Question about Casio Exilim EX-S600 Digital Camera
Memory card won't unlock
I have a canon power shot and when I insert the pny micro sd the
i keep reciving a message that the meory card is locked . this is even after moving the lock. casn you help ?
  • Casio Master
  • 4,738 Answers
First I know you've said you've checked the card's slide switch, but just want to restate this first for others with the same problem who may not know of this switch.
Check to make sure that you didn't accidentally place the tiny locking slide switch on the side of your SD card in the "locked" downward position. The correct "unlocked" position should be slid up toward the direction of the connectors.
If you've tried this, and it's still showing locked, it's likely that the locking switch inside the camera's card slot is stuck. If you look inside the slot on the side of the slot where the SD card slide switch would be, you'll see a glint of gold color on the side. This is the camera's lock/unlock switch. The other glint's of gold that you may see at the far end of the slot are the reader's connectors (ignore those).
Somehow, the locking switch is making contact and has become stuck in the locked position. With a plastic toothpick, or other skinny NON-METALLIC item, tap against this switch to see if you can jar open the contact to its normal unlocked position. Also try blowing compressed air at it, as some gunk may have worked its way in there, jamming it closed. Occasionally, reinsert the SD card to see if the issue has been corrected.
If repeated tries fail, it may be time to consider opening the camera to force open this switch (not recommended unless you have some familiarity with electronics). In this case please see the following (xscrewdriver, hope you don't mind me referencing your blog):
http://www.myfixtips.com/blog/digital-camera/how-to-fix-a-%e2%80%98card-locked%e2%80%99-problem-125.htm
Posted on Jul 11, 2009
Micro sd adapter i keeps in camera it is shows card locked
SD and Mini SD memory cards has a small slide switch on the edge of the card, which write protects data on the memory card or add photos to the SD card. Slide the switch from the LOCK position to the UNLOCK position, which is furthest away from the contacts.
Mar 18, 2013 | Canon Cameras
My canon power shot A420 blink a massage card locked ,card error when i micro sd card adaptor in it and my adaptor is also unlock mod
Feb 02, 2013 | Canon PowerShot A420 Digital Camera
How to unlocked pny optima sd memory card 4gb
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Oct 28, 2011 | PNY 4GB Secure Digital High Capacity...
My memory card has been locked i dint keep any password i conneted to pc and clicked format but it says insert a disk plz solve my problem
Here is a tip that I wrote about SD Cards and how to unlock and lock SD Cards.
If you are getting a memory card locked message then check this out.
How to Unlock SD Card
heatman101
Nov 12, 2010 | Kingston 2GB Secure Digital Memory Card
My 1 gb pny micro sd card has locked . how i can unlock it?
There's a switch on it to unlock it. Slide the switch to the other side of its travel.
Sep 09, 2010 | PNY 2GB microSD Memory Card
How unlock i lost password
i don't think micro sd cards have lock codes. If it's not letting you install pics or music then check the adapter that you put it in to when inserting it to your computer. The adapters have a no write lock on it's side. just slide it to unlock if it's locked.
Mar 11, 2010 | PNY 2GB microSD Memory Card
I have a PNY Micro Sd card and I slid the lock (write protection)
not much you can do.. try to slide the lock back, if that doesn't wrok, go shopping.. they are pretty cheap righ now..
Good luck
Oct 23, 2009 | PNY 2GB microSD Memory Card
My micro SD meory Card got lock i want to unlock it but i dnthave card reader
Dear Sir,
I have Nokia 5310 xpressMusic phone with two GB micro SD memory Card, which has locked. please unlock the same at your earliest.
Yours sincerely,
Customer
Jun 03, 2009 | Nokia Consumer Headset
How do i hook my PNY micro sd to my computer
check if the lock tab on the adapter isnt on lock
Jan 31, 2009 | PNY 2GB microSD Memory Card
Casio Exilim EX-S600 Digital Camera Logo
1,158 people viewed this question
Top Casio Cameras Experts
mohamed salim shaikh
pontelemon
pontelemon
Are you a Casio Camera Expert? Answer questions, earn points and help others
