Apex no sound mode LE 1910 19" one year. moved and DirectTv man could not get sound but it has beautiful picture
Tv had been working beautifully. Moved and packed in original box. Direct tv man set it up and could not get sound, but hada beautiful picture! What to do??
  • 192 Answers
SOURCE: HDTV Cable box conflict
This set does not support 480I in the DTV mode, only 480P and 1080I is supported. Try setting the analog setting in the cable box to 480p and that should take care of watching the set in DTV. Most cable boxes have a setting for format changes in the customer menu, depending on the type of box. If you are able to change the format, then the other inputs will not work since they need a 480I signal, as well as VCRs. Another setup could be to use the S-Video cable or Video input jacks to get a better picture in 480I instead of using the cable input. However, when changing from HD to Analog, you will have to change to the correct input on the set as well. Hope this helps.
Posted on Dec 25, 2006
SOURCE: Help K2001UM TV
I'ts possible that by accident someone activated the parental lockout. Your best bet is to locate your instruction manual and find the default code. Also problems(usually with software) can cause the the tv to do unusual things. Leave the set unplugged for at least 24 hours, the see if there is a response with the buttons on the tv. You may be able to reset the set to factory defaults. Scrivitron
Posted on Jul 09, 2007
  • 556 Answers
SOURCE: Have a beautiful picture but no sound
your problem is in sound section only. 1 signal line for sound coming from vif section 2 supply to audio section. 3 component fail in audio output section. 4 loose contact in audio section 5 speakr & its connecting wire.
Posted on Sep 27, 2007
SOURCE: ** sound! Please help
I'm not sure about 10 seconds but its been unplugged and plugged back in and the darn thing still wont work.
I will try it
Thank you!
Posted on Mar 17, 2008
jerryg50
  • 1667 Answers
SOURCE: TV picture fades, then shuts off
There are some components in the scan amplifiers, and or the power supply area that have become unstable. This can happen with age and use. It is impossible to make an accurate assessment without actually troubleshooting the set.
You need an experienced TV service tech that is strong on troubleshooting, has the service manuals, and has the proper set-up to work on your set. I would recommend the factory service rather than an independent service tech unless you know for sure that the independent service tech can handle this type of repair.
Considering the age of the model of set that you have, I would be looking at replacing it rather than fixing it. Because of the age of the set the reliability will be decreased.
Jerry G.
Posted on Jun 10, 2008
The picture went black...has sound....bulbs gone?...lamp? Thx
Seems to be the inverter board that controls the bulbs! With the TV on if you shine a torch at the screen can you see a faint picture? If so it is the inverter board that needs replacing!
Jan 04, 2015 | Mitsubishi WD-52525 52" Rear Projection...
Humming sound
This type of sound can be generated by the back-light inverter board.
Jun 15, 2013 | Sony BRAVIA KDL-52XBR4 LCD TV
I have the code for my apex digital converter box but I have no sound but beautiful picture why is this
Look for a pair of audio jacks on the back of the box. You may need to run a seperate pair of RCA jacks (Left/Right) to you television to get audio.
Jun 10, 2013 | Apex Digital DT250A Digital TV Converter...
I have DirectTV and a DirectTV remote RC64. I can
Here are all the codes I have
10171 10096 10187 10020 10381 10024 10030 11314 10186
here is how to set up without a code:
mode switch set to TV
PRESS & HOLD Mute and Select buttons at the same time UNTIL light blinks twice
enter 9911
keep pressing channel up until the channel changes on the tv
Maker sure to test the VOL button, if volume works
PUSH select key to set the code
THESE PROCEDURE CAN BE USED WHENEVER A REMOTE KEY IS NOT AVAILABLE.
CHANGE THE LAST NUMBER, 1 TO
2 for AUX1 (VCR and DVD)
3 for AUX2 (Audio Devices)
Mar 27, 2009 | Sylvania LC320SS8 32 in. LCD Television
No sound beautiful picture
check color code cables be sure all cable match up with the right inputs red to red and white to white rca or HDMI will same you alot of problems but sure that your tv have HDMI outputs
Feb 04, 2009 | Hitachi 61SWX10B 61" Rear Projection...
AV-2053m
My problem is solved!!! I called my neighborhood TV repair shop. The technician suggested I check the Internal Speaker Switch on the back of the TV. And sure enough, I had accidentally move the switch to the OFF position while carrying it from one room to the other. Ahhhhhhhh!!!!!!!!!!!!! my 13 year old JVC is as good as new!!!!!
Aug 02, 2008 | JVC AV-32260 32" TV
Blue tint screen in video mode
· http://esupport.sony.com/perl/news-item.pl?news_id=24
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
Jan 05, 2008 | Sony KP-57HW40 57" Rear Projection...
Brand new TV and it has a beautiful picture but no sound any suggestions?
S-video does NOT carry audio.
You'll have to get some RCA audio cable and connect them to the audio in ports associated with the S-Video input.
Nov 21, 2007 | Olevia LT32HVM 32 in. LCD Television
No Picture
If when you press the volume or channel up or down button you get no OSD, that's is no channel number or volume up bars, have some one check the set for either a defective video out IC or a defective picture tube, or a bad cap in the power supply. Set should be serviced by a TV repair person.
Good day!
Toprol
Nov 06, 2007 | Apex Digital AT2708S 27" TV
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
Electro Med Services...
