom!
Then black roller (36) you lift up and take out by sliding to the side. Then two long black metal pieces.
Now you should be able to pull up and move to the left that vertical plastic wall on the left side of laminator. If not, try loosing some screws that are in this wall.
Be careful taking melted jammed stuff away from heating panel. Do not over-scratch it, as it is very sensitive.
floating cowboy
Jun 26, 2012 | Gbc HeatSeal H425 Laminator
GBC #SC32 auto stop not functioning
take the shredding portion of the shredder off and check in its teeth (while unplugged of course) to check that there are no errant pieces of paper or plastic in the device. You may even want to try and blow out any possible paper stuck inside with some canned air or something.
Sep 06, 2011 | Quartet gbc Office Equipment & Supplies
Plastic tangled to roller not moving at all
I just had this problem. I let it cool but still let the rollers keep rolling. Take the roller cleaning cardboard thingy and listen for the now cooled tangled plastic pouch to click around the roller. AND reversing the rollers so I could see the stuck plastic. When I could see the plastic I let the reverse go back to normal rotation and put the cleaning cardboard through and it finally caught the plastic pouch and pushed it out! WOO HOO! SAVED MY MACHINE!!! MACHETE STYLE!
Aug 17, 2011 | Gbc HeatSeal H520 12.5-Inch Commercial...
My gbc heatseal h300 wont feed paper.
I have the same machine, GBC H-300. I have it apart right now, and found the feed motor gear in pieces.
Motor Gear 18T 120v part #26700056
Mike Dettling
May 26, 2011 | Grilling
How do I change the blade on a GBC AccuCut A400pro paper trimmer?
You have to pop/pry the blue plastic cover off with a screwdriver blade or something similar. The you unscrew the silver colored piece, then there is a piece of plastic, usually gray, which has a magnet on it, land clinging to the magnet will be your old blade. Remove old blade--watch your fingers, and you can use the magnet to get the new blades out of its plastic case. Align blade and gray magnet--there is notch at the top, put the screw back on and pop back the blue pastil cap. Voila I ran into the same problem until I realized the directions were on the cardboard backing of my replacement blades. DUH!
Oct 11, 2010 | Office Equipment & Supplies
Several pieces of clothing stuck under agitator.
you can remove the agitator. there are 3 steps to this. 1.take off the top plastic part of the agitator. 2 remove secondary plastic piece from inside of agitator 3. there will be a 7/16 bolt inside and will be deep so you will need a long extension to reach it. hold the fins of the agitator and remove the bolt with a ratchet. once the bolt is out you will be able to lift the agitator up.
Jan 03, 2009 | Kenmore 22422 Top Load Washer
STUCK ON STANDBY
I took the ****** apart and found two spring-loaded black triangular plastic pieces poking out of two rectangular chips about 2mm square, just below the circular piece on the outside of the camera that changes mode – play, video, camera. Actually I found one of the above, because the second triangular piece was stuck in the closed position. A bit of jiggling and voila the problem was fixed.
That was the good news. The other news is that I must now reinsert inside of the shell a black circular piece of plastic that affixes to the rotating circular piece on the outside of the camera that changes the mode. When properly attached this circular piece manipulates the triangular pieces to change the mode.
I think that the likelihood of getting this piece properly aligned and affixed so that it moves the triangular pieces properly when the mode knob is rotated falls into the statistical probability range of pork taking wing. But worth a try.
Sep 04, 2008 | Fuji FinePix A345 Digital Camera
Stuck in park
is the jeep on a steep hill if so try rocking the jeep back and fourth while somone is inside trying to shift.
May 26, 2008 | 2004 Jeep Wrangler
Shredded paper is wrapped around blades
Try saturating paper jam with liquid vegetable based cooking oil from your kitchen this should soften the paper after sitting 6-7 hours
Oct 28, 2007 | Quartet gbc 1150X Shredder
42 people viewed this question
k24674
jasbo
jasbo
