Question about Thule 2000 Ford Taurus - Wagon, with factory roof track - Base Rack System
How to replace 2005 gmc tag light - Thule 2000 Ford Taurus - Wagon, with factory roof track - Base Rack System
No tail lights or instrument panel lights
Thread: Help! No Dash lights, Tail lights or Tag lights - The Ford ...
forums.focaljet.com/.../510540-Help!-No-Dash-lights-Tail-lights-or-Tag-...
May 2, 2006 - 11 posts I have a 2002 Focus SE 4dr. I don't have any Dash lights,Tail lights or Tag lights. Everything else is working ... Join Date: Oct 2005; Posts: 838 ...
Sep 15, 2015 | 2005 Ford Focus
2005 gmc sonoma. Tag light isnt working . I was going to check the fuse but cant find tag light listed on fuse diagram. What else would they call it so i can locate what fuse its on. And if its not fuse...
You can check the fuse, but the problem usually is the bulb or the socket contacts where the bulb plugs into.
Tag lights (license plate lights) are exposed to a lot of weather/road exposure and bumps/vibration, which shorten their life.
Rarely is a "tag light fuse" listed. The tag light is typically on a circuit with several other lights or accessories, and most commonly on the taillight circuit fuse, but not always.
Only a wiring diagram or a manual will be able to verify which circuit/fuse it is on, so you may have to check several fuses.
IF it turns out to be a blown fuse, your first step should then be to trace and identify the source of the electrical short (usually in wires by the tag light itself). Simply replacing a fuse is NOT a cure or a good 'repair'.
(As I write this, I have 2 tag lights out on my vehicle,, one which I verified is a blown bulb, and the other due to a badly corroded bulb socket)
Please rate via the helpful button if this helped answer your question, and please post back (via comments) when you discover the actual source of the problem.
Nov 10, 2014 | GMC Sonoma Cars & Trucks
GMC Sonoma Tag lights and dash light not working.
Maybe you didn't reconnect the ground for those lights. Check for tail light fuse or IP lights fuse. You may have to get a test light or voltmeter, and start looking for where power is lost. Start at the rear light sockets, and work back to the front, to the park light switch.
Dec 31, 2013 | GMC Cars & Trucks
GMC 2005 Savanna, running lights will not shut off even when the van is turned off. Switch was replaced but the lights are still on.
Interesting that this same problem has started with my 2005 GMC Savana.....they turn on by themselves and won't turn off.
Dec 05, 2010 | 2005 GMC Savana
I have a 2005 GMC Yukon XL. The service 4WD is on.
Yes you do have to take it to the dealer, This is a common problem in these trucks. This is caused by a bad encoder sensor in the shifter on the side of the transfer case. The sensor can be replaced with out having to replace the shifter assembly.
THe best test is to get the code from the system. This sensor is a sliding resistor and the material wears off causing a false reading. That is why the lights were showing Nothing, but you were able to drive. The code for the sensor is C0327.
TBS: #PIP3480M: Rattle Drone Or Buffeting Noise At Highway Speed In 2WD Or DTC C0327 - keywords 246 2hi 2high 4WD auto awd buffet buzz case click indicator knock lamp light service tick transfercase transfer vibrati - (Mar 4, 2008) Vehicles involved were built approximately between 01/01/04 and 03/06/06. The noise condition if not noticed by the customer may cause eventual encoder sensor wear causing DTC C0327 set in the Transfer Case Control Module (TCCM).
An updated TCCM calibration has been released to apply light pressure to the transfer case clutch pack and reduce the rattle. The calibration was released on 3/18/07 and the title line will read "to correct transfer case rattle at highway speeds and possible DTC C0327". For Rattle only (no current DTC C0327 set), Install the updated calibration and if necessary follow the diagnostics listed below
If the vehicle has a current or history dtc C0327 and can be diagnosed to the encoder sensor, re-flash with the updated calibrations and replace the encoder sensor as necessary.
Important Note: All NV246 transfer cases built 02/25/06 and beyond are manufactured with pressed fit parts to help reduce the rattle. Inspect the ID tag on the transfer case for this build date and verify the tccm has the latest calibration before repairs are initiated.
Thank you fur using Fixya and good luck.
Apr 20, 2010 | 2005 GMC Yukon Xl Denali
2005 GMC STALLS IN ALL GEARS
your fuel pressure regulator is bad, replace it!!!
Aug 15, 2009 | 2005 GMC Envoy
Tag light replacement
Push the entire assembly back into the cargo area of the vehicle - it is clipped to the frame. (You may need to use the blade of a screwdriver to pry it loose).
Remove the electrical feed cover (red plastic) from the assembly by depressing the side clip.
Now, holding the asssembly in your hands, remove the lense cover top from the black bottom by depressing the side inserts.
Pull out the bulb, and replace.
Reassemble in the reverse manner.
The entire job should take no more than 3 to 4 minutes.
Apr 15, 2009 | 2005 Honda CR-V
There are 2 screws securing the plastic cover right above the tag on the bumper. Twist them open and replace the two bulbs inside. You may need to use liquid wrench to break the rust on the screws.
Feb 07, 2009 | 2005 Toyota Camry Solara
How Do I find out if My 2005 Canyon has the Bose system or not?
sounds like a standard system to me but i think the bose has little tags on all the speaker grills that say bose
Jan 09, 2009 | 2005 GMC Canyon
Thule 2000 Ford Taurus - Wagon, with factory roof track - Base Rack System Logo
450 people viewed this question
Top Thule Home Experts
Donni Steen
Tom Chichester
Are you a Thule Home Expert? Answer questions, earn points and help others
